Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Kas Pärnus leidub mõnda foorumi liiget ? Abi vaja . .
Pealkiri: Kas Pärnus leidub mõnda foorumi liiget ? Abi vaja . . (Vastuseid: 4 | Vaatamisi: 873)
SiimRes
Registreerunud 12.06.13
Auto: Audi a4 b6 avant 2002, Opel Corsa Ls 1985.
postitati 27.06.13 10:52 Tsiteeri
Küsimus siis selline, kas Pärnus leidub mõnda foorumi liiget, kes jagaks natuke rohkem audide hingeelust, kui mina :D
Oleks vaja paar asja üle vaadata :)
freeser
Registreerunud 24.06.11
Auto: Audi S6 2,2 20v, S3 8V
postitati 27.06.13 14:20 Tsiteeri
Nagu näiteks?
SiimRes
postitati 27.06.13 15:59 Tsiteeri
http://foorum.audiclub.ee/viewthread.php?tid=126969
Siin postituses kirjas millega .
seitsmene
Registreerunud 10.05.06
Auto: A8 4,2
postitati 27.06.13 16:25 Tsiteeri
Algselt postitas: SiimRes
Seda peab erakordselt tähelepanelikult kuulama, sest sa ütled seda ainult ühe korra?
(Listen very carefully, I shall say 'zis only once!)
sadguy
Registreerunud 16.03.06
Auto: Coupe, 9-5 T, Octavia
postitati 27.06.13 16:41 Tsiteeri
Audi Pärnu
Kui pöörata vasakus kurvis paremale, siis näeb rohkem loodust.
Sõidukite poleerimine, vahatamine ja muud iluteenused Pärnus. Meguiar´s toodete müük.
[PHP: 27.5% - SQL: 72.5%]
