Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - ohutulelüliti.
Pealkiri: ohutulelüliti. (Vastuseid: 7 | Vaatamisi: 1211)
sander1990
Registreerunud 30.07.10
Auto: Audi A6
postitati 20.10.10 20:24 Tsiteeri
ohutulelüliti.
probleem selles siis et a6 ohutuletule lüliti jääb plõksima peale suuna näitamist, sai uus lüliti ostetud ja ära vahetatud aga ikka plõksib edasi, et milles võiks probleem seisneda?
postitati 21.10.10 05:38 Tsiteeri
Kui Sa vahetasid punase nupuga ohutuledelüliti juba ära, siis on viga tõenäoliselt suunatulekangis.
Jürgen
Registreerunud 11.11.04
postitati 21.10.10 06:20 Tsiteeri
Jälle üks müügimeeste ohver :)
Kui suunatule relee jääb plõgisema peale suuna välja võtmist, siis 95% on viga kangis, mitte relees.
Enne rahakoti tuulutamist on soovitav siiski korraks tester järgi panna ja mõõta takistust paremal ja vasakul kanalil vastu keret - embkumb läheneb mingi intervalliga nullile.
Lehekülje all antud kangi kasutavatest mudelite loetelu, aga SWAG (ja üldse b-osa) toodet ise ei soovita. Võrreldes originaaliga on ikka välimus ja kvaliteet juba peale vaadates küsitava väärtusega, ei sisalda usku ka töökindlusele.
PS! Kui kellelgi kang välja vahetatud ja vana poolpidune üle, siis ma olen lahkelt nõus selle omandama :D - tahaks natuke lammutada ja enese harimise eesmärgil sisu uurida.
PS2! Auto mudel ja aastakäik oleks alati abiks foorumis vigade defekteerimisel.
rat_013
Registreerunud 07.03.03
Auto: 3.0q
postitati 21.10.10 06:51 Tsiteeri
Kiidan ka siis takka - endalgi kang vahetatud :)
Ma olin õnneks piisavalt tark et algselt releed ostma minnes proovisin kohe kohapeal järgi ka :cool:
Vaata kasutaja profiili Saada kasutajale e-mail Külasta kasutaja kodulehte Saada kasutajale U2U Skype
sander1990
Auto: Audi A6
postitati 21.10.10 07:31 Tsiteeri
niiet sain siis 600 eek vastu pükse juba :)
ega seal kangi kallal ple ka ju muud teha , kui uus ära osta ja see on siis terve kobakas mis roolisamba ümber on, et seda vast eraldi lahata ega osta ei saa eks ?
postitati 21.10.10 08:06 Tsiteeri
Algselt postitas: sander1990
... see on siis terve kobakas mis roolisamba ümber on, et seda vast eraldi lahata ega osta ei saa eks ?
See kobakas käib keskelt pooleks- kojameeste kang ehk roolist paremale jääv osa jääb vana.
rat_013
Auto: 3.0q
postitati 21.10.10 08:12 Tsiteeri
Sulle anti isegi link kust osta saab :)
Ja proovi lauseid suurte tähtedega alustada ikka, muidu tulevad moderaatorid su säärekonte kohe närima :D
MorpheusS
Registreerunud 03.07.07
Auto: Audi A6 1.8T Quattro C5
postitati 21.10.10 08:41 Tsiteeri
Kui huvi on, siis mul on üks täitsa töökorras suunatulede kang üle. Võta ühendust, ehk saab kaubale :)
Kuhu... Kuhu... Kuhu ma olen küll sattunud???
[PHP: 46.1% - SQL: 53.9%]
