Pealkiri: Audi A6 1,9TDI 81kw - 1997 - Audar (Vastuseid: 29 | Vaatamisi: 7809)
Audar
Registreerunud 22.11.12
Auto: Audi 80, A4, A6
postitati 03.09.16 18:18 Tsiteeri
Audi A6
Mootor: 1,9TDI 81kw
Käigukast: Manuaal
Esmane registreerimine: 1997a
Eestis esmane registreerimine 13.12.2012
Vin kood: WAUZZZ4BZWN032594
Reg märk: 942BHM
https://c8.staticflickr.com/9/8336/28808265903_329e4c7b7a_z.jpg
https://c3.staticflickr.com/9/8248/29395572466_4717fb3c47_z.jpg
https://c3.staticflickr.com/9/8524/28805840874_d7001708df_z.jpg
https://c8.staticflickr.com/8/7773/29429811335_76f53126e3_z.jpg
Sisust ka mõned pildid:
https://c8.staticflickr.com/9/8064/29429806455_9f797a22fa_z.jpg
https://c3.staticflickr.com/9/8796/29395552826_c5ab621564_z.jpg
https://c1.staticflickr.com/9/8024/28805821184_5944af1923_z.jpg
https://c2.staticflickr.com/9/8378/29350189001_0828ed8dee_z.jpg
https://c1.staticflickr.com/9/8053/29395539536_41e1a27a19_z.jpg
https://c3.staticflickr.com/8/7526/29395531426_47f70a3986_z.jpg
https://c5.staticflickr.com/9/8477/29141555860_3d0db66ef4_z.jpg
Kapotialt on muidugi jube tolmune:
https://c3.staticflickr.com/9/8356/29321720602_7e524cfb62_z.jpg
Õnneks pump kuiv:
https://c2.staticflickr.com/9/8554/28808261833_d6ba245d40_z.jpg
Serviseraamat ilusti täidetud.
https://c7.staticflickr.com/9/8644/29395531526_c3412e9ed1_z.jpg
Ostetud 25.06.1997
Servised:
16.01.1998 - 6000km
17.07.1998 - 15210km
31.12.1998 - 22235km
27.05.1999 - 30066km
04.10.1999 - 37726km
24.01.2000 - 42780km
17.07.2000 - 52300km
08.01.2001 - 60131km
06.06.2001 - 68020km
26.10.2001 - 75520km
11.03.2002 - 83000km
12.08.2002 - 90000km + Hammasrihma vahetus
10.02.2003 - 98000km
29.07.2003 - 105430km
09.03.2004 - 113500km
09.08.2004 - 120000km
14.03.2005 - 128000km
22.09.2005 - 135000km
10.07.2006 - 142995km
12.03.2007 - 150160km
06.08.2007 - 157000km
01.04.2008 - 165097km
19.12.2008 - 173480km
02.09.2009 - 182070km + Hammasrihma vahetus
23.09.2010 - 193310km
21.11.2011 - 209055km
Eestis alates 219000km odonäiduga. Eestis üks omanik, kes tõi selle ise Belgiast. Belgias oli samuti olnud üks omanik. Avariivaba. Kaasa sain naelrehvid plekkvelgedel Nokian Hakkapeliita 5.
Viimane õlivahetus on tehtud 234000 odonäidul. Paar tuhat siis veel muretu.
https://c6.staticflickr.com/9/8444/28808263173_ddfb9c7693_z.jpg
https://c7.staticflickr.com/9/8267/29142209110_349160fd8c_z.jpg
https://c1.staticflickr.com/9/8328/29322348032_8dd87cc934_z.jpg
Kuulutuse pildid ka:
https://c1.staticflickr.com/9/8380/28806595224_5afeec2a39_z.jpg
https://c6.staticflickr.com/9/8591/29350931501_4b3a2fb68d_z.jpg
Kulutused:
Auto hind - 3200€
Omanikuvahetus - 48€
Kindlustus aastaks - 37€
Paak täis - 36€
Kokku: 3321€
Kindlasti hakkan kütusekulu päevikut pidama. Paagi tankisin silmini täis juba 13km pärast ostuhetke.
