Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - audi 100 c4-le a6 c4 kellaplokk
Pealkiri: audi 100 c4-le a6 c4 kellaplokk (Vastuseid: 6 | Vaatamisi: 1437)
alari88
Registreerunud 17.08.12
Auto: c4 2.5tdi ;bmw e34 tds ;calibra 110kw
postitati 13.11.16 05:29 Tsiteeri
tere
kas keegi teab kuidas 100 saaks abs tuled a6 plokiga toimima
ette tänades
postitati 13.11.16 07:38 Tsiteeri
100 C4'sid peaks olema ka kahte erinevat varianti: ABS'i lülitiga ja ilma selleta.
Kummaga tegemist?
Priit86
Registreerunud 30.10.08
postitati 13.11.16 10:22 Tsiteeri
Nii lihtsalt ei saagi. ABS-i pumbad ja ajud neil erinevad, seepärast ei ühildugi. Ise jändasin ka pikalt, kuni lõpuks loobusin. Otsi mu auto teema üles ja sealt leiad lugemist. Ja mingi seletuse ka, kui sellest abi.
Sõidame ikka mõistusega !
postitati 13.11.16 11:01 Tsiteeri
Eks kõik on tehtav. Pole esimene ega viimane, kellel sama mure!
alari88
postitati 13.11.16 13:53 Tsiteeri
tean niipalju et 100 ja a6 aju annab erinevat polaarsust ehk üks plussi teine miinus kui süsteem korras
ja kellaplokil pini asetus teine ,aga ei tea mis pin kuhu ümber tõsta ja kuidagi relee või diodiga polaarsus muuta
postitati 15.11.16 07:29 Tsiteeri
Sõltuvalt vastusest ülalesitatud küsimusele eksisteerib ka kaks varianti, kuidas neid dioode ja releesid ühendada.
alari88
postitati 06.12.16 20:47 Tsiteeri
ilma lülitita varjant mul
[PHP: 20.3% - SQL: 79.7%]
