Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - ukse lombivalgusti saab voolu peale aga ei põle (must jublakas katkestab?!)
Pealkiri: ukse lombivalgusti saab voolu peale aga ei põle (must jublakas katkestab?!) (Vastuseid: 3 | Vaatamisi: 1494)
elu
Registreerunud 31.12.10
postitati 23.08.16 10:10 Tsiteeri
Tester näitab, et lombivalgusti pistikusse tuleb vool, aga lamp ei sütti. Kruvikeeraja otsaga voolu lambi kõrval olevast mustast ümmargusest jullakast mööda juhtides süttib ka lamp.
Mis jullakaga on tegu, kuidas selle korrasolekut testida ja kas viga võiks olla selles või kuskil mujal?
https://s14.postimg.org/knxcxuect/2016_08_14_20_45_48.jpg
https://s14.postimg.org/tk851s4z1/2016_08_14_20_46_21.jpg
https://s14.postimg.org/bip03zay5/2016_08_14_20_47_08.jpg
stonestick
Registreerunud 08.07.15
Auto: S3 8P
postitati 23.08.16 10:22 Tsiteeri
Must jublakas peaks olema diood - midagi oleks nagu tagurpidi paigaldatud selles süsteemis, lombivalgusti pistikut nö ümber ei saa keerata?
postitati 23.08.16 10:38 Tsiteeri
Lihtsalt mainin, et on olemas ka täpselt samasugused kuid ilma selle dioodita lombivalgustid, mille töö ei sõltu toitepinge polaarsusest.
Kahjuks ei tea, mis mudeli ja aastaga on tegemist. Seega rohkem ei saa ka kommenteerida.
elu
postitati 23.08.16 17:04 Tsiteeri
Algselt postitas: stonestick
Pistikut kahjuks niisama lihtsalt ümber ei keera - pistikule endale selline vorm antud, et ühel pool lõigatud nurkadega plastiknurgad.
Seda on küll kummaline kuulda, kuid samas ka huvitav ja julgustav - ühendasin musta jullaka klemmid ära ja katse näitas, et selle voolu peale saamist ehk põlemist juhib ukseluku andur - kui uks on kinni siis lombivalgustustuli põlema ei jää. Eks testib nii.
Küsimuse tuum püsib - milleks seal see musta värvi arvatav diood üldse vajalik on?
[PHP: 26.7% - SQL: 73.3%]