Odonäit ostupäeval 3 sept. 2016a 242614km
Audi 80 1,9D 50kw http://images.spritmonitor.de/574424.png Audi A4 1,9TDI 81kw http://images.spritmonitor.de/761975.png Audi A6 1,9TDI 81kw http://images.spritmonitor.de/781237.png
mossejumal
Registreerunud 12.08.14
Auto: Audi A4 avant 1.9 tdi Quattro 81kw.Iz412ie.Iz2715ie
postitati 03.09.16 19:24 Tsiteeri
Hammasrihma komplekti soovitaks ära vahetada,juba 7 aastat .
Audar
postitati 04.09.16 13:00 Tsiteeri
Nii, esimene kütusekulu mõõtmine tehtud - 394km - 21,26L = 5,40L/100km
Maanteed rohkem, Tartus ja Võrus sai ka sõidetud omajagu. 80-ga töllajatest ja muudest umerdajatest sai ka raske jalaga mööda sõidetud, maanteel kuskil kerge sada+ gepsu.
Selle kliimaga ma sõbraks veel saanud pole, terve sõidu ajal ainult timmisin, ei oska siiani õiget seadet panna. Küll oli palav ja umbne, küll läks esiklaas uduseks, küll läksid tagumised küljeklaasid uduseks jne. Tavalistel autodel lihtne - keeran puhumise ette klaasi peale või nats tagasi + ventikas esimeses asendis ja siis timmin vajadusel sooja. Tehaseraamatust leidsin isegi pildi, kus sellel C5 kerel on ka selline variant olemas, kuigi ise ma pole kordagi kohanud.
https://c5.staticflickr.com/9/8309/29159548660_6b93bd1a29_z.jpg
Keegi äkki annaks nõu, kuidas seda kliimaautomaatikut enda autol peaks sättima? Mis kraad peale panna, kas "econ" nupp sees või mitte, kas "auto" või mitte, kas klaasile, keskele või jalgadele puhumine sisse panna või mitte? Väga keeruline ja kasutajavaenulik värk mu jaoks.
madtongue
Registreerunud 17.05.10
postitati 05.09.16 11:38 Tsiteeri
Kliimaga autol tegelikult just asi oluliselt lihtsam kui neil vändaga pillidel. Minu tavapärane valik on alati AUTO ehk auto sisekliima automaatne reguleerimine süsteemi enda poolt ja kraade 23. Kui sul on nii palav siis pane 22. Ja üldiselt ei olegi vajadust rohkem nuppe näppida. Kui, siis talvel klaasi sulatamiseks panna eraldi esiklaasile puhuma.
Kui sul klaasid uduseks lähevad, siis võib seal muid probleeme ka olla. Vt salongiõhu filter üle nt. Diagnost tasuks ka võimalusel teha, vbla siseõhuringluse klapiga mingi teema, need kipuvad lolliks minema ja suletud asendis tõmbab aknad kiirelt uduseks.
postitati 05.09.16 12:35 Tsiteeri
Soovitud temp. ette, AUTO sisse, (econit ei näpi üldse mitte kunagi) ja rohkem polegi vaja kliima peale mõelda.
