Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A4 läheb keema
Pealkiri: Audi A4 läheb keema (Vastuseid: 13 | Vaatamisi: 2106)
onuheino
Registreerunud 02.02.14
postitati 02.02.14 12:51 Tsiteeri
Audi A4 läheb keema
tere, mul on probleem audi a4 (B5) 1,6l, 74 kw jahutusega. panen kõik symptomid siia kirja. nimelt auto jahutusvedelik läks keema, temperatuur tõusis 115 kraadini ja kompuutris läks hoiatustuli põlema. jätsin masina seisma ja vaatasin yle jahutusvedeliku taseme- see oli normis. jahutasin mootorit, ja läksin tuttava juurde ning vahetasin ära termostaadi ja temperatuurianduri, sellest abi ei olnud. kohapeal tiksudes tyhikäigul läks masin uuesti keema. kallasin veidi jahutusvedelikku juurde ja õhutasime systeemi ära- ei aidanud. kontrollisime salongiradikat ja see oli ok. jahutusradikas soojaks ei lähe. yks lõdvik läheb soojaks kui temperatuur on 90´+ aga teine ei lähe. lõdvikutes tugev surve puudub ja salongi hakkab kytma samuti kui temp on 90+ kraadi. kui temp läheb yle 100 kraadi siis kytab ikka väga kuumaks. paisupaagi kork on samuti vahetatud ja proovitud mitut erinevat! loodetavasti targemad inimesed oskavad diagnoosida ja nõu anda mida edasi teha? plokikaane tihend läbi? veepump? või lausa plokk ise õhtal?
ettetänades!
Ricky
Registreerunud 10.06.09
postitati 02.02.14 12:55 Tsiteeri
Kahtlustan veepumpa, nimelt plastikust labad pooleks. Enda 1.8T B5-l oli sama jama, ostsin sinna metall labadega pumba.
E: Kui sa ei pahanda siis kirjutan siia oma mure ka.
Nimelt siis A4 B6 1.8T läheb keema. Nullist 90 kraadini kulub umbes 7 minutit ja hakkab temp üle selle ronima. Samas mul erineb teemaalgatajast see, et mul ei puhu salongi grammigi sooja õhku ja paisupaagis jääb vesi külmaks. Mis siin võib probleemiks olla?
Kahtlusan veepumpa, aga hiljuti vahetatud rihmad ja jutud. Antud mootori puhul (AVJ) jääb veepump hammasrihma alla, erinevalt siis minu teisest autost millel oli kiilrihma all. Kas võib mure korduda, ehk siis veepumba labad või siis termostaat?
onuheino
postitati 02.02.14 12:59 Tsiteeri
kui veepump on õhtul omadega`, kas siis on võimalik, et salongisoojendus toimib?
mainin selle ka veel lisaks, et päev enne jamade algust sai jäärajal tunnike lõbutsetud...äkki on kasulik teada!
Ricky
postitati 02.02.14 13:01 Tsiteeri
Algselt postitas: onuheino
Muudsin oma eelmist posti, väiksed kahtlused tekkisid mul just jah.
onuheino
postitati 02.02.14 13:20 Tsiteeri
olgu siis veel mainitud ka see, et tosooli sees õli ei ole ja õli sees tosooli samuti mitte!
memphis
Registreerunud 16.01.06
Auto: vw passat 2004
postitati 02.02.14 14:40 Tsiteeri
Kontrolli veepumpa, ilmselt peitub viga seal.
onuheino
postitati 02.02.14 14:46 Tsiteeri
teisipäeval lähen yhe targa onu juurde ja tuleb ära survestada siis on näha kas viga peitub plokikaanes, kui ei siis veepumba kallale!
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 02.02.14 14:48 Tsiteeri
Pigem veepumba kallale ja siis vaadata, kas plokikaan ka viga sai. Nimelt peaks vedelikku ka kaduma, kui plokikaan kõver, või tihend ära.
http://foorum.audiclub.ee/viewthread.php?tid=20090
Life is tough.
varemax
Registreerunud 27.03.11
Auto: Audi a4 b8 2,0 tdi 2008
postitati 02.02.14 14:59 Tsiteeri
Salongi radikasse satub ikka soe ringlema kui veepumpa labad katki. Kõige kiiremini veepumba olukorras veenduda on külma mootoriga käima ja kohe soendus radika toru lahti tõmmata ja pööret anda korra.Kui lõõb vedeliku välja siis pump toimetab.
onuheino
mõlema variandi puhul on teatud vasturääkivusi
plokikaane tihend läbi?? - lõdvikutes puudub tugev surve ja tosooli sisse pole sattunud õli ning õli sisse pole sattunud tosooli.
veepump õhtal? - salongi puhub kenasti sooja õhku!
ok, seda asja ma saaks kohe proovida
annan varsti teada tulemustest
onuheino
postitati 02.02.14 15:29 Tsiteeri
paistab, et viga on leitud!!! grammigi vedelikku ei tulnud sealt...v.a siis kui keerasin paisupaagi korgi lahti ja puhusin sealt õhku sisse.
suured tänud kõigile abimeestele... annan homme või ylehomme siin ka teada kas piisab ainult pumba vahetusest.
Edu!
pillekas
Registreerunud 12.03.10
postitati 02.02.14 15:40 Tsiteeri
Arvan et rihm katki.Täpselt ei tea kuidas sellel mootoril on aga 1.8 20v on eraldi väike rihm mis veepumpa ringi ajab, mida kohe ei näe, kui kapoti alla piilud.Jääb natuke peitu.
onuheino
postitati 02.02.14 15:54 Tsiteeri
esimeses postis jäi kahjuks see asi mainimata, et rihm on terve
yanekk
postitati 02.02.14 17:10 Tsiteeri
Ole hea ja vaata ka klubi reeglid üle, enne kui moded sind leiavad.
http://foorum.audiclub.ee/viewthread.php?tid=62785
Ja oma profiili täitmine ei tee ka paha.
Best ET 12.08 :)
[PHP: 24.9% - SQL: 75.1%]
