Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Raadio & püsikiiruse hoidja
Pealkiri: Raadio & püsikiiruse hoidja (Vastuseid: 1 | Vaatamisi: 1190)
gregor96
Registreerunud 17.12.16
postitati 19.12.16 07:04 Tsiteeri
Oskab keegi ehk jagada soovitusi paari elektroonilise probleemi kohta 1998. A4 juures.
1) Raadio puterdab. Enamus ajast suudab üles korjata vaid ühte raadiojaama ning seegi kaob suure osa ajast ära (läheb väga vaikseks). Kas siin vigane antennikaabel või mure pigem raadios? Nii palju kui uurisin, siis raadiosse sisse tulev pistik heas korras ja ühendused korralikult kinni.
2) Püsikiiruse hoidja ei tööta. Vajutan nuppu, kuid miskit ei toimu. Nii palju kui uurisin, siis asi võiks olla kaitses. Diagrami järgi see aga sama kaitse, mis tagurdustuledel, kuid viimased töötavad kenasti, seega kaheldav. On siin veel midagi, mida võiks ise näppida, või ainus lahendus mooduli vahetamine?
postitati 19.12.16 07:37 Tsiteeri
2) Kui tegemist 1998. aasta bensukaga, siis võiks esimese asjana proovida teist (kindlalt töökorras) püsikiirushoidja aju.
Tallinnas saan seda anda/laenata. Kahjuks seal arvutiga midagi ei näe.
Kui aga diisel, siis saab arvutiga kontrollida erinevate lülitite toimimist. Diislil eraldi aju puudub, mis jupsima saaks hakata.
[PHP: 21.3% - SQL: 78.7%]