Audar
postitati 05.09.16 15:18 Tsiteeri
Oot see "econit ei näpi kunagi" tähendab seda, et kliima pump on alati järel? Kui nuppu vajutada, läheb tuluke põlema ja see lülitab ju pumba järelt ära.
postitati 05.09.16 15:52 Tsiteeri
Miks peaks kliimapumba välja lülitama? Automaatika ju selleks ongi, et ta ise endamisi toimetaks.
postitati 05.09.16 16:17 Tsiteeri
Algselt postitas: Audar
Kui sa econi sisse lülitad, siis ei lüliti kliima pump enam sisse ning praeguste niiskete ilmadega on udused klaasid garanteeritud. Kui econ on välja lülitatud, siis süsteem ise lülitab vajadusel kliima pumba järgi, mitte ei tohiks see olla 24/7 järel siis.
audihunt
Registreerunud 12.08.07
Auto: Audi quattro
postitati 05.09.16 17:57 Tsiteeri
Kas sisu on hiljem lisatud ? Kummaline et 200 000 sõitnud C5 nahksisul on juhi istme nurk ära kulunud ja uus pandud.
postitati 05.09.16 19:19 Tsiteeri
Algselt postitas: audihunt
Mitu korda juba lugenud aga ei saa aru mis Sa nüüd öelda tahad? Sisu ju oki.
Kmerevits
Registreerunud 04.03.11
Auto: Audi
postitati 05.09.16 19:31 Tsiteeri
Juhi istmel on seal nurk vahetatud, ehk siis enne kui istme seljatugi lõppeb on tehtud õmblus. Originaalis seda seal olla ei tohiks ? Arvan, et ta mõtleb seda selle nurga vahetuse all.
Siim
Registreerunud 26.04.10
postitati 05.09.16 19:41 Tsiteeri
Kui silti uskuda siis õli on kaks aastat vahetamata (next oil change 2014 ja 234 000), soovitav minimaalselt kord aastas vahetada. Juhiistme küljetoel kortsud ja kulumine olematu, võrreldes ülejäänuga.
postitati 05.09.16 19:42 Tsiteeri
Ehk hakkas nahal värv lihtsalt kasvõi õrnalt vananemismärke näitama ja see häiris omanikku.
madtongue
postitati 07.09.16 10:14 Tsiteeri
Selle koha pealt kulub ikka suht kiirelt värv maha, eriti kui on pisut hooletum või korpulentsema kehaga kasutaja. Ja eriti kiiresti juhtub see heleda nahaga.
Mürr
Registreerunud 02.05.12
postitati 07.09.16 14:24 Tsiteeri
Kabe pill...aga eks vanust vaadates on hinda kaa.
Edu!
Audar
postitati 09.09.16 18:39 Tsiteeri
Maki luuk ei fikseerunud alumises asendis. Viga oli lihtne - fiksaatori tihvt oli oma pesas liiga sügavale läinud.
https://c1.staticflickr.com/9/8240/29533547856_d85cb19388_z.jpg
https://c3.staticflickr.com/9/8417/29533545626_973a72cc38_z.jpg
Raadiole on midagi kirjutatud. Keegi tõlgiks?
https://c1.staticflickr.com/8/7766/29533550216_8a0d03f505_z.jpg
Millalgi peab tegelema antennimajandusega. Eriti rohkem kui klassika, raadio 2 ja uno praegu see makk ei võta. Tegin veidike otsingut siin foorumis, päris metsikult oli teemasid Audide antenni ja selle võimendi mittetöötamise teemal.
Pagassis vaatasin originaal tööristakoti üle.
https://c6.staticflickr.com/9/8259/29567535725_b8fb2d7d9d_z.jpg
Mis selles aukudega ja krõpsuga kinnitatavas taskus võiks käia?
https://c8.staticflickr.com/9/8259/29567533695_5212a7fd57_z.jpg
Originaal Audi kirjadega koorma võrk ka olemas.
https://c2.staticflickr.com/9/8558/29487090321_1e0fe93097_z.jpg
Tellisin avaruosad.ee-st õli + filtrid ära ning vahetasin täna ära. Õlifilter oli metsikult kõvasti kinni. Spetsvõtmega keerasin lömmid sisse.
https://c3.staticflickr.com/9/8421/29533531706_5b3e369a1b_z.jpg
Kahjuks salongiõhu filter ei sobinud. Vana sai ajutiselt kompressoriga puhataks puhutud ja tagasi pandud.
