Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 B5 automaadi käigukangi nupp kiilus kinni
Pealkiri: A4 B5 automaadi käigukangi nupp kiilus kinni (Vastuseid: 7 | Vaatamisi: 1820)
Lemboss
Registreerunud 05.03.07
Auto: A4 V6
postitati 12.01.14 12:47 Tsiteeri
Tere
Täna sõidu ajal kui käigukang oli D asendis, lõin käega kogemata vastu käigukangi riivates käigukanginuppu, mis jäi sisse ning ei tule enam tagasi algesse asendise. Käike saab vahetada D N ja 4 käigu vahel, R või P asendisse käiku panna ei saa.
Nupp on küll sees, aga lüliti tundub, et jäi esialgsesse olekusse, mistõttu ei saa P või R asendisse. Proovisin seda väja urgitseda, tuleb välja küll aga kui lahti laseb tuleb sisse tagasi ja käike vahetada ei saa.
Kas kellegil on sarnast peavalu olnud ning kuidas saaks vea kõrvaldada ? Või ehk kuhu saab pöörduda ning mis remont võib ees oodata.
Igasugune info teretulnud!
postitati 12.01.14 13:43 Tsiteeri
Tõmba nuppu nii välja, kui tuleb ja sikuta kogu kangi üles. Nii saad kangi koos nupuga kätte ning vaadata, mis purunes. Vähemalt c5-l on nii, täpsustage, kui eksin.
postitati 12.01.14 14:41 Tsiteeri
C5'l tuli ka kangi(toru) kattev läikiv plasthülss alla lükata. See vabastab lõplikult käepideme.
Lemboss
Auto: A4 V6
postitati 13.01.14 09:04 Tsiteeri
Tänan info eest, läheb peale tööd sikutan käigukangi otsa maha.
Kas keegi on sarnase probleemiga kokku puutunud, ehk oskab kogemust jagada, kas saab seda kuidagi parandada või lihtsam oleks kasutatud uut käigukangi ots osta ?
Küsin ka kohe arvamust juurde, et kui mul on 2.6 bensiin 5 käiguline automaat, siis käigukangi ots peab olema kindlasti sama mudeli oma või kuidas selles osas on ?
Lemboss
Auto: A4 V6
postitati 13.01.14 15:00 Tsiteeri
Sain kangi otsa maha, käigukasti metalltorust ulatub välja kandiline plastikust pulgake!
Küsimus kas see ei tohi välja tulla kui seda tõmmata õrnalt ? Minul tuli see välja ca 10 cm jupp, ise eeldan, et see ongi puruks seetõttu ei tule nupp välja tagasi.
Saan aru, et süsteem töötab nii, et kui surud nupu alla, tõmbab selle pastpulga abil käigukastist midagi ja lasen R või D peale vahetada.
Kordan siis küsimuse üle, et kas see pulgage ei tohi väja tulla (kui tuleb on see järelikult pooleks) ning kas siis tuleb eeldavasti kogu käigukasti andur välja vahetada ?
Lemboss
Auto: A4 V6
postitati 13.01.14 15:39 Tsiteeri
Jõudsin probleemi ivani, nimelt purunes käigukasti kangi sees olev plastikust piklik julla, mis on ühendatud käigukastikangi nupuga.
Õnneks on seda juppi eraldi müüja, mis tähendab, et saab eraldi vahetada.
Seega sai Forsist uued jupid tellitud vedru + plastjulla ca 12€. Nüüd siis 2 nädalat oodata kui kaup tuleb ja vahetsse.
Ega kellegil mõna linki heale juhendile või videole ei ole kuidas käigukasti kang lahti võtta, koos keskkonsooliga ?
morriss
Registreerunud 20.12.10
postitati 27.01.14 13:32 Tsiteeri
Oled saanud vahetuse ära teha? Mul tekkis just täpselt sama probleem täna.
Lemboss
Auto: A4 V6
postitati 04.02.14 11:46 Tsiteeri
Jah lasin ära vahetada, õnneks sai minu mudelile seda plastikust jubinat eraldi tellida.
Vahetus pole aga väga lihtne, pidi vist isegi summuti alt ära võtma, et antud töö tehtud saaks, forss määras tööajaks 4-5 tundi, 35 € tund, edasi arvuta ise.
Õnneks sai sõber mehaanik kõik ise vahetatud.
[PHP: 20.4% - SQL: 79.6%]
