Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 1.9 TDI 96 kW Audi A4 2003 aasta
Pealkiri: 1.9 TDI 96 kW Audi A4 2003 aasta (Vastuseid: 5 | Vaatamisi: 816)
keijo84
Registreerunud 30.07.12
Auto: Audi A4 Avant 1,9 TDI (96 kW)
postitati 12.01.14 09:17 Tsiteeri
Sooviks siis arvamusi, et mure selline et autoga s6ites v6i kiirendades t6mbab autol hinge kinni (viskab mootori tule p6lem) ja tahaks nagu välja surra, kui gaasi lahti lased siis k6ik korras jälle saab s6ita taas mingi aja ja siis teeb uuesti mingi aeg nii.
Asja kallal on juba natuke ka töötatud arvuti näitas 6hulugeja viga sai siis vahetatud nii 6hulugeja, kui ka filter aga viga tule p6him6tteliselt kohe tagasi ja jälle näitab 6hulugeja viga.
Nyyd kysiks, mis arvamusel audi mehed on ise arvan, et viga v6ib olla 6hulugeja relees v6i siis kusagil juhtmetes. Aga samas mulle räägitud, et mingi pihusti v6ib läbi olla, kuid ei tahaks seda uskuda siis ei töötaks mootor yltse (putertaks) aga sellist jama nagu pole lihtsalt t6mbab hinge kinni nagu 6hku ei tuleks peale.
yanekk
postitati 12.01.14 09:20 Tsiteeri
Algselt postitas: keijo84
Mis asi see veel on?
Ja kuidas oleks sellega, http://foorum.audiclub.ee/viewthread.php?tid=62785
Kõiki sinu oletusi saab arvutiga vaadata masina pealt, ei pea ennustama.
Best ET 12.08 :)
keijo84
postitati 12.01.14 09:31 Tsiteeri
Algselt postitas: yanekk
Kas 6hulugeja pole relee all..nii mulle on räägitud..
t6esti vabandan, et kasutan 6 ja y kuna arvuti selline ja ei hakka ära muutma kuna tegu töö arvutiga ja olen ainuke eesti keelne inimene..
walkman
Registreerunud 25.01.06
Auto: Audi S8 D2
postitati 12.01.14 09:44 Tsiteeri
Vaata rüperaaliga oma veakoodid üle autol, siis ehk mõni oskab sind suunata kuskile poole veaotsingutel.
Muidu siinsed kodanikud jäävadki sapiseid postitusi õigekirja teemadel kirjutama. :D
keijo84
postitati 12.01.14 09:52 Tsiteeri
Algselt postitas: walkman
Selleks ma küsingi, et veakoodid on üle vaadatud ja sellest tulenavalt õhulugeja vahetatud aga ikka annab uuesti samat veakoodi.
(see foorumite üldine probleem, et inimesed kellel igav hakkavad mingi asja kallal närima, selle asmel et parem inimest aidata)
loodan, et nüüd rahul copy-paste aitas..:)
alts20
Registreerunud 28.09.05
Auto: Audi A6
postitati 12.01.14 10:05 Tsiteeri
Vaevalt seal nüüd kirjas oli, et on õhulugeja viga.
Pane siia täpne veakood mis aktiivne oli või on ja saad kindlasti rutem abistavaid vihjeid või vastuseid
Kopeeri alati teemasse kõik see jutt, koodid ja kirjeldus mis arvuti näitas ja on edaspidi muresid ja mõttetut vaidlust vähem
[PHP: 21.5% - SQL: 78.5%]