https://c8.staticflickr.com/9/8246/29487085911_5d98d585c8_z.jpg
Veel tellisin tagaluugi amordid, kuna üks oli täiesti läbi, mitu inimest said luugiga vastu pead juba. Nüüd luuk tõuseb aeglaselt ise, kinni vajutada päris raske. Veel võtsin maha seestpoolt pagassiluugi katte, et vaadata miks üks tagumine udukas ei põle - kõrvalistuja pool polegi pirnipesa, vaid koht on. Timmisin luugiavamis lingi tundlikumaks, noh et ei võtaks link liiga põhjast, vaid kohe algusest.
https://c3.staticflickr.com/9/8143/29457868642_f59d58904a_z.jpg
Hinnad:
Õlifilter - 4,32€
Õhufilter - 5,16€
Kütusefilter - 6,86€
Õli Mobil Super 3000 X1 5w-40 5L - 29€
Tagaluugivedru 2tk - 12,84€
Saloniõhufilter - 3,45€ EI SOBINUD
Kokku: 61,63€
Õli + filtrite vahetus sai tehtud 9.09.2016 odonäidul 243155km
ahtisaar
Registreerunud 16.10.12
Auto: Audi q7 4.2tdi, Audi coupe 2.6
postitati 09.09.16 18:48 Tsiteeri
Selles krõpsuga kotikeses käib vargapoldi võti/padrun.
Audar
postitati 10.09.16 15:04 Tsiteeri
Värvisin mati veljevärviga kärukonksu ära.
https://c8.staticflickr.com/9/8068/28961068703_6e62f1d125_z.jpg
Kuna originaalrool mulle üldse ei meeldinud, sest oli emase pundunud välimusega, siis sai natuke kabedam rool ostetud täna. Maksin rooli eest 50€.
https://c3.staticflickr.com/9/8798/29294517370_a57a0b47d8_z.jpg
Audar
postitati 14.09.16 10:33 Tsiteeri
Paistab, et polegi antenni viga, sest proovisin praegust Blaupunkt makki A4-s, seal siis samuti raadio levi väga kehva. A4-s jälle mingi volkari kirjadega makk, millega ei tööta tagumised kõlarid, aga raadio võtab väga hästi. Proovisin viimast ka A6-s, seal ei hakanud see üldse tööle.
Nüüd oleks põhimõtteliselt vaja mõlemis makid välja vahetada (või teab keegi kuidas A4-s tagumised kõlarid tööle saada?)
Soovitage, mida asemele panna. Kas laiemat makki kannatab üldse ilma suurema ümberehituseta panna? Kas mingil vanakooli Gamma kassetikal see suur vol nupp võib luugile ette jääda? Tegelt piisaks, et vaid raadio oleks hea. Kellelgi äkki vedeleb midagi odavalt või aitähh eest?
https://c7.staticflickr.com/9/8423/29637698006_c5f27a1cac_z.jpg
AndresL
Registreerunud 30.07.10
Auto: Audi A6 C5 2.5TDI 132kw. Quattro 2003
postitati 14.09.16 18:18 Tsiteeri
See kliimaautomaatik ongi tegelikult mingi hälvik süsteem. Ma samuti vihkan seda, hommikul lööd kraadid sisse ja siis kukub puhuma lampi nii, et ei kuule raadiotki. Eelmine auto saigi ostetud puhtalt tavalise kondiga, et saaks ise nuppe keerata ja ei toimetaks omaette. Nüüd taas kliimaautomaatik ja ikka vigane süsteem see. B5 pre FL õnneks vaid üks koht kus saab sättida. FL variandil ja C5 peab kahte kohta sättima, et saada asi vaikseks Sama asi oli ka mul E38-as. Ise eelistan samuti pliidinuppe igakell rohkem. Hea lihtne asutada ja ei pane villast kui hommikul kukub kohe jubedalt puhuma kuskile suunas.
