Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Murelaps a4 96a 1,8 92kw
Pealkiri: Murelaps a4 96a 1,8 92kw (Vastuseid: 3 | Vaatamisi: 1115)
rainix
Registreerunud 27.08.14
postitati 01.07.16 19:13 Tsiteeri
Hei mure 1,8 92 kw audi a4 probleemide jada algab kõrge Co -ga,pika käivitusega ning kustu pandud mootoritulega. Täna lihtlabast diagnosti näppides avastasin ,et süütenurga % tühikäigul tuksudes hüppleb 9,8 ja 13 vahel. Esimene mõttevälgatus oli see ,et süüde paigast,nii rihmal kate maha ning oleks nagu kohe tahtnud süüdet näppima hakata. Aga kaanealt paistis hoopis see ,et rihma rulliku kinnitus polt viskab, realselt tsentrist väljas , pingutusrullikul liigub edasi-tagasi mingi 3-4mm . kas sellepärast on segu vale jaCo paigast? ning ehk sellepärast ka mootori pirnike eemaldatud? ise just soetasin selle masina ,kuid tean et 2015 on alla pandud uus universaalne Kat. kas universaalsed ei peagi kauem vastu kui aasta? suht segane värk ning vast saate mu küsimustest aru.
postitati 01.07.16 19:26 Tsiteeri
Et co lõpuks korda saada, võiks üle kontrollida ka kõik karterituulutuse plastist torud ja kummist voolikud.
Katkiste voolikute või ka torudega ei suuda mootor segu/süüdet paika reguleerida, näiteks lisaõhk peale MAF andurit.
Lisaks sellele ka kõik muud jutud muidugi!
rainix
postitati 02.07.16 13:23 Tsiteeri
aga see ei loe et esimene hammakas kergelt viskab? mingi 1-2mm.
postitati 02.07.16 17:00 Tsiteeri
Algselt postitas: rainix
ja siis
Mis asi see täpselt viskab siis?
Suure rulli kinnituspolt
suur rull ise
väikse rulliku polt või
väike rull ise?
Esimene hammakas lülitus ka kusagilt teemasse - kas see on see, mis vända otsas või nuka otsas?
Ja kui palju? 3-4mm muutus 1.2mm-ks?
Suur rull pisut liigubki, sel on ju see kompensaator külges ja peabki pisut tuiama, kuna mootor vblla ei käi päris sujuvalt.
Väike rull peab ainult keerlema; muid liigutusi teha ei tohi. :)
Aga et esimene hammakas viskab? Misasja?
[PHP: 24.7% - SQL: 75.3%]
