Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - v6 st ümber v8 ks!
Pealkiri: v6 st ümber v8 ks! (Vastuseid: 18 | Vaatamisi: 2354)
loom119
Registreerunud 10.02.12
postitati 19.11.13 13:38 Tsiteeri
v6 st ümber v8 ks!
Autoks siis audi 100 c4 2.8 quattro.
plaan oleks siis selline et sooviks v8 mootori peale panna ja küsimusi on.
Kas selle auto kast sobib v8 mootoriga kokku?
Kas keegi on seda teinud siin?
Ja pm kas on mõtet assja nii keeruliseks ajada?
Rain573
Registreerunud 17.09.05
postitati 19.11.13 13:49 Tsiteeri
Algselt postitas: loom119
Seda kas asja on mõtet nii keeruliseks ajada pead kül endakäest ise küsima. Lihtsam 4,2 mootoriga S4/S6 pole osta? Need ei maksa teabmis hingehinda.
Remo
Registreerunud 06.08.10
Auto: Mercedes-Benz , BMW , Audi
postitati 19.11.13 15:40 Tsiteeri
Sa peaks enne otsustama, millise V8 sa tahad üldse vahele panna: AQJ, AEC või ABZ? Kui selle otsuse oled ära teinud, siis saad teada, millist hooratast pead tegema hakkama:)
Got ARB and nitrous?
postitati 19.11.13 15:52 Tsiteeri
Kuna c4 kere peal 4,2 täitsa olemas ja suht heade hindadega müügis, siis ma ka ausalt öeldes asjas mõtet ei näe, aga noh võibolla on omanikul mingid kindlad põhjused selleks.
taavi9
Registreerunud 09.01.06
Auto: A6 C6 avant 3,0TDI S-line 09a.
postitati 19.11.13 16:48 Tsiteeri
Ma arvan, et v6-e kast v8 otsas kaua ei kesta.
postitati 19.11.13 17:24 Tsiteeri
Algselt postitas: taavi9
3000rpm 100km/h juures ei kesta ta tõesti, varem või hiljem on tahtmine see diisli 01E kastiga asendada :)
Kui just igapäevaselt launchimisega ei tegele, siis kestab see kast küll.
aixx
Registreerunud 21.03.05
postitati 19.11.13 18:05 Tsiteeri
Ma ei saa aru miks kõik arvavad, et mingi lisa 100kw kohe kasti ribadeks kisub. Kuigi jah teema algusesse minnes, ma prooviks sellele kerele ikka vähemalt V10t istutada- või kui töö tegemise hinda arvestada, siis pigem 2,8 üle laadida-ilmselt tuleb saranases hinnaklassis, kuid oluliselt unikaalsem sõiduk.
rix30
Registreerunud 19.04.09
Auto: Audi S3 1,8T 8L
postitati 19.11.13 20:17 Tsiteeri
No kui vaadata v10 ja v8 mootorite hinna vahet, siis vaevalt kuskilt 300-500e v10 moto leiad. V8 mootorile saad juhtmestiku pealekauba. Kasti soovitaks 01E soetada ja ilma jagajateta mootoril hooratas ju 8 poldiga, vähe lihtsam kui aec-st allapoole 10 poldiga.
Adolf Hitler!
Remo
postitati 19.11.13 20:28 Tsiteeri
Algselt postitas: rix30
Ise valiks ka kindlasti AQJ mootori (8 poldilise hoorattaga). Enamasti aga tehaksegi see viga, et võetakse vana jagajatega V8, kuna neid saab sümboolse hinnaga kätte, aga selle aretamine on vist keerulisem just nimelt selle 10 poldiga hooratta tõttu.
CE
Registreerunud 02.03.06
Auto: A4 Avant 1,9 TDI q
postitati 19.11.13 22:26 Tsiteeri
Pisike täpsustus (pigem küll sõbralik norimine :) ): C4 kerega 2,8 A6Q "pikemate" ülekannetega kasti puhul (koodiga näit. CAB) jäävad pöörded 100km/h juures ~2718rpm kanti. Manuaalkastiga S6 4.2 01E-tüüpi käigukasti (CMG) kasutades langeksid mootori pöörded 100km/h arvutuslikult puhul 2336'ni ning 2,5TDI Q kasti (DPJ) puhul 1923'ni. Kõigil C4 kerega nelikveoliste Audidel kasutati vähegi võimsamate mootorite puhul 4,11 (37/9) peaülekannet, seega kastivahetuse korral tagadifferentsiaali sobivuse pärast muretsema ei peaks.
Usun samuti, et kui hea pidamisega pinnasel "vihast" kohaltminekut mitte harrastada, ei juhtu selle V6 kastiga V8 otsas midagi paha. Võimsamate mootorite otsas oli agressiivse startimise puhul 1. käigu hammarataste vastupidavus probleemiks ka teatud 01E-tüüpi kastidel.
Käigukasti "taluvust" väljendatakse eelkõige lubatud sisend-pöördemomendiga (maksimaalne võimsus kasti vaatenurgast on sekundaarne, kui nii võib öelda ;) ). Arvestades, et näiteks 2,5 R5 TDI mootori 4,2 V8 vastu vahetades kasvab maksimaalne pöördemoment "ainult" kolmandiku võrra, peaks "traktori" kast V8 otsas mõistlikul ümberkäimisell samuti suurepärastelt kestma. Doonoriteringi laiendamiseks võiks mainida, et 01E kaste kasutati hilisemalt näiteks B5 A4 quattro masinatel, ka koos V6 TDI mootoriga.
