Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Elektroonika "tweaks"
Pealkiri: Elektroonika "tweaks" (Vastuseid: 3 | Vaatamisi: 984)
r1v0
Registreerunud 25.11.13
postitati 25.11.13 12:50 Tsiteeri
Tere, tulin teadjate käest küsima. Plaan on minna audi esindusse elektriku juurde. Esiteks vaja minna sellepärast, et service-timer uuesti 30k peale saada, kuna ise hoolduse tegin ära, siis õlide vahetamist ja sellist jama pole vaja. Ning teise asjana tahtsin ka päevatulede automaatse lülituse "eestistada", ehk siis soov on, et ta mul ka päeval need põlema paneks.
Teie käest tahaksingi uurida, et kui juba minek on, mida head ja huvitavat saaksin veel elektrikul lasta vaadata või muuta. Auto ise on 2006 A4 2.0TDI. Lisavarustusest väga palju pole. Multirool, värviline displei kellade keskel, vihmasensor, 4x el aknad, el kokku klapitavad peeglid, tumenev tahavaate peegel ja muu pudipadi. Suuri navisi ja tagurdusandureid kahjuks pole.
Teise küsimusena esitaksin selle, et kuidas aru saada, kas mootor on 100kW või 103kW. Sevice'i raamatus, passis jne on kirjas 103kW, kuid kui hakkasin filtreid vahetama, sobisid ainult 100kW omad, ehk nii kütte kui õli filter olid lühemad.
postitati 25.11.13 13:05 Tsiteeri
Siin teemas on väike ülevaade erinevatest B6/B7 diiselmootoritest:
http://foorum.audiclub.ee/viewthread.php?tid=112175
Lähtuda tuleks ikkagi mootorikoodist , mitte kw'dest.
tl470487
aeg maha
Registreerunud 06.07.11
postitati 25.11.13 14:43 Tsiteeri
Kui teed ise hooldust siis, mis takistab iseseisvalt selliste seadete tegemist?
Kaalu seda.
r1v0
postitati 25.11.13 14:52 Tsiteeri
Takistuseks on vajaliku tehnika puudumine :)
takistuseks on vajaliku tehnika puudumine :)
[PHP: 35.8% - SQL: 64.2%]
