Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Deprecated: Implicit conversion from float 508318.99999999994 to int loses precision in /data01/virt4271/domeenid/www.audiclub.ee/foorum/viewthread.php on line 181
Eesti Audi Klubi foorum - Kus asub audi 80 termostaat?
Pealkiri: Kus asub audi 80 termostaat? (Vastuseid: 11 | Vaatamisi: 2793)
mt
Registreerunud 16.12.03
Auto: Audi 80 Avant 94
postitati 17.01.06 11:54 Tsiteeri
Foorumites on palju juttu termostaatidest kuid audi 80 kohapealt ei leidnud ma termostaadi asukoha ja vahetuse osas kuigi palju.
Niaplju sain küll targemaks, et termostaat on kinni kiilunud ja ei lase jahutusvedelikku jahtuma - ehk 5 min saab auto ajada keega.
Kas 91 a audi 80 l asub termostaat mootori üleval servas kust väljuvad torud (üks toru läheb radika ülesse äärde)? Või veel parem, kust oleks võimalik leida joonist termostaadi paiknemise kohta? Ja kuidas seda vahetada saab?
-markus-
Registreerunud 28.03.05
Auto: A4 B6 Avant
postitati 17.01.06 12:03 Tsiteeri
Veepumba alumise lõdviku otsa juures. Keerad kahe poldiga lõdviku lahti, natuke jahutusvedelikku tuleb välja, vahetad termostaadi ja üks-kaks tihendit ära, paned kokku tagasi, lisad piisavalt uut jahutusvedelikku ja valmis.;)
Edit: see siis 66kW mootori kohta.
postitati 17.01.06 12:14 Tsiteeri
Algselt postitas: mt
'91 Audi 80 peale pandi 1.6 - 2.8 mootoreid ja termostaadi asukoht sõltub ikka mootorist, mitte kerest. Nii et räägi, mis mootor sul seal on?
mt
postitati 17.01.06 12:38 Tsiteeri
Mootor on
Ja mootor on 1,8 ja 66 kw.
ZharpV6
Registreerunud 27.12.05
Auto: Audi 80 B4 Avant 2,6
postitati 17.01.06 13:19 Tsiteeri
Ei hakka uut teemat tegema ja küsin siinsamas. Kus asub Audi 80 B4 1993 V6 2,6l termostaat? Käisin just töökojas ja tüübid ei leidnudki üles. :( Tänud igasuguse abi eest!
Edit: Helistasin just Catwees'i ja öeldi et hammasrihma taga? On see õige? :) Ja äkki keegi Pärnu inimene oskab head töökoda vahetamiseks soovitada? Catwees's 410 kr/h ja arvasid et tööd 3 tunni jagu. Natu karm. :P
undu
Registreerunud 05.08.05
Auto: Outback´13, Gaz 2410
postitati 17.01.06 13:49 Tsiteeri
Algselt postitas: -markus-
Nii on see kõigil selle aegsetel 4sil motodel , 5sil kohta ei tea kindlalt väita
errkk108
Registreerunud 14.06.05
postitati 17.01.06 16:43 Tsiteeri
Algselt postitas: ZharpV6
on jah rihma taga krt, väga lolli kohapeal on see! ise sai ka just ära vahetatud.
postitati 17.01.06 22:21 Tsiteeri
Polegi vaja uut teemat teha, otsing aitab 99% juhtudest. ;)
http://foorum.audiclub.ee/viewthread.php?tid=15813
kuusk623
Registreerunud 02.11.03
Auto: Audi 100 C4 avant
postitati 18.01.06 05:46 Tsiteeri
Tere
Põhimõtteliselt saad siid lehelt oma termostaadi asukohaga joonise üles otsida. Jõudu ...
http://etka.auto2.ru/?lang=eng
symbo
Registreerunud 29.05.05
Auto: Audi 80 B3 ja Audi 100 2,3 R5
postitati 21.01.06 15:56 Tsiteeri
Termostaat
Minul ka termostaadiga probleem,tahaks teise ära vahetada aga üles ei leia.Oskab keegi öelda kus see asub?Autoks Audi80 B3. Riputan siia pildi ka,et asi selgem oleks.Ette tänades.http://www.pilt.ee/picture.php?album_id=427146&picture_id=17131745
mt
postitati 31.01.06 14:00 Tsiteeri
Aitäh abi eest.
Vidin vahetatud ja auto jalle töökorras. Millegipärast kõik väitsid, et termostaat saab ainult lahti jääda aga mitte kinni minna kuid siiski sai. Liska veel ka kogemus, et kui autol on roolivõim siis ise seda termostati kodusta vahenditega kätte ei saa.
rakulka
Registreerunud 13.01.06
Auto: A4 1.8 Avant
postitati 07.02.06 12:17 Tsiteeri
teema algataja auto puhul siis puust ja punaselt ...
Audi 80 termostaat
http://www.zone.ee/rgnr/termostaat.png
[PHP: 49.2% - SQL: 50.8%]