Siim
postitati 14.09.16 18:38 Tsiteeri
Puhub tugevasti, sest kliima üritab võimalikult kiiresti saavutada sätitud temperatuuri. Vajutad AUTO, paned puhuri 2-3 pulka ja ongi hästi, temperatuuri hoidmise ja kliima rakendab automaatselt aga puhuri pööretega enam edaspidi ei mängi.
Audar
postitati 15.09.16 05:02 Tsiteeri
Kui ma Auto peal hakkan ventikat timmima, kustub ju esimese vajutuse peale Auto tuli ära. Päris nii lihtne ikka pole, et panen auto ja 22 või 23 kraadi peale ja asi korras. Kui päike ikka sisse paistab, on alguses palav ja tuleb temperatuuri külmemaks timmida või on tagumistel umbne jne.
Oot kas keegi üldse on kunagi näinud või on omanud seda "pliidinuppudega" c5 Audit? See vist sama haruldane, umbes nagu on manuaalkastiga w140 mersu.
Seda kaasas olevat raamatut sirvides tundus imelik, et ühtegi pilti pole universaali teemal. Nüüd sain teada, et universaali ei olnudki veel 1997 aastal, tuli alles 1998.
Ostsin odavalt siitsamast foorumist ühe vana gamma maki, eks katsetab ära, kas mu auto antenn ikka korras. Peaks homme kätte saama.
Siim
postitati 15.09.16 08:27 Tsiteeri
Sealt kustub jah auto ära aga puhumise avad, temp ja kliima rakendumine jääb ikkagi automaatseks. Kui tempi ja puhumise suunda muudad siis läheb kõik manuaalseks. Täis automaatne (22 c ja vajutad auto), pool automaatne (valid puhumise tugevuse, midagi muud ei näpi, seda teeb automaatika) ja manuaalne (tugevus, avad, helbeke). 35c kuuma kabiini jahutades puhub kliima sama külma olgu seal näidikul 22 või 25, 22c puhub kauem, et saavutada seda temp.
Audar
postitati 29.04.17 04:45 Tsiteeri
Teemaks olev auto seisis mul terve talve, soolaga ei sõitnud kordagi. Sai vaid käivitatud mõne nädala tagant. Ükskord pikema vahe korral oli akul käivituseks jaks otsa saanud. Veel tõmbas peale seismist geneka, sisselaske jm alumiiniumdetailid pealt oksiidiseks, muid tagasilööke polnud.
Nüüd jälle auto kasutuses.
Sain tuttavalt Audi originaal 16" ümarate aukudega 4B0601025P koodiga veljed, 3tk praktiliselt tutikad! Nüüd oleks ühte veel vaja, siis vahetaks need all olevad 15" originaalid välja. Ega kellelgi ei vedele sellist üksikut? Varurattana näiteks. Peaks olema ikka päris uus või vähemalt täiesti kriimu ja oksiidivaba originaalvärviga. Siis saaksin jooksu kokku ja ostaks tutikad rehvid alla.
https://c1.staticflickr.com/5/4188/33522102003_123fa44dd4_z.jpg
Kapslid ka mul puudu, aga need tellisin eile eBayst 9,31€ eest.
edit. Kõik neli velge olemas (tegelikult isegi 5).
dislapann
Registreerunud 19.06.13
Auto: Audi A4 Avant 1.9TDi 2003; Audi A6 Avant 1.9TDi 2004
postitati 04.05.17 21:30 Tsiteeri
Lihtsalt uudishimust uurin, et miks see seisva auto käivitamine vajalik on? Mul naine ka talvel ei sõida - novembris jäi auto seisma ja nüüd paar päeva tagasi panin peale poolt aastat seismist käima. Läks poolest pöördest nagu oleks eile seisma jäänud. Tegu samuti 1.9 tdi-ga.
[PHP: 27.9% - SQL: 72.1%]
