Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2004 a8 d3 cd box ei tööta
Pealkiri: 2004 a8 d3 cd box ei tööta (Vastuseid: 4 | Vaatamisi: 1153)
roos666
Registreerunud 12.04.07
postitati 26.12.16 19:26 Tsiteeri
Ostsin hiljuti omale 2004.a. a8 ja cd box ei töödanud. Ei põlenud boxil ükski tuli ega töödanud ka nupud. Sai siis box välja võetud, et vaadata miks ei tööta ja avastasin, et pole juhtmed taha ühendatud. Ühe pistiku otsas oli mingi rõngas. Võtsin selle rõnga ära ja ühendasin juhtmed boxi taha, aga kui maki tööle panen siis ekraan tuleb aint välja, pole ei pilti ega häält, ainult taga hakkab midagi plõksuma. Kui boxi tagant juhtmed uuesti ära võtta ja ühe pistiku külge see rõngas tagasi panna hakkab jälle raadio ilusti tööle. Oskab äkki keegi mind selle probleemiga aidata. Milles viga võib olla ja kuhu peaksin selle asjaga pöörduma? Ette tänades.
postitati 26.12.16 19:47 Tsiteeri
Kui kaks pistikut on küljes ja midagi ei toimu, siis on box tõenäoliselt kutu.
Sellepärast on ka see rõngas pandud, et ülejäänud süsteem valguskaabli peal edasi töötaks. Ajutised lahendused muutuvad püsivaiks.
Teine box on vaja spetsiaalselt (konkreetse auto jaoks) esinduses aktiveerida, lihtsalt sisse pistmisest ja veakoodide kustutamisest ei ole üldiselt selle mudeli puhul abi.
roos666
postitati 26.12.16 19:49 Tsiteeri
Tänud vastuse eest. Eks peab siis uue boxi vaatama ja esinduses ära käima.
zack
Registreerunud 30.11.07
postitati 27.12.16 17:18 Tsiteeri
Lihtsalt mainin, et endale sai suvaline cd-box sisse lükatud ning toimib ilma nö aktiveerimiseta ka. :)
postitati 27.12.16 18:49 Tsiteeri
Algselt postitas: zack
Samas pole see esimene ega viimane selline juhtum. Aga millest see n-ö "vedamine" sõltub, seda ei oska hetkel öelda.
[PHP: 17.6% - SQL: 82.4%]
