Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - a4 1,8 suri välja ja ei käivitu enam-Asi kütusepumbas
Pealkiri: a4 1,8 suri välja ja ei käivitu enam-Asi kütusepumbas (Vastuseid: 7 | Vaatamisi: 1078)
simo88
Registreerunud 15.12.10
Auto: audi 80 b3 101 kw ja a4 1.8q, VW G3 VR6
postitati 29.06.15 19:14 Tsiteeri
Mure selline, et a4 (1995a) 1,8 (ADR) 92kw suri sõites välja ja enam ei käivitu. Mootor käib ilusti ringi. Peale väljasuremist hakkas segusiibri juurest imeliku undamist tulema.
Kas keegi oskab midagi tarka öelda, et milles asi on ja mis välja vahetada vaja.
Ise asun Valgas ja auto Valga lähedal.
Ette tänades
Simo
postitati 29.06.15 19:20 Tsiteeri
Vöimalusel juhe sappa ja saab mingigi aimduse, äkki.
simo88
postitati 29.06.15 19:24 Tsiteeri
Asjaga kiire, aga juhtme saaks alles reedel sappa visata :(
postitati 29.06.15 19:35 Tsiteeri
Algselt postitas: simo88
Kas sinu asukoha läheduses pole kedagi, kel kaabli võimalust, kasvõi veakoodide lugemiseks?
simo88
postitati 29.06.15 20:01 Tsiteeri
Mul suri auto maal ära, linnas oleks lihtne töökotta veda. Homme hakkan otsima inimesi kes sellega tegelevad ja kui keegi ei viitsi kohale tulla toon auto linna. Tahtsin kergemalt pääseda ja lootsin, et keegi teab milles asi võib olla.
iguaan
Registreerunud 10.02.13
Auto: B7 A4 Avant 2.0T quattro 147kw '05
postitati 29.06.15 20:36 Tsiteeri
Maa/linn suhtelised asukohad, kui pisut piirkonda täpsustada saavad klubilised äkki aidata.
karly
Registreerunud 26.11.08
postitati 30.06.15 05:26 Tsiteeri
Usun et kütusepump sai otsa.
postitati 30.06.15 05:57 Tsiteeri
Algselt postitas: karly
Kui kulunud on ainult el. mootori kollektor, siis paagi loksutamine, koputamine või peksmine äratab pumba hetkeks veel ellu.
Kui pumpa ennast koputada, saab heal juhul isegi töökotta sõita.
[PHP: 22.2% - SQL: 77.8%]
