Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A4 2.4 spidokaplokk
Pealkiri: Audi A4 2.4 spidokaplokk (Vastuseid: 6 | Vaatamisi: 1017)
DjTann17
postitusõiguseta huviline
Registreerunud 30.08.10
postitati 30.08.10 23:15 Tsiteeri
selline küsimus,et kus kohast saab audile hea hinnaga tervet spidoka plokki??auto kiirust ei näita..kütuse näidik ka jebib oma suvajärgi..oleks hea kui saaks selle kiirelt ära vahetada..
Audi A4 Avant 2.4 QUATTRO 1998
Selline küsimus, et kuskohast saab Audile hea hinnaga tervet spidokaplokki? Auto kiirust ei näita. Kütusenäidik ka jebib oma suva järgi. Oleks hea, kui saaks selle kiirelt ära vahetada.
Audi A4 Avant 2.4 QUATTRO 1998.
A-kaheksa
Registreerunud 23.11.07
Auto: A6 C6 4,2Q, Mondeo 11
postitati 31.08.10 05:07 Tsiteeri
Romulast, aga enne otsi endale üks pädev mees, kes selle su autoga kokku progeb, et auto ka käima läheks. Mis firma toodangsee mittetöötav kelladeplokk on?
www.harteron.ee
DjTann17
postitati 01.09.10 17:58 Tsiteeri
audi spidomeeter
Märkus moderaatorilt: "Postitus kustutatud, kuna kasutaja ei ole vaatamata varasemale märkusele asunud järgima foorumi reeglite 3. punkti! Järgmine samm on kasutaja postitusõiguse tühistamine!"
marks2484
Registreerunud 02.04.10
postitati 01.09.10 17:59 Tsiteeri
Mul ka selline probleem on aga mul ei tööta ka püsikiiruse hoidja ja täheldanud ka et kui gaasi sujuvalt lahti ei lase teeb jõnksu kohe ennem nii ei teinud. Mind aga huvitaks kus seda remontida saaks`? Tartus mul pakuti et võib minna 800-1500 kr aga nad ei osanud ka täpselt öelda et äkki mõni joode lahti vmt. On kellelgi veel sellist jama olnud ja huvitaks mis siis seda põhjustas?
DjTann17
postitati 02.09.10 11:20 Tsiteeri
ahjaaa...püsikiiruse hoidja mul töötab..aga mõte oligi,et kui vahetaks skeemid millegi teise vastu ära??kas see võiks töötada?sai proovitud ka mingit inglise oma kus olid millid,aga jh..korra läheb käima ja siis suren kohe välja..ei jää püsima..uus "kellade" plokk maksab 6000-10500.- see oli audi esinduses..diagnostika mitte midagi ei näita,et oleks midagi puud või katki..aru ma ei saa mis teema sellega on
Märkus moderaatorilt: "Kuna kasutaja ei ole vaatamata varasematele märkustele asunud järgima foorumi reeglite 3. punkti, on kasutaja postitusõigus tühistatud!"
A-kaheksa
postitati 02.09.10 16:30 Tsiteeri
Minu esimeses postituses oli sinu jaoks kõik vajalik info juba olemas. Oleks sa seda hoolikalt lugenud, siis saaksid aru. Nüüd kahjuks sa enam vastata siin ei saa.
Probleem selles ongi, et romula kelladega sa oma autot käima ei saa (kuigi keegi siin foorumis väitis, et suudab seda tööle progeda). Kui su kelladeplokk on toodetud Jaegeri või Marelli poolt, siis ehk annab olemasoleva korda teha. Kui VDO toodetud, siis veidi keerulisem.
Ei usu, et esinduses maksab kellade plokk 6000-10500.-. Viimati kui pärisin, siis oli hind 18000.- Aga mine tea, ehk on hinnad oluliselt langenud.
www.harteron.ee
marks2484
postitati 09.09.10 19:03 Tsiteeri
tere
ma sain oma murest jagu. Asi oli suht lihtne käigukasti peal oli kiirus andur, mis oli märjaks saanud sai teine puhastatud ja nüüd töötab ilusti loodan et kellelgi abi sellest
[PHP: 46.9% - SQL: 53.1%]
