Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Aku tühi uksed lukus
Pealkiri: Aku tühi uksed lukus (Vastuseid: 4 | Vaatamisi: 1717)
KV7791
Registreerunud 23.07.17
postitati 23.07.17 10:04 Tsiteeri
Tere, audi 100 uksed lukus aku tühi, tundub et jäid tuled peale
Lahti saab ainult pagasniku ukselukud ei toimi võtmega rikkis
Kas saaks ka kuidagi pagasnikust lahti kuidagi näit kuhugi voolu andes
postitati 23.07.17 10:08 Tsiteeri
Algselt postitas: KV7791
Kui tuled jäid peale, siis ju lihtne, lase kusagilt a la park tulest vool sisse. Või kui vaakumiga kesklukk, siis polster maha ja ime/puhu voolikusse, et ülejäänud uksed ka lukust lahti saada.
KV7791
postitati 23.07.17 10:17 Tsiteeri
Algselt postitas: R-I-X
Ise mõtlesin la kuskile tuletest voolu lasta aga kust võiks selle vaakum süsteem olla võiks kas luugi sees
postitati 23.07.17 10:25 Tsiteeri
Ei tegele ennustamisega! Audi 100 on siiski LAI mõiste. C1 / C2 / C3 / C4 kered olemas ju...
Ei tea, kuidas C keredel, aga B keredel on keskluku vaakumpump taga parempoolse tiiva sees (rattakoopast taga pool).
EDIT: Abi soovitan otsida ka SELLEST teemast. ;)
SalmA
Auto: 100 Sedan 2.5 TDI 90
postitati 23.07.17 10:28 Tsiteeri
Võta luugil kate maha ja saad sealt vaakum voolikule ligi.
SalmA
[PHP: 23.6% - SQL: 76.4%]
