 Lehekülgi:  1  ..  3  4  5  6  7  8
Pealkiri: Audi V8 4.2 Q - 1991 - RKsilver / MÜÜDUD (Vastuseid: 177 | Vaatamisi: 49916)
Silverpm
Registreerunud 06.04.08
postitati 10.04.10 23:01 Tsiteeri
Ka võimalus..
Mis vahepeal juhtunud on ?
Väikseid iluvidinaid saanud auto omale-aina originaalsemaks!
Püsikiiruse hoida-(kangid,mootor,aju,hoob) ning minu audil igatahes oli ainult plug and play ja asi töötas.:P
Väga hea nüüd cruiisida.
Teised valuveljed.
Teised püstakud.
Teine radiaator.
Silverpm
postitati 11.04.10 11:37 Tsiteeri
http://images.orkut.com/orkut/photos/OgAAAJKx-2d-L-YUT-mne_Y3iM7LUbu05WPjGW-rSkU32DmUs-FXEGkRa3T3mdVEqRXpmw3omtWzJ-WwCDahc_DxVZkAm1T1UHYNw6Mdlsg
http://images.orkut.com/orkut/photos/OgAAANKNe3SLwX86QD-PrvH5Qc1B-GqefZQtvN3zDrZD5MnQjEWndWrLurrQ0osS2SN8V86YrtwAUx9cTLyMfuVaZRkAm1T1UNWzRbAEqxq
http://images.orkut.com/orkut/photos/OgAAAMNi5E10ZoDbutGrgOjTGgj6hqzh-YzifPe6HZnthfX15--qIm5MJ2QQDfTb6HK8EdWSS-R2z3vTjGLLYmskTSYAm1T1UBoD0rsaefL
http://images.orkut.com/orkut/photos/OgAAALK3C3dot-h43_NHlNWbvlOaThCdMF82QZCE9BS-f0DZX713MOoHL3OwQF19xBMl_L3Uni955KPERVIRWueI6_AAm1T1UI-LHLsXXWZ
http://images.orkut.com/orkut/photos/OgAAAM64gHhIVTmKuWP8Z9SVZlEcc-uu8QBYhi8YKakadQRI_5qMNeCTPHg9iE7yzo7G7y-WMrvsJVbRc2gJhlizTRkAm1T1UDLD_WErn9B
http://images.orkut.com/orkut/photos/OgAAAByNJejzRA_3VJ6spptD9iQ5pgjZrMyMmBldFJo7srPCj0fXJptcjRYEMrZbqAtms9oaV1tAqZCMXkLPS2UzgAUAm1T1UFd6iFWgk5i
http://images.orkut.com/orkut/photos/OgAAAAGrNv10KJLLyDbl9MplkNuaxBNaFR7LWobnvoECIIyE41Bo3bb1cRGZZQY90Eb1p9pXLIMvpqBL-TL9v9mvBW4Am1T1UIQcaPLKqmE
http://images.orkut.com/orkut/photos/OgAAAAUJkKorAjOqaWErOJQdIN3XeLAbSoBgb0LDqLv87tVxAKmYIOHCrPJMIx9lKXkIDuAa0lDwDNxvrYoxpwDsE7oAm1T1UOxxaqhIYSL
http://images.orkut.com/orkut/photos/OgAAAAWJy3-Ghs7tpCkoMxS66cWZpTdZeLNuSppWEMc3GikJioN-njHavbRHZ_K5xquiHyG8gdWKlE1m3UTApWr4mtwAm1T1UIpjmfFCcZ5
http://images.orkut.com/orkut/photos/OgAAADndhIoasUstc22DHDFTEP-3XbSzZYq36_33SfFobdl1T3iQJgd7SKI8LPJumXj1FUEXr5-wfENhTUc3VLLwx_YAm1T1UDGxbZ1ygoH
Zandr
Registreerunud 26.09.05
Auto: Ex steroididel Sigar
postitati 11.04.10 13:27 Tsiteeri
Oi, kuidas mulle ikka need V8-d meeldivad. Minu maitse järgi sobiks pisut suurem velg ka ja siis oleks ikka väga 5+:cool:
Madaldus on aga kahe otsaga asi;)
Quattro, the only antidote known to man against the white cocaine like substance..
