Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Abi tarvis, temperatuuri anduri pistikuga. 2,5tdi
Pealkiri: Abi tarvis, temperatuuri anduri pistikuga. 2,5tdi (Vastuseid: 9 | Vaatamisi: 1820)
aivor
Registreerunud 03.04.13
Auto: a6 c5 2,5tdi quattro
postitati 26.08.13 05:11 Tsiteeri
Äkki keegi viitsiks pilti teha enda auto temperatuuri anduri pistikust. Mootoriks on 2,5tdi. 1999a. pistik peab olema must ja üks serv ovaalne. Vanema tüübi kandiline ja sinist värvi pistik on erinev. Nimelt endal tulid selle pistiku tagant juhtmed ära ja nüüd pole mille järgi neid tagasi panna.
OnuJack
Registreerunud 10.12.07
postitati 26.08.13 05:52 Tsiteeri
Mis mootori kood on?
EDIT: piisab ka kw arvust.
aivor
postitati 26.08.13 05:56 Tsiteeri
110kw
postitati 26.08.13 06:33 Tsiteeri
Korpuse peal on numbrid:
1 pruun halli triibuga
2 sinine pruuni triibuga
3 sinine lilla triibuga
4 pruun
PS. Juhtmevärvid peavad klappima. Uuematel on juba teised värvid.
aivor
postitati 26.08.13 06:50 Tsiteeri
Mul on üks pruun kollase triibuga. Pruun halli triibuga on olemas. ja numbreid peal ei ole. Pistiku ülemine osa on vähe vigastada saanud võibolla selle pärast.
OnuJack
postitati 26.08.13 07:17 Tsiteeri
Vahest on anduri korpusel ka numbrid peal.
Algselt postitas: aivor
postitati 26.08.13 07:35 Tsiteeri
Teine uuem variant:
1 Sinine pruuni triibuga
2 Pruun kollase triibuga
3 Sinine lilla triibuga
4 Pruun halli triibuga
aivor
postitati 26.08.13 07:41 Tsiteeri
Anduri peal on A B C D. Pruun kollasega jäi terveks see olks nagu A. Numbrite järgi ei klapi nagu ka selle järgi oleks 1=A pruun halliga.
postitati 26.08.13 07:57 Tsiteeri
Pistiku pilt:
http://www.audi-club.ru/photo/data/3850/G2_.jpg
aivor
postitati 26.08.13 08:09 Tsiteeri
Asi Korras, tänud abistajatele.
[PHP: 14.1% - SQL: 85.9%]
