Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 80 b4 esisild koliseb.
Pealkiri: Audi 80 b4 esisild koliseb. (Vastuseid: 14 | Vaatamisi: 1904)
Light
Registreerunud 17.06.12
postitati 12.06.15 13:11 Tsiteeri
Autoks audi 80 b4 2.0 85kw quattro.
Mure siis järgmine, et ostmisest peale on esisild kolisenud. Vahepeal vahetatud: esimesed amordid, tugilaagrid, raami puksid, õõtsa puksid, stabika puksid, stabika kondid.
All on ka madaldus vedrud. Kui maanteel ca 100km/h järsemast lohust läbi sõita lööb keresse kõva paugu.
Käidud kontrollis ka töökojas ning samamuti ühtegi viga ei leitud. Ehk oskab keegi öelda, mis võiks seda kolinat tekitada?...Olen lugenud, et paljudel B4 esisillaga probleeme.
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 12.06.15 13:39 Tsiteeri
Palju seda madaldust on?
Tean vähemalt kahte juhust kus madaldus ei olnud just kõige kvaliteetsem ja kasutusel tava õliamort, samuti lajatas paugu keresse ja seda tänu sellele et amordistokil ei olnud enam kuskile minna allapoole. Ehk siis lihtsalt lajatas amordi põhja ja kohe olid ka tugilaagrid uuesti puruks
zack
Registreerunud 30.11.07
postitati 13.06.15 09:29 Tsiteeri
Endal ka sama probleem. B4 2.0 66kw...vahetatud ees sarniirid, õõtsapuksid, amordipadjad aga ikka aukudest läbi sõites kolin sees.
Light
postitati 16.06.15 11:19 Tsiteeri
Palju seda madaldust on ei oska kahjuks öelda. Auto jõudis minuni nende vedrudega.
Põhja peal ei seisa ja rattakoobastes on ka piisavalt ruumi. Võrreldes mu B3'ga on see B4 ikka väga kõrge.
Kui saan mingihetk kusagilt originaal vedrustuse ja alla jõuan panna annan ka teemas teada kas miskit muutus.
Light
postitati 11.07.15 17:24 Tsiteeri
Nüüdseks on all originaal vedrustus ja kolin ei kadunud kuhugile. Järsematest lohkudest läbi sõites peksab ikka paugu keresse.
Ehk oskab keegi nõu anda, et mida veel vaadata/proovida...endal mõtted otsas.
Koliseb (peksab keresse) linnas ca 50km/h järsemast lohust läbi sõtes. Proovisin sõbra passatit ja to samadel aukudel täiesti vait, nagu polekski kusagilt läbi sõitnud.
sir-mac
Registreerunud 26.06.03
Auto: S6 4,2 Avant
postitati 11.07.15 18:04 Tsiteeri
Olen küll B4 altpoolt ka näinud, aga kahjuks ei tule pilt silme ette. Kas tal on ka nn. poolraam nagu C3? Kui on, siis võivad vabalt läbi olla poolraami puksid ja sel juhul ei aita vedrude ja amortide vahetus kohe mitte. 100-le sai transportööri lindist seibid vahele pandud ja maa peal valitses vaikus. Ja kui on viitsimist, hinda stabikavarda pukside seisukorda.
sir-mac
Auto: S6 4,2 Avant
postitati 11.07.15 18:06 Tsiteeri
Sry, sul need juba ju vahetatud.
madjs
Registreerunud 28.10.02
Auto: Audi 80 b4 1,9tdi, Suzuki VX 800, Golf 2 GTI, Megan Coupe 108kw
postitati 11.07.15 22:26 Tsiteeri
Mootori esimene tugi ei lajata keresse?
Light
postitati 12.07.15 04:37 Tsiteeri
Stabika puksid panin just igaks juhuks uued, kuigi all olevad olid sammuti pmst äsja pandud. Raami püksid on ka uued.
Mootori padjad vaatasin üle, raputasin mootorit igat pidi ja kusagil mingit lõtku ei olnud..
Huvi pärast võtan stabika korraks üldse alt ja proovin siis..
Light
postitati 12.07.15 09:48 Tsiteeri
Võtsin stabika üldse alt aga ei muutnud see midagi. Samamoodi lajatab paugu keresse. Pole vaja üldse suurt auku/lohku, et see juhtuks. Mõtted täiesti otsas, ei oska enam midagi vahetada ja proovida. Kui tekib veel kellelgi mõtteid olen valmis proovima.
Light
postitati 03.08.15 18:59 Tsiteeri
Tooks teema päevakorda.
Ikka maadlen nende paukudega keresse. Keegi teine pole oma B4 tähele pannud, et lajataks suuremates lohkudes paugu keresse? Kuna pole ühegi teise B4'ga varem sõita saanud, siis ehk ongi see B4 eripära? Ükski teine auto millega proovinud olen pole samade kohtade peal pisematki kolksu teinud.
100
Aeg maha
Registreerunud 12.04.10
Auto: 100
postitati 03.08.15 19:09 Tsiteeri
Kuna vedrud lühemad, siis arvatavasti peaks amordi töökäik lühem olema ja amort istub rohkem oma lõpu lähedal kui originaalis ning järsemast lohust läbi sõites lööb amordi põhja (läbilöögipuksi vastu)? Kas on vahetatud nii läbilöögipuksid kui amordi tugipadjad?
Räägitakse, et kulunud roolilatt võib ka igasuguseid kahtlaseid kolksusid teha.
Pigem tundub, et probleem on amortide-vedrudega seotud.
Light
postitati 04.08.15 11:59 Tsiteeri
Madaldus vedrud vahetasin originaal vedrude vastu ja sammuti igaks juhuks panin ette ka uued amordid.
Tugilaagrid panin kõrgemad madalamate asemel, kuna olen kuulnud, et ka nendest võib kolks tekkida. Kusjuures läbilöögi pukse vahetanud pole, ehk peaks tõesti need ka uued panema, olgugi, et vanadel midagi häda pole...
Täna sai proovitud ka üht teist b4 kerel audit ja tollel sildades jumala vaikus. Seega ikka viga kusagil minu masina küljes.
postitati 05.08.15 06:13 Tsiteeri
Mul B4 all -45mm madaldus originaal amortidega ning ei kolksu midagi kuskil. Läbilöögi puksid võivad olla pealtnäha korralikud, aga nn "pehmeks vajunud", st ei tee enam oma tööd nii nagu peaks. Kui vahetama hakkad, siis pane uus ja vana kõrvuti ning imesta, kui palju ta lühemaks vajuda saab. :)
Light
postitati 07.08.15 19:25 Tsiteeri
Uskumatu! Tundub, et läbilöögi pukside vahetus tõesti aitas!..
[PHP: 20.9% - SQL: 79.1%]