888
Registreerunud 24.01.06
Auto: Audi A6 Quattro
postitati 12.04.10 10:21 Tsiteeri
Minu omal on mingi 3cm madaldus ja välja näeb ta selline. Kuigi nivoo amort nagu hoiaks tagumikku kõrgemal:P
http://www.upload.ee/thumb/520674/P1012379.jpg
Sõitsid saanid-Sõitsid reed A Quattro sõidab ikka veel;)
Silverpm
postitati 12.04.10 18:03 Tsiteeri
tegemist on juba 16 tollistega ja seda ruumi koopa äärte vahel enam ei olegi külgedel ..
peab lihtsalt auto madalamaks saama, see kompenseerib ;)
888
postitati 13.04.10 13:37 Tsiteeri
Algselt postitas: RKsilver
Lõika paar keerdu ära:D
Silverpm
postitati 13.04.10 19:59 Tsiteeri
Ei ole väga vedrude lõikaja. :P
Edit: Vahepeal käis närvidele tagumise juhipoolse õõtsapuksi krigin.. pooltelje määret vahele ja korras, puks ise healjuhul 2000km sõitnud.
sai uuritud ka mis asi taga kolksub.
diffripadi mis taga on, 1 poldiga, kinnitub silla külge..
Kuidagi see padi veel oli seal ning polt oli pooleks.
Tükk tegemist oli kuid sai polt tugevama vastu vahetatud ja asi korda tehtud.
Ideaalne ;)
Silverpm
postitati 11.05.10 20:49 Tsiteeri
Niisiis, mis vahepeal tominud on ka.. :
Pepu sai madalamaks.
Eintsil oli väga õigus, tegemist mingi esiveolise audi esivedrudega mis mul taha oli pandud.
Mõtlesin küll, et väga lõigata ei taha neid kuid sain ära lõigata peaaegu, et 2 keerdu ja sain sama natuke madalamaks pepu kui eelneval pildil on :)
Esistanget sai nüüd lihvitud, värvitud ja lakitud. vägagi kena jäi.
Esisuunatuled nagu ikka, sai ühele puruks suunakale mingi kile peale sulatatud / ehk kile soojaks ja siis suund sinna sisse panna.
Kile jahtus maha ja täpselt nagu korras suunatuli.
Ikka otsin lahendust, et miks tahab mul katuseluuk ise automaatselt kinni minna..
Vahetatud sai ka kütusefilter..peale mida läks käivitamine oluliselt paremaks.
Paar fotosüüdistust:
http://images.orkut.com/orkut/photos/OgAAAGsIyT1-Bqyf6MLV21WKz2ncZDsaY21B_PEVgjo9EvQ_ZdKmQRwalhSulPvVD1mBF_TyE8ZKJpZ8lTloAde2omMAm1T1UI-FZD7BFN_
http://images.orkut.com/orkut/photos/OgAAAD0G5oL5sM3PVG56th0ZA9zQVIXSFU4gtpNkm6txscpuMIxntyeEj3X1EdoDi80Qk655A-sMOtZKwJm-5DDbQz4Am1T1UG5n_lEuFjz
arsi
Registreerunud 09.02.06
postitati 12.05.10 06:36 Tsiteeri
Viska 100 avant tagumised vedrud ja amordid kogu täiega alla ja jääb väga hea :)
Tükk istub 1:1
888
postitati 12.05.10 19:29 Tsiteeri
Algselt postitas: arsi
Tükk istub 1:1
Sõber pani 200 avant vedrud alla ju pepu tõusis ikka päris kikki:D Ehk siis vana rullika tjuuning:P
Kenwood
Registreerunud 03.03.07
Auto: Audi V8 ; MB
postitati 12.05.10 22:14 Tsiteeri
Enda omal all 200 20v sedaani omad, kõrgus jäi samaks või törts langes.
Samas, head kokka tunneb sellest, et pann on tahmane.
Silverpm
postitati 15.05.10 14:23 Tsiteeri
Nii, vahepeal sai omale organiseeritud selline makk nagu audi Delta CC
Kuid kunagi kõrva või silma on jäänud õpetus kuidas üldse see koodi asi maha võtta ehk mingil prosel kohe kasseti mängija all mingid pinnid või lihtsalt jalg ära lõigata, siis ta koodi ei küsi..
Oskab keegi sellest midagi mainida ?
Kaits
Registreerunud 01.03.03
Auto: RS 6 Avant
postitati 15.05.10 16:16 Tsiteeri
http://www.ibiblio.org/tkan/audi/radios/deltacc.html
Silverpm
postitati 15.05.10 16:40 Tsiteeri
Algselt postitas: Kaits
Selle koodi sisestamisega pole mingit probleemi, kuid pole koodi mida sisestada.
Jürgen
Registreerunud 11.11.04
postitati 16.05.10 06:32 Tsiteeri
No sel juhul tekib mõningane küsimus raadio eelmise omaniku osas... Aga üldiselt on pahatihti kood kuskile korpuse peale kribatud vastavalt fantaasiale.
Silverpm
postitati 16.05.10 08:04 Tsiteeri
Vastavalt sellele, ostsin mina selle eelmise inimese käest kes oli selle omakorda eelmise omaniku käest saanud, ja tema omakorda eelmise.. ehk surnud ring.
