Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Lisa vool
Pealkiri: Lisa vool (Vastuseid: 5 | Vaatamisi: 1081)
sass098
Registreerunud 09.10.10
Auto: A4 B6 2,5TDI A6 C6 3.0TDI Q
postitati 23.10.15 08:33 Tsiteeri
Lisa vool
Tervitus, a6 c6 07a, tahan lisada kaugtulesid kuna originaal on nagu neil kõigil aga jäin mõtlema kust võtta tuledele vool. Impulsi relee jaoks saab tule juhtmest aga sealt ei taha mitte voolu võtta ja aku ka kaugel.
ülks
Registreerunud 04.12.04
postitati 23.10.15 10:52 Tsiteeri
Algselt postitas: sass098
Kas kapoti all + terminal on olemas? Sealt ei kannataks võtta?
www.teemetünni.ee
SilverL
Registreerunud 18.07.13
Auto: A6 Avant C7 FL BiTDI
postitati 23.10.15 11:00 Tsiteeri
Selge on see, et sa ise neid tulesid sinna korealikult ette ei saaks. Minul on lisakaugtuled ette pandud jõujaamas. Nii negatiivne kui positiivne koht on olemas kapoti all, mass on kohe eestpoolt vaadates üleval vasakul ja plussi saab vasakult ülevalt ühe musta karbi seest mis on selle ekstra musta katte all (see kus aknapesu kork). Sinna tulevad jämedad juhtmed akust. Minul on bixenon elektrilise juhtimisega ja signaali selleks leiab pedaalide kohalt. (Salongist seest.)
postitati 23.10.15 11:20 Tsiteeri
See pluss on olemas ka kõrvalistujapoolses mustas karbis. Jämedad (16, 12, 10 või 6 ruutmillise ristlõikega) punased ilma täiendava triibuta juhtmed.
Kaitsme võiks ikka ka vahele sokutada.
sass098
postitati 23.10.15 17:08 Tsiteeri
Aku klemmidest mis kapoti all on, ei taha võtta. Sinna ei saa külge ühendada. Homme uurin neid musti karpe. Paigaldusega saan kindlalt ise hakkama, signaali saab ka tulest endast, facelifti mudelile sai keskmised vilgutamise elemendid tehtud ümber täistuledeks ja seal sai ka signaal võetud tule juhtmestikust. Relee ja kaitsmed on loomulikult kohustuslikud.
sass098
postitati 24.10.15 14:59 Tsiteeri
Tuled ees ja toimivad. Sellest mustast karbist oli hea voolu võtta seega tänan soovituste eest, lisaks tule pistikus nr 11 juhe on täistule impulss, mingit veakoodi sellega ei järgne.
[PHP: 47.6% - SQL: 52.4%]
