Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A3 8L suunatule relee
Pealkiri: Audi A3 8L suunatule relee (Vastuseid: 10 | Vaatamisi: 1569)
KuldarA
Registreerunud 26.11.11
postitati 26.11.13 12:20 Tsiteeri
Probleem selline, et 2001 A3 1.9 96kW TDI Quattro on suunatule relee läbi(vahepeal töötavad, vahepeal ei tööta). Otsin uut releed aga olen leidnud sellise:
http://www.ladu24.ee/et/ladu1/6582/3,0/64128
Seal pandud sobivateks
Audi A3, 1.6 (74kW), 9/1996-8/2000
Audi A3, 1.8 (92kW), 1997-2003
Kas neile pandi erinevaid releesid või võin südamerahuga selle osta?
postitati 26.11.13 12:50 Tsiteeri
Ära seda osta, tõenäoliselt pole seal Audi ega A3'ga palju pistmist.
Ohutulede lüliteid ehk suunareleesid on sõltuvalt aastakäigust paar erinevat varianti pluss alamvariandid orig. konksuga autode puhul.
KuldarA
postitati 26.11.13 13:04 Tsiteeri
Konksu pole. Masin aastast 2001 ehk facelift. Milline relee sinna sobiks?
postitati 26.11.13 13:38 Tsiteeri
Uus orig. (ca 45.-) jääb kalliks ?!?
KuldarA
postitati 26.11.13 13:45 Tsiteeri
Ei ole uut uurinud, aga nüüd kui mainisid, siis tuleb hinnapäring ära teha ilmselt.
Loaded
Registreerunud 09.08.05
Auto: Golf IV Variant '06
postitati 26.11.13 18:55 Tsiteeri
Forss pakkus Swagi b-osa Golf IV'le ca 14.- euri eest, vast on A3'e oma samas suurusjärgus. Välimus oli suht originaali lähedane, kuid nupu kate ise ei seisa päris nii "tihedalt" kui originaal ning veidi logiseb.
KuldarA
postitati 27.11.13 07:41 Tsiteeri
Tänud vastajatele.
A3-le b-osa ei leidnudki. Sain Forsist kõige parema pakkumise ja ostan sealt. Hind jäi 40€ kanti.
postitati 27.11.13 08:23 Tsiteeri
Viga on tavaliselt kas kangis või relees. Proovimise jaoks ka üks relee olemas, vajadusel muidugi ka kang.
KuldarA
postitati 27.11.13 08:32 Tsiteeri
Oleks auto Tallinnas, saaks proovida, aga Järvamaal kahjuks.
KuldarA
postitati 27.11.13 08:43 Tsiteeri
Veakirjelduse järgi ilmselt ei tee vahet, et kumb olla võib?
Väga tihti ei tööta. Väljendub nii, et vilgub ainult ühe korra ehk siis kui suuna sisse lülitad. Mõnikord vilgub 2-3 korda ja kaob ära. Manuaalselt edasi-tagasi klõpsustades saab suunda näidata.
KuldarA
postitati 02.12.13 08:15 Tsiteeri
Viga oli relees. 5min vahetuseks ja asi korras. Nüüd läks aga genekas :) Vanade autode hooldamise võlu, ei hakka vähemalt kunagi igav :)
[PHP: 35.7% - SQL: 64.3%]
