Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A6 1,8t 98a süüteluku vahetuse probleem ,palun abi !
Pealkiri: Audi A6 1,8t 98a süüteluku vahetuse probleem ,palun abi ! (Vastuseid: 3 | Vaatamisi: 2099)
HenriE
Registreerunud 13.12.18
postitati 13.12.18 09:17 Tsiteeri
Tere ,sai soetatud pruudile esimeseks autoks c5 kerega a6 1,8turbo ja väljalaske aasta on 98. Juhtus siis selline lugu et läks katki süütelukk. Luku vahetasin ära ja vana süütevõtme küljest võtsin selle puldi osa kus on nupud siis uue võtme külge. Nüüd on probleem, et kellaplokis vilgub kollane võtme tuli ja auto korra käivitub ja siis mõne sekundi pärast sureb välja . Eelnevalt foorumit lugedes sai selgeks süütelukul oleva immorõngal teinekord pistik jamab et siis ka samalaadne viga ,et äkki ikka alustaks pistikust ?. Või selles et kas peab vahetama ka vana ja uue süütelukku immorõngad omavahel ringi ? Kuna youtubes vaadates oli see suhteliselt keeruline töö ,miskine pikk peenike ora ,mis.läheb luku sisse jne :(
Tänud ette vastajatele !
postitati 13.12.18 09:23 Tsiteeri
Ringi tuleks vahetada mitte ainult nuppude, vaid kogu plastmassist osa.
Plastmassist osa eesotsa (ja mitte nupuosa) sisse ongi paigutatud immopulk, mida rõngas loeb!
postitati 13.12.18 09:35 Tsiteeri
Aitamaks mõista, mida rocket kirjutas:
(Pildil on küll VW võti, mis on õige pisut erinev, aga üldine ehitus on sama.)
https://www.myturbodiesel.com/images/a4/vwkeydis.jpg
Sisuliselt peaksid sa uuelt võtmelt võtma ainult "key blade" (selle saad kätte, kui eemaldad "cam" seest "pin", sellisel juhul ei pea kogu pulti laiali lammutama) ja kõik muu jääb vana.
http://oi66.photobucket.com/albums/h279/mark1vws/ebay%20photos/flipkeyapartcaptioned2.jpg
HenriE
postitati 13.12.18 10:31 Tsiteeri
Suured suured tänud audimehed !!!;) Nii kui koju jõuan lähen võtit tuunima :)
[PHP: 28.8% - SQL: 71.2%]
