Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Õlituli ei anna märku.
Pealkiri: Õlituli ei anna märku. (Vastuseid: 15 | Vaatamisi: 2874)
jansa1978
Registreerunud 03.10.09
Auto: audi a4 2,6 v6 110kw
postitati 18.10.10 19:45 Tsiteeri
Autoks Audi a4 v6,2,6 110 kw. Mure selline, et õlituli ei anna armatuuris märku kui õli vähe on. Kontrollisin eile õli ja selgus et varras läks otsast kergelt õliseks. Millest selline asi olla võiks ja äkki oskab keegi nõu anda selle probleemi lahendamiseks?
medical
Registreerunud 01.05.05
Auto: AAN
postitati 18.10.10 20:25 Tsiteeri
Õlitaset pead ikka varda pealt jälgima, kui tuli põlema läheb võib juba vähe hilja olla.
postitati 18.10.10 20:47 Tsiteeri
Kompuurtiga varjandil näitab ka madalat taset. Kui tavalised kellad on siis ei hakka enne midagi põlema kui õlirõhk 0 on.
postitati 09.09.15 19:54 Tsiteeri
Algselt postitas: automees6
Mul sama kala. Pandud sai kompuga uued kellad, ei näidanud mitte üht varianti..kui oleks pidanud C variant juba olema. Anduri vahetus? Või kellaploki vahetuse käigus midagi valesti läinud ikkagi?
http://foorum.audiclub.ee/viewthread.php?tid=94753
Selle juhise järgi täpselt tegutsetud ja plokk õige sama aasta om oli.
http://i19.photobucket.com/albums/b154/walky_talky20/Audi-Oil-Warnings.png
Andres89
Registreerunud 25.12.12
Auto: Audi A4
postitati 09.09.15 20:07 Tsiteeri
Õli märguandetuli võib jah liiga hilja märku anda. Ka minu A4-l hakkas siis põlema kui varras oli juba kuiv. Tegemist oli kompu kelladega.
postitati 09.09.15 20:14 Tsiteeri
Õlitasemeandur tuli alates 1999. aasta keskpaigast.
Enne seda oskab ka kompuuter ainult madalast õlirõhust (ja mitte tasemest) teada anda.
Eks sõltub mootorist, aga esimesena peaks see mõnes järsemas kurvis juhtuma, kui õlisurve hetkeks ära kaob.
postitati 12.07.16 19:22 Tsiteeri
Seega vanematel ölirõhuandur? Viimasel ölivahetusel meenus, keerasin süüte sisse kui mootor tilgatu oli ning ei hakanud midagi särama spidomeetri plokis.
TanelH.
Registreerunud 08.07.16
Auto: Audi A4 B5 1.8 92KW 20v ADR
postitati 13.07.16 07:52 Tsiteeri
Endal selline probleem Audi 80 b4 avandil, et õlirõhu tuli hakkas tööle ja piiksuma. Õlitase on normis. Mootoriks 2.0 85 kw. Probleem tekkis peale seda kui spidoplokil vahetasin trükkplaadi ja selle jubina, mis tahhoka taga on ja ploki üleval keskel seda märgutuld näitab. (Lisasin jubinast pildi :D ) Ise loodan et kala on selles. Ehk keegi targem oskab nõu anda.
https://www.upload.ee/image/5964961/spidopask1.jpg
postitati 13.07.16 12:58 Tsiteeri
Esimese asjana kontrolliks üle kõik ühendused ja võimalikud (tekkinud) külmjooted.
TiitR2
Registreerunud 21.07.04
postitati 13.07.16 14:06 Tsiteeri
Lamp/pirn ise ikka terve? :P ..eriti kui juba süüte sissekeeramisel ei põle.
Sry, see oli quattru jutule....
postitati 13.07.16 16:38 Tsiteeri
Algselt postitas: TiitR2
Ei ole pirn läbi, mul kompuutriga näidikuplokk.
Kunagi ammu olen näinud seda tulukest kui öli väheks jäi, enam ei ilmu.
TanelH.
postitati 14.07.16 14:09 Tsiteeri
Minu probleem sai lahenduse sellega, et vahetasin õli lihtsalt ära. Tuli läks sellepärast põlema, et uus spidoplokk oli lihtsalt terve ja vana oli surnud :D
postitati 14.07.16 19:22 Tsiteeri
Minul ajavad kõik näidikud plokis õiget asja. Öli vahetan kord aastas juba viimased 6 aastat. :P
TanelH.
postitati 15.07.16 06:59 Tsiteeri
Eile õhtu siis istun rooli ja vahi jah mis põlema läks jälle. Õlirõhu tuli. Kontrollisin siis õlitaset, normis. Võimalik et siis õlirõhu andur tujutseb?
Auto: 6x4x4
postitati 15.07.16 07:20 Tsiteeri
Algselt postitas: TanelH.
Andur väsinud, juhtmed ei anna ühendust või mootor hõre - õige vastus leia ise :).
TanelH.
postitati 15.07.16 11:59 Tsiteeri
Selge, tänud!
[PHP: 34.9% - SQL: 65.1%]
