Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - quattro GmbH
Pealkiri: quattro GmbH (Vastuseid: 4 | Vaatamisi: 2326)
Simmi2
Registreerunud 27.07.13
postitati 27.07.13 06:35 Tsiteeri
quattro GmbH
Tere,
Saatsin siis oma auto VIN koodi Audi GmbH`sse ja sain sellise vastuse :
the mentioned A4 Avant
has the following individual items:
S3G / 1BB / 1SB SCHLECHTWEGE-FAHRWERK (rough track suspension)
Teab ehk keegi midagi rääkida mida siis see täpsemalt tähendama peaks? Niipalju saan aru, et siis peaks olema vähe asjalikum vedrustus kui orginaalis (auto tundub kuidagi kõrgem ka kui tavaline A4).
postitati 27.07.13 07:03 Tsiteeri
Kehvadele teeoludele mõeldud vedrustus.
Põhierinevus võibki seisneda suurendatud kliirensis- teistsugustes vedrudes, amortides ja stabilisaatorites.
Kas just asjalikum , aga vähe erilisem küll.
postitati 28.07.13 07:10 Tsiteeri
Miks pealkiri on "quattro GmbH"? WUAZZZ-VIN-iga A4?
paranormaalne
Registreerunud 23.08.04
Auto: AAN+3B+AEL+AAN+AAN+AAN+AAN+ABY
postitati 28.07.13 17:52 Tsiteeri
Hiljuti oli juhus A4 B5-ga, mille VIN koodi (WAUZZZ) ETKA-sse sisestamise järel lõi ette hoiatuse, et jupid ei pruugi sobida ja paluti ühendust võtta Quattro GmbH-ga.
Edit: A4-ga vast jah ;)
värdsõnade leksikon - kellablokk, varjant, igastähes, nukvõll, org. eesliide - orgaaniline jagaja?, velüür, bronks, gardaan, polüretaan, millekagi, ütlematta, värvimatta, hooldamatta, tahtmatta, vahetamatta, katusetta, ostmatta, õieti vs. õigesti, kvall, sürpriis, kahedeist, oksion, pumb, doll (mõõtühik), saabgi, kellegile, tänamattu, algorütm, roolilätt, rädikas, milleGIGA, paraleel, didident, laadia, oktsion, kabasnik, pagaaznik, toonor, sumbuti, saaleviga, airbäg, bäg, gartaan
postitati 28.07.13 18:22 Tsiteeri
Algselt postitas: paranormaalne
Hiljuti oli juhus A5 B5-ga...
Vast ikka A4 B5-ga? :)
[PHP: 45.4% - SQL: 54.6%]
