Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Probleemid Audi A6 quattroga
Pealkiri: Probleemid Audi A6 quattroga (Vastuseid: 7 | Vaatamisi: 1747)
Risto28
Registreerunud 17.01.17
postitati 17.01.17 13:30 Tsiteeri
Tere, autoks on 2004 Audi a6 2.5TDI quattro. Esisillas on korralik kolin, lisapidurituli ei tööta ja tulede kõrguse regulaatori hoiatustuli vilgub koguaegl.
Kuna autoremonte ja hindasi on seinast seina, siis äkki keegi oskab omast kogemusest soovitada mõnda head töökoda v remondimeest kes tunneb audide hingeelu.
Tänan tähelepanu eest :)
TiitR2
Registreerunud 21.07.04
postitati 17.01.17 14:51 Tsiteeri
Algselt postitas: Risto28
Auto asukoht ilmselt lihtsustaks soovitusi.
Risto28
postitati 17.01.17 15:55 Tsiteeri
Asukohaks Tallinn
postitati 17.01.17 16:31 Tsiteeri
Avant kere lisapidurituli ja kõrguseregulaatori andur(id) tuleb tõenäoliselt uued originaalid osta.
Kasutatud variantide otsimine või külgepanemine oleks minu arvates enesepettus. Need on kuluosad, kuna alluvad ilmastiku ja keskkonna tingimustele.
Risto28
postitati 18.01.17 08:11 Tsiteeri
Hea oleks kui keegi teaks soovitada häid remondimehi kes viitsiks auto tegemisse võtta..Esisild tahab ka tegemist
yanekk
postitati 18.01.17 09:11 Tsiteeri
Sama hästi võiksid ise foorumist seda otsida ja helistada ning uurida.
Best ET 12.08 :)
Risto28
postitati 18.01.17 12:25 Tsiteeri
kõik kohad on autoremondi töökodasi täis...Arvad et ma ise oska otsida? Paljudes kohtades üritatakse üle lasta v keeratakse sitt kokku kehva remontimisega...Sellepärast uuringi siit foorumist, et keegi soovitaks omast kogemusest mõnda head töökoda kus tehakse korralikult töö ära!
KuldarA
Registreerunud 26.11.11
postitati 18.01.17 12:30 Tsiteeri
Acgarage.ee, Esindus, Forss jne
[PHP: 17.5% - SQL: 82.5%]
