Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Udu salongis
Pealkiri: Udu salongis (Vastuseid: 1 | Vaatamisi: 1168)
audi2.8
Registreerunud 01.12.05
Auto: Audi a4 2.8 quattro
postitati 02.12.05 19:43 Tsiteeri
Udu salongis
Kui ma juba abi sain küsin veel. Auto salong läheb uduseks. Just siis kui on niiske ilm. Jahutusvedelik ei kao. Vahetati ka välja mootor mis avab/suleb välisõhu. 2000 läks. Aga siin tuleb välja, et oleks saanud 12V korda teha. Siit moraal - ennem kui midagi ette võtad käi ära www.audiclub.ee lehel.
john
Registreerunud 07.01.03
postitati 02.12.05 19:51 Tsiteeri
http://foorum.audiclub.ee/viewthread.php?tid=18325#pid135664
http://foorum.audiclub.ee/viewthread.php?tid=17040#pid127404
http://foorum.audiclub.ee/viewthread.php?tid=3462#pid71685
Otsingusse kirjuta udu/uduseks jne ja vualaaaaaa..;) Edu ja loodan, et leiad mis vaja.
[PHP: 46.4% - SQL: 53.6%]
