Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Roolivõimu pump undab!!! HELP!!!
Pealkiri: Roolivõimu pump undab!!! HELP!!! (Vastuseid: 8 | Vaatamisi: 2888)
john
Registreerunud 07.01.03
postitati 07.07.05 17:41 Tsiteeri
Probleem 1.
Audi roolivõimupump hakkas yhel hea hetkel undama ja siis ajas laksust õli välja. Päev otsa sai nii sõidetud aga õhtul otsustasin võimul rihma maha võtta.
Kysimus: Kas ma oleks pidanud kohe rihma maha võtma? Kas on võimalik, et see lõhub ka lati ära või teeb sellele viga.
Probleem 2.
Vahetasin täna roolivõimupumba ära aga see hakkas ka ilgemalt undma ja läks jõle kiiresti kuumaks. Ohutuse mõttes kiskusin kohe rihma maha. Ja nyyd ei oska midagi teha. Kui uue võimu ära vahetasin siis valasin sinna sisse tsirka 1.5L roolivõimu õli :P mis mulle eriti muret tekitas, kuna vahetades ei tulnud mitte kuskilt tilkagi.
Probleem 3.
Võim on vahetatud aga kasutegur on "null" kuna, kui rihma peale panen siis hakkab see neetud võim undama :P Kuhu ma nyyd põõrdun ja mida ma peaks tegema!?
PS! Kas keegi oskab seletada mida tuleb täpselt teha roolivõimu pumba vahetusel :P
john
postitati 08.07.05 09:50 Tsiteeri
vajaks kiiret lahendust... käed väsivad ära :D
ACE16V
Registreerunud 12.03.03
Auto: Audi80AvantQuattro / DUCATI_M900
postitati 08.07.05 14:24 Tsiteeri
Käte väsimise vastu aitab see, kui lased roolikarbist õli välja.
Kunagi B3-ga sai niimoodi aasta aega sõidetud, enne kui uue(loe kasutatud) pumba sain. Ja seda sportrooliga.
Süsteemile see mingeid tüsistusi ei tekitanud. Peale pumba installi olen sõinud ca 5...6 aastat.
john
postitati 08.07.05 17:27 Tsiteeri
Aga mõni remondimees ei oska sõna võtta kuidas peaks käituma pumba vahetusel!? Mida teha ja mida peaks jälgima.
Käteväsimise vastu pole erilist enam midagi, hakkan juba igapäevase trenniga hartjuma :D
john
postitati 26.07.05 19:05 Tsiteeri
teema ikka päevakohane.
Ostsin siis tõõtava pumba. Vahepeal on ka latt vahetatud. Aga ikkagi sama teema. Pump hakkab kohe undama ja läheb väga kiiresti kuumaks. Millest võib see tingitud olla!?
jõuvanker
Registreerunud 21.03.03
postitati 26.07.05 19:16 Tsiteeri
TTÜ ja vene keelt kõnelev vanamees aitab. tel 55 150 20
john
postitati 26.07.05 20:38 Tsiteeri
Paar tarka inimest ytlesid et asi võib olla ka õlis. Hetkel kasutan ATF punast õli aga mulle mainiti et roheline võimuvedelik on palju vedelam ja palju parem,ning audid kasutavad seda...
Aga eelmine omanik ei ole seda õli vahetanud ja seal see oli punane. Kuda ta siis nii äkki undama hakkas :P
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 27.07.05 04:15 Tsiteeri
Äkki pingutasid rihma liiga üle.
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 31.07.05 09:19 Tsiteeri
Kas sai süsteemist ikka kogu õhu välja ( kas müra iseloom muutub, kui rooli keerata )?
Endal siin vedelikku vahetades tegi asi ka alguses päris võigast häält kuni kõik õhk välja tuli :D
P.S. Kustkaudu selle õli välja ajas?
[PHP: 41.5% - SQL: 58.5%]