Silverpm
postitati 03.06.10 18:10 Tsiteeri
Esiosa ka muutub vaikselt ..
http://images.orkut.com/orkut/photos/OgAAAIu8qob1hYnzQsmtV976P05e8vQDcloguaXyaCqWnPEx9KtGVXxfZ6vV_qeMqvUhqPat0IxVsxv7V776GySqdrsAm1T1UBAe1urMsyD
Silverpm
postitati 10.06.10 16:13 Tsiteeri
Ilusat suve Audide omanikud ! :) .
http://images.orkut.com/orkut/photos/OAAAAKwE03oyFL9KU3V8cSqZeVzUZDe3wlqL-5b0zaZauFp8CnOoz9QPspXmsMkR8qjC8YF6Dgcokp-4LoGogb0Y2QgAm1T1UBi-aWbUj4f
http://images.orkut.com/orkut/photos/OAAAAC2nMnL1FDf3mQfAphm90lCNbxsILMChAP67TabAhlBl9Bwe-i93eZ9ZKChCpLF2w2Ayq-fr9hZFaCs0eETVbz8Am1T1UHU7ycqS8z0
http://images.orkut.com/orkut/photos/OgAAABWPq3fdNNoIDOoMddi7su_d4XqfLT5UAMvh-PwxfUh4Ti5954HO5GctpFBqfSEWS--5a21lyYnkbstvMOFKr9EAm1T1UEVLK6rmN7F
http://images.orkut.com/orkut/photos/OAAAALr3SIqJos_9hja94nLYAGQaHFPnHgCUVU80M7_lGBemmJZZGQmr2UASIubM0fUMCLln6ARp-jJov27JzT73Hm8Am1T1UPS24jsuUn3
http://images.orkut.com/orkut/photos/OAAAALUfoGU4DSd2djNXa9Kf9oP_kgKHHhezu2VGrnjuqqI4SrXesSi9ImjC2XQe54TS1SLdUJvc5zSqJfm2nEWNKfQAm1T1UDtrOlOM8Gv
B.A
Registreerunud 10.09.09
postitati 10.06.10 21:07 Tsiteeri
Väga kena pill on! Jubedalt meeldivad V8:) Igati edu!
Silverpm
postitati 14.06.10 14:31 Tsiteeri
Nii, tehtud nüüdseks veel:
Juhipolne tahavaate peegel vahetatud, vana juba ussitas niipalju, et ei jaganud tahavaadates, et kas auto või veoauto :P
Ette pandud 2cm flntsid et veljed natukene väljapoole tuleksid, nüüd asi kenam..
Celtic
Registreerunud 24.05.09
Auto: BMW & FIAT/SEAT - CoDriver
postitati 24.06.10 20:20 Tsiteeri
Mõni uuem ja ilusam pilt Silveri V8'st siis.
http://i220.photobucket.com/albums/dd254/tipsitups/V8-4.jpg
http://i220.photobucket.com/albums/dd254/tipsitups/V8-3.jpg
http://i220.photobucket.com/albums/dd254/tipsitups/V8-2.jpg
http://i220.photobucket.com/albums/dd254/tipsitups/V8-1.jpg
Celtic;)
RWD viib külgees edasi.
arsi
postitati 14.07.10 18:22 Tsiteeri
Ka minu liikuril on jahutuse probleemid ( olid mõlemal ) ja ainus mis mul veel tegematta on , on visko vahetus .
Tekkis juba mõte panna kliima vent vägisi tööle ja kasutada vaid ECON reziimi.
Samas olen ka kaalunud selle visko vendi minemaviskamist suure kaarega ja elektri vendi paigaldamist , peaks parem saama .
Silverpm
postitati 14.07.10 18:32 Tsiteeri
Ise olen sama mõelnud, visko oli mul kutu kuid Eints-ilt sai see teine muretsetud juba talvepaiku.
Mis-maal sul tempi seier maanteel sõites istub ?
Mul istub ikka suht 100 peal koguaeg(kui see on keskmine kriips) ja õlitemp on teise valge kriipsu peal, esimene on vist koos selle numbriga 60.
arsi
postitati 14.07.10 19:42 Tsiteeri
pidevalt 100 juures ja kui linnasõit siis 110 ja peale .
Vana mootoriga sellist asja ei täheldanud aga probleemivaba polnud ka see .
Vahel olen ka eneserahustuseks soenduse põhja pannud ja aknad laiali kulgenud .
Kõige kummalisem on aga see, et kui kasutan kliimat siis temp tõuseb reipasti sinna 120 alla :mad:
Silverpm
postitati 14.07.10 19:53 Tsiteeri
Endal samamoodi, vana mootoriga oli nagu 90 peal koguaeg, just peale mootorivahetust tekkis probleem, ikkagi mingi õhutuse teema vast, räägi mulle sellist asja ka, et mis kiiruseni ta sul pihustid kinni hoiab kui mootoriga pidurdad?, ehk nagu tablool kütusekulu nulli viskab?
[PHP: 13.4% - SQL: 86.6%]
