Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K: millised rehvid???
Pealkiri: K: millised rehvid??? (Vastuseid: 4 | Vaatamisi: 1991)
yksMees
Registreerunud 03.08.06
Auto: A4 avant s-line 3.0TDI quattro B9 (315TLW)
postitati 12.09.06 20:05 Tsiteeri
millised rehvid peaks olema tehase poolt mõeldus s4 1992a. ja kuidas on lood sellega et kõik neli peavad olema ühte mõõtu, mustriga ja ühe firma toodang. või ei olene rehvide laius et siis ees n. 225/40/r18 taga 235/40/r18 oluline.
vabandage seda lolli küsimust aga ma alles algaja.
Auto: 6x4x4
postitati 12.09.06 21:59 Tsiteeri
haakuv teema
yksMees
postitati 15.09.06 06:50 Tsiteeri
aga mis mõõdus on tehase poolt ette nähtud
tanel
Registreerunud 09.07.03
Auto: Audi A4 Avant
postitati 15.09.06 07:08 Tsiteeri
Algselt postitas: yksMees
Vaata bensiinipaagi luugi siseküljelt, seal peaks olema kleeps kus on kirjas erinevate tollidega (kui ei eksi siis 15, 16 ja 17)ja mis möödus rehvidega sõita, ning kui täis rehvid peavad olema ning millise oktaanarvuga bensiiniga sõita. Vähemalt minu omal on selline kleeps.
MaQQu
Registreerunud 15.12.02
postitati 15.09.06 07:09 Tsiteeri
vaata bensiiniluugilt.
215/60/15 oli 1 mõõt, mis tehase poolt soovitatav
SIIT saad kontrollida, mis mõõdud veel sobiksid.
ehk siis 18" puhul on sobivad
225/40/18
235/40/18
Ja mõlemal teljel peavad olema sama mõõtu rehvid (parim oleks ka üks muster ja kulumisaste) !
[PHP: 16.2% - SQL: 83.8%]