Rain573
postitati 20.11.13 07:14 Tsiteeri
Selle kasti teema kohta võiks öelda omast kogemusest, nii et alguses oli mul küljes AXN kast millel juba 2,0 mootoriga teine käik käis vahetevahel raksuga sisse. Sellega sain sõita täpselt niikaua kui ükskord masina asfaldipeale ajasin. Esimese käiguga rahulikult minema, teine käik läks ilusti sisse, gaas põhja ja käis kõva pauk ja enam teine käik ei püsinud isegi jõuga hoides sees. See kast mis mul nüüd all on on võetud audi 80 B3 1,8 quattro alt. Millel peaks olema siis 66kw ainult ja kast hetkel töötab täiesti koralikult. Stressanud olen teda juba päris kõvasti. Tahtsin selle jutuga öelda, et kui kast on korras siis pole probleemi! :)
postitati 20.11.13 09:20 Tsiteeri
Algselt postitas: CE
Tore kui keegi viitsib kaasa mõelda:)
V6 kasti ülekanded ja kiirused ongi sellised nagu kirjutasid, ma ei viitsinud ühtul seda üle arvutada ja kirjutasin mälujärgi mida tolle masina tahomeeter mulle väitis.
01E kasti esimese käigu hammasrataste probleem oli tõepoolest ainult vanematel isenditel, kui võeti kasutusele 105H peavõll siis lahendati see mure laiema esimese käigu hammasrattaga. Ca 1996-1997 ja edasi peaks kõik 01E kastid juba selle peavõlliga olema(wide & flexible), vanemate puhul saab õnneks välise vaatlusega seda teada. Peavõlli erinevust on võimalik kindlalt määrata kasti lahti võttes (flexible või solid), kuigi jäika varianti kasutati mälujärgi ainult R5 bensiinimootoritel, V8 sh kitsa esimese käigu hammasrattaga CMG, oli juba nn vetruva peavõlliga.
Selline näeb välja ca 1993a C4 V8 CMG kasti peavõllil olev esimene käik, teisel pildil laia ja kitsa käigu erinevus.
http://datacomb.pasun.ee/albums/upload/kast/thumb_IMG_8541.pnghttp://datacomb.pasun.ee/albums/upload/kast/thumb_P4040064.JPG
loom119
postitati 20.11.13 18:02 Tsiteeri
Suured tänud tarkuste eest ;)
Aga iseenesest ma saan aru küll et lihtsam s6 osta vms,lihtsam oleks kohe rs osta :D
Ma mõtlengi kas finantsiliselt läheks väga kulukaks?sest et mootor umbes 400 ja interneti ja mõne tuttava abiga teeks selle ära niiet tööraha väga palju ei kuluks.
andres91
postitusõiguseta huviline
Registreerunud 07.04.09
Auto: b4
postitati 20.11.13 18:40 Tsiteeri
Märkus moderaatorilt: "Postitus kustutatud, kuna kasutaja ei ole vaatamata varasemale märkusele asunud järgima foorumi reeglite 3. punkti! Järgmine samm on kasutaja postitusõiguse peatamine!"
Darkdog
Registreerunud 20.03.06
Auto: Audi A6
postitati 20.11.13 18:46 Tsiteeri
Algselt postitas: andres91
kui palju mootoririhma komplekti vahetus maksab? õlid, filtrid, küünlad, võib-olla mõni leke eemaldada, ei osta ju uut mootorit. Kui need juurde lisad, siis see summa ikka muutub tublisti suuremaks. 4.2 mehed võivad öelda, mis sellise loo hinnaks on, kui tööraha mitte arvestada. Samuti tuleb asja juures ka ootamatusi, küll vaja mõni jupp otsida, siis jälle sõida, too organiseeri. Isegi, kui mootor maksab 400 võiks eelarveks 1000 eurot ikka võtta, sest varjatud kulud on ka ning ega sõbradki oma rõõmuks sulle autot ehita. See kas viskad neile sula, paned jooke lauale või mõni muu variant, siis kulu sinu rahakotist on see ikkagi.
Kõige odavamad S6 4.2 V8 auto24.ee on 1500 - 2000 €. Kui kange isu V8 järgi, osta parem S6, tee korda ja naudi, tuleb vähem peavalu ja lõppkokkuvõttes odavam.
loom119
postitati 20.11.13 18:59 Tsiteeri
Nagu ma siis soovitustest aru saan, ei ole mõtet asja keeruliseks ajada endal. Aga tänud!
nagu ma siis soovitustest aru saan ei ole mõtet assja keeruliseks ajada endal.Aga tänud!
reizor
Registreerunud 26.01.10
Auto: Õnnetud S6 2.2T, S6 4.2
postitati 20.11.13 20:07 Tsiteeri
Ostad 2000euriga automaat S6-e. Järgmine hetk hakkab kammajaa pihta, et kuidas see manuaaliks teha :D
Raika42
Registreerunud 16.11.08
postitati 20.11.13 20:34 Tsiteeri
AEC-le umbes 230€ hammasrihm koos rullide ja pingutiga. +SKF-i veepump umbes 55€ ja termostaat 10-15€
Boschi küünlad umbes 45€ komplekt.
Ühesõnaga hullu mitte midagi. Vahetus ise on kõige hullem.
rkrimm
Registreerunud 09.06.08
Auto: V8 4.2TT man projekt; S6 2,2t man.
postitati 20.11.13 20:55 Tsiteeri
Algselt postitas: Raika42
V8 mootori jupid ei maksa tegelikult palju kui vaadata üksiku detaili hinda. Hinda aga upitab see, et neid detaile on palju mis vahetust vajavad.
Automaadi manuaaliks tegemise kohapealt, et kõige raskem saab olema just hooratta leidmine. Kui see olemas siis ülejäänud on juba köömes, kaste ju iseenesest leiab vastavalt soovile ja vajadusele.
[PHP: 28.6% - SQL: 71.4%]
