Pealkiri: Audi A8 3.2 FSI - 2006 - riiel (Vastuseid: 14 | Vaatamisi: 4255)
riiel
Registreerunud 08.01.13
postitati 20.04.15 07:22 Tsiteeri
Tervist,
Auto ostetud 2013 sügis.
Toodud millalgi itaaliast, niiet puuduvad mõned lisad nt. soojendusega istmed.
Suuremad tööd mis olen teinud:
Õhkpadja, kompressori ja ketipingutite vahetus. Pluss veel mõned nipetnäpet asjad
Ega rohkem ei oskagi kirjutada
http://4clubbers.eu/a8/rsz_41787871.jpg
http://a8.4clubbers.eu/rsz_141787965.jpg
E0A = No special edition
0GG = Emission standard EU4
4VF = 1 2-point seat belt/3 static lap belts third row of seats in passenger compartment
6XL = Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable/heated
5SL = Left exterior mirror: aspherical
5RV = Right exterior mirror: aspherical
1KW = Disc brakes, rear
J0Z = Battery 520 A (110 Ah)
1LL = Disc brakes, front
2MA = 4-corner air suspension with electronic shock absorption control, sports version
3FA = Without roof insert (standard roof)
5TZ = Decorative inserts, gray birch vein
7X4 = Park distance control, front and rear
F0A = No special purpose vehicle, standard equipment
0YZ = Without determination of weight categoryfor rear axle
0JZ = Without determination of weight categoryfor front axle
T14 = 6-cylinder gasoline engine 3.2 L Unit 06E.A (ALU)
8ED = Bi-functional headlight with gas discharge lamp, for driving on the right
V1A = Apollo tires
X4C = National sales program Italy
1XX = Leather trimmed multi-function sports steering wheel w/ Tiptronic
8Q6 = Headlight-range adjustment, automatic/ dynamic with fixed and dynamic bending light(AFS 2)
8Z5 = Not hot country
D62 = 6-cyl. gasoline eng. 3.2 L/191 kW (24V) FSI, homogeneous base engine is T14
7Q2 = Navigation system with color screen
CQ4 = Alloy wheels 7.5J x 18
7K0 = Without tire pressure warning light
2K1 = Reinforced bumpers
3PN = Electric seat adjustment for both front seats with memory system
VW8 = Side and rear windows, burglar-restrained
3Y2 = Electrically operated roll-up sun screenfor rear window
4K4 = Radio remote controlled central locking
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
5Z0 = Without separate power seats rear
Q1D = Sports front seats
4GH = Windshield in heat-insulating glass with sunshield
riiel
postitati 20.04.15 08:13 Tsiteeri
Eile tulin mõttele, et võiks panna valged ledid salongi.
Küsin, kas keegi on oma a8 vahetanud vanad salongi pirnid LED'de vastu?
Palju neid pirne vaja on, mis tüüpi ja kuidas neid vahetada?
riiel
postitati 21.04.15 11:16 Tsiteeri
Kas keegi saab pärnus MMI 5570 plaatidega ja kaabliga aidata?
sigaelmar
Registreerunud 25.08.07
postitati 21.04.15 13:26 Tsiteeri
Kas sa vahetasid ketipingutid igaks juhuks ära või oli mingi probleem?
riiel
postitati 22.04.15 07:32 Tsiteeri
Algselt postitas: sigaelmar
Külma mootoriga käivitades oli kõrin sees, revalis vaadati üle ja öeldi, et ketipinguti läbi
sigaelmar
postitati 22.04.15 08:07 Tsiteeri
Kui kaua või kui valjusti ta kõrises?
riiel
postitati 22.04.15 08:20 Tsiteeri
Terve käivitamise aeg, tugevuse kohta ei oska öelda aga mulle ei meeldinud see heli
scox
Registreerunud 09.03.09
Auto: Audi A6 C6 3.0TDI Q 2005, urS4 4.2 v8 1992, (Audi A4 1996a. 1.8 R.I.P)
postitati 22.04.15 16:51 Tsiteeri
Pakun mmi uuendust ja navi ning pirnide koha pealt võin ka aidata
Alexashka
Registreerunud 07.03.15
postitati 05.06.15 10:02 Tsiteeri
Kettide plõrinaga käivitusel, tavaliselt, sõidavad päris kaua :)
Kui aga hakkab töötaval motol plõksuma siis on asi hull ja tuleb rahad välja käima varsti.
sigaelmar
postitati 08.06.15 06:17 Tsiteeri
Algselt postitas: Alexashka
Ma olen aru saanud, et bensukad vist sõidavad jah päris kaua aga diislil pikka pidu pole kui kett käivitamisel häält teeb.
riiel
postitati 03.07.15 19:51 Tsiteeri
Hea kuulda
AntiL
Registreerunud 30.05.08
postitati 10.07.15 10:58 Tsiteeri
Lahe värk ikka. Ostetakse omaaegne esindussedaan ja kui tuleb info, et kõriseva ketipingutiga kannatab veel pikalt sõita ohatakse kergendatult.
JoonasJJ
Registreerunud 29.05.11
postitati 10.07.15 11:24 Tsiteeri
Algselt postitas: AntiL
Karikat või siis vähemalt medalit väärt kommentaar. +1
postitati 10.07.15 13:21 Tsiteeri
Lohutuseks niipalju, et A8'l on vähemalt mootori taga rohkem ruumi ja saab mugavamalt ülemisi pinguteid vahetada.
riiel
postitati 24.07.15 07:11 Tsiteeri
Kui sa loeks esimest postitust siis sa näeksid, et autol pingutid vahetatud ja see ei olnud kergendatud ohatus.
[PHP: 20.7% - SQL: 79.3%]
