Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A6 3,0 2005 a
Pealkiri: A6 3,0 2005 a (Vastuseid: 19 | Vaatamisi: 2316)
Pettu9
Registreerunud 02.04.11
Auto: Audi A6 avant 3,0
postitati 02.04.11 14:25 Tsiteeri
A6 3,0 2005 a
Plaan endale lähiajal soetada 2005 või 2006 A6 avant 3,0. Millise käigukastiga soovitaksite ja mis antud mudeli +; -
postitati 02.04.11 14:47 Tsiteeri
Pluss on see, et A6 3.0TDI'd on kõik ka quattro'd.
Miinuseks, et manuaali on tõenäoliselt raske leida. Mitte küll võimatu, aga hakkab valikut oluliselt piirama.
waic
Registreerunud 16.05.05
Auto: Allroad 3.0 + A5 sportback 3.0
postitati 02.04.11 16:05 Tsiteeri
See kasti teema on väga suhteline, isiklikult seda küll puuduseks ei loe..
Joel
Registreerunud 01.10.02
postitati 02.04.11 16:35 Tsiteeri
Naljakas küsimus, mis kastiga soovitada. Nagu eelpool öeldud on manuaaliga neid ülikeeruline leida. Mis minu arvates on ka täiesti normaalne, sest A6-suguse suure ja laisa laeva jaoks ongi automaat õigem. Eriti veel diiselmootori puhul, mis nagunii pöördesse ei käi ja sportlikku sõidustiili kuidagi ei toeta.
audi121
Registreerunud 30.09.09
Auto: a6 2004 3.0 tdi
postitati 02.04.11 18:07 Tsiteeri
Algselt postitas: Joel
Minu arust läheb 3.0 tdi väga hästi põõrdesse.
Robinson
Registreerunud 05.09.03
postitati 02.04.11 18:21 Tsiteeri
Algselt postitas: audi121
Vahelduseks võiks sellele pilgu peale visata.
http://www.youtube.com/watch?v=7Zq0I6_3q2o
postitati 02.04.11 18:25 Tsiteeri
Algselt postitas: Robinson
http://www.youtube.com/watch?v=gzULo8-jTV0
Kommentaare pole vist vaja.
heihei
Registreerunud 01.02.06
Auto: b6, 96kw bens.
postitati 02.04.11 18:31 Tsiteeri
Vaatasin videot, kena minek , aga Led tuled on ikka käkerdis küll, seda näha videoski.
Maku
postitati 02.04.11 18:47 Tsiteeri
Olles kokku puutunud mitme c6 kolmese diisliga, ei saa ma Joeliga nõustuda. Esiteks ei ole tegemist laisa autoga ja teiseks ei saa kolmese diisli pöördesse mineku kohta midagi halba öelda. Laisaks võib kutsuda mõnda ameeriklast või näiteks c4-a aga kindlasti mitte c6-e. Ka iseendale üllatuseks aastaid tagasi tõdesin, millised kardid ja olematu müraisolatsiooniga autod need on. Ja muideks, Audi kolmesel diislil on chippides ca 600nm alla kahe tuhande pöörde.
siLc
Registreerunud 05.06.10
Auto: 2011 VW Passat EcoFuel
postitati 03.04.11 05:45 Tsiteeri
Algselt postitas: prj
See 3.0TFSI on ju bensukas, mitte TDI :)
heihei
postitati 03.04.11 06:09 Tsiteeri
Praegu 3,o siis a4 kere peal manuaalina saada, kui huvi?
http://www.auto24.ee/used/769037
veekaheksa
Registreerunud 07.09.03
Auto: A4 TDI quattro, S8 40V
postitati 03.04.11 07:26 Tsiteeri
Manuaalil on kiirendus- ja kütusekulu näitajad pea 5% paremad kui automaadil. Samas - mugavuse erinevus on suurem kui see 5%, ma arvan. Nüüd see oleneb juba sinust, mida sa eelistad ja väärtustad rohkem. Käigukasti hoolduse ja remondikulud on umbes samapalju kallimad automaadil, kui palju automaat on mugavam sõita.
Valik on sinu :P
Maku
postitati 03.04.11 08:18 Tsiteeri
Algselt postitas: veekaheksa
Pigem on manuaali parem kiirendus tingitud launchimise võimalusest, mida teatavasti esineb väga vähestel automaatkastidel. Ja noh, omada manuaalkasti ainult sellepärast, et kaks korda aastas tunda 5000rpm starti, samas, kui teine mees sõidab iga kord foori tagant ilma igasuguse pingutuseta minema (effortless ride), pole ka just mõistlik.
postitati 03.04.11 08:57 Tsiteeri
Kui kasti valiku teemadel rääkida, siis tarbeautona kasutatav A6 võiks ju tänapäeval tõesti automaadiga olla. Robinsoni viidatud video kaheukselises sportlikuma suunitlusega A5-s tahaks mina aga mootorist olenemata vaid manuaali näha. Just nimelt ehedat manuaali, mitte käsitsi lülitamise võimalusega automaati. Eks ta selline maitse asi ole, milles on kõrvalt raske nõu anda.
Eile veel oli pealkirjas ja/või esimeses postis TDI ka mainitud, selle eemaldas teema algataja või keegi teine? See ju muudab kogu teema olemust. Edit: algataja viimast sisselogimisaega vaadates vist mitte tema.
postitati 03.04.11 09:34 Tsiteeri
Algselt postitas: Black
TDI võis keegi ju pealkirjast eemaldada, aga küllap ta unustas, et 2005. ja 2006.a. ehk prefacelift C6'l 3.0 bensukat (TFSI) ei eksisteerinud :D
postitati 03.04.11 10:08 Tsiteeri
Mõni aasta oli 3-se bensukaga auk sees jah, siis tuli jälle. Samas ma mäletan, et sinu eilne diislit eeldav vastus algsele postile näis nii loomulik, et ma ei hakanud seda enda jaoks üle kontrollima. Mäletan ka, et teema algataja oleks justkui ikkagi konkreetselt diisli kohta küsinud. Samas võibolla ikkagi luulud, mälu ei ole enam see, mis kunagi. :P
juks11
postitati 03.04.11 10:27 Tsiteeri
Samas on ka olemas C6 kerel tavaline 3,0 bensukas, seesama rihmaga mootor mis on ka C5'el peal.
Olen oma silmaga näinud!
Joel
postitati 03.04.11 18:02 Tsiteeri
Algselt postitas: Maku
Mul on sellesama 3,0 TDi 165kW mootoriga Touareg. Touaregi aju on seadistatud madalamalt vedama kui A6, ehk see ei ole päris 1:1 võrreldav. Kuid ega A6 selles osas nüüd ülemäära teistsugune ka ole - "magus ala" on ikkagi vaid umbes 2000 pööret lai ja üleval otsas kukub jõud ära. Diisel nagu ikka diisel. Ma ei näe mingit põhjust sellise mootori otsa manuaalkasti panna. Isegi A5 puhul mitte. Aga eks see ole minu probleem... :)
Maku
postitati 03.04.11 19:28 Tsiteeri
Nõus.
cesar
Registreerunud 05.05.04
Auto: A4 B8 TFSI
postitati 03.04.11 19:33 Tsiteeri
Algselt postitas: juks11
On tõesti. Neid on toodetud arenevate riikidele. (Venemaa)
[PHP: 18.0% - SQL: 82.0%]
