Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mida tähendavad käigukasti veakoodid A8 Tdi Q
Pealkiri: Mida tähendavad käigukasti veakoodid A8 Tdi Q (Vastuseid: 19 | Vaatamisi: 2017)
allan23
Registreerunud 16.10.11
postitati 01.04.13 14:53 Tsiteeri
Auto siis Audi A8 tiptronic 1998
Koodid 18265, 17136, 18153. Ise sain aru, et multilüliti on vigane. aga sellest ei saa aru täpselt-
Transmission Control Unit Relay Short to B+ - mis tähendab Short to b+
KristjanE
Registreerunud 17.10.10
Auto: Audi 80 B3Q
postitati 01.04.13 15:10 Tsiteeri
Lühises aku +-iga, aga nii palju kui mina nendega kokku puutund olen, siis see tähendab seda, pistik on ära oksüdeerunud või juhe viga saanud ja sealt ära oksüdeerunud.
allan23
postitati 01.04.13 15:21 Tsiteeri
Aga mismoodi see aku + -iga lühis saab olla? aku on pagasnikus. Asi selles,et mul kast vahepeal töötab, vahel harva viskab avarii peale. Keeran süüte välja panen auto käima siis jälle töötab, vahel saab sõidu ära teha ja siis alles viskab avarii peale.
Kas need lülitid on esiveolisel ja quattrol 110kw/132kw erinevad?
KristjanE
Auto: Audi 80 B3Q
postitati 01.04.13 15:43 Tsiteeri
aku pluss tuleb ju igale juhtplokile külge ja on igal pool mööda auto laiali, ta ei peagi olema aku pealt lühises, vaid autost sees. Aga nagu ma ennem mainisin siis see veakood ei tähenda seda et ta lühises on, vaid on aju pistik ära ussitanud või juhe viga saanud ja sealt ussitanud. Mõnel autol on ka läbipõlenud kaitse sellise vea andnud.
allan23
postitati 01.04.13 15:56 Tsiteeri
Ma seda ussitamise asja lugesin juba jah ühes väljamaa foorumist. Tänud sulle. Aga kas seda pistikut eraldi huvitav saab ära vahetada?
Coomb18
Registreerunud 06.08.08
postitati 01.04.13 15:57 Tsiteeri
Kas sellel Transmission Control Unit Relay-l mingi tähe numbri kombinatsioon ka sulgudes järgi oli kui veakoode lugesid?
KristjanE
Auto: Audi 80 B3Q
postitati 01.04.13 16:03 Tsiteeri
Pistik lihtsalt pese puhtaks kontakti puhastajaga, uut pole mõttet osta, kui just pole nii ära mädanenud, klemmid ära muruduvad.
allan23
postitati 01.04.13 16:12 Tsiteeri
Peab uurima. Mingeid sulgusid ja numbreid ei olnud veakoodis.
allan23
postitati 16.06.13 18:41 Tsiteeri
Vahetasin autol multilüliti ära ja nüüd kast avariis kogu aeg..panin vana lüliti ka tagasi korra aga see ka ei funka enam...mis nüüd siis juhtus? Või pean koode kustutama?
postitati 17.06.13 04:24 Tsiteeri
Tasub jälgida, et multilüliti autopoolne pistik samuti korras ja korrosioonivaba oleks.
allan23
postitati 17.06.13 14:57 Tsiteeri
Nüüd nagu auto ei taha parkingu peal käima minna ka ja kui panna R ja uuesti parking siis nagu kõriseb seal multilüliti juures midagi. Eks peab ikka vaatama mis see arvuti näitab. Aa see müstika, et vana lüliti ka enam ei funkand üldse.. kast kohe avariis ja kõik. Poleks pidand näppima :), enne sai vähemalt sõita autoga nüüd enam ei saa.
allan23
postitati 17.06.13 17:17 Tsiteeri
Kui autol on muidu see lüliti viga ja panna uus lüliti , kas ta peaks kohe toimima hakkama? või on ikka vanast ajast see avariireziimi koodid peal ja siis näitab, et on avariis? Läpparit pold kohe võtta ei saand vaadata.
allan23
postitati 18.06.13 15:44 Tsiteeri
Sai siis läppariga vaadatud ja oli ainult kood 18265 selle saab ära kustutada ja siis tuleb tagasi.
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittental
Kui kood ära kustutada läheb avariist välja aga kui käigu sisse lükad tuleb tagasi avariisse.
Mis see veakood tähendab ja mis sellega teha. Mootori ajuga mingi jama?
txxxl
Registreerunud 22.11.11
Auto: Audi
postitati 18.06.13 16:17 Tsiteeri
Kas mootoris polnud ühtegi viga?
LINK
allan23
postitati 18.06.13 16:23 Tsiteeri
Ma ei vaadanud, vaatasin ainult käigukasti.
txxxl
Auto: Audi
postitati 18.06.13 16:35 Tsiteeri
Sealt võiks pihta hakktata,
1. veakoodide lugemine(mootor, igaks juhuks võiks ka vaadata uuesti kasti)
2. veakoodi tõlgendamine
3. vigase komponendi kontroll
4. remont või vahetus.
Ahti
Registreerunud 03.10.02
Auto: Q7 3.0 TDI S-line
postitati 21.06.13 17:29 Tsiteeri
Ma ei tea täpselt, kas saab neid sassi ajada, aga ega Sa juhuslikult 4-se kasti "Multifunctional switch" 5-se kasti alla ei pand? 1997 a. tulid 5-sed kastid.
allan23
postitati 21.06.13 20:29 Tsiteeri
Ei pannud . täpselt sama lüliti on.
Vaatasin mootorit ka.
00550 - Start of Injection Regulation
17-10 - Control Difference - Intermittent
Google arvab selle kohta siis mingit kütuseprobleemi või süüde vale vms.
Kuidas seda pumpa reguleerida saab? Ma graafikut ei vaadand jälle kuna pole varem puutund kokku selle vag comiga ja ei tea aga päris huvitav on näppida seda, saaks lähiajal auto korda ka siis oleks päris äge. Muidu auto käivitub ilusti ja töötab ka ilusti nagu, suitsu pole üldse..võibolla nagu jõudu vähe.
Kustutasin selle vea ära aga tuleb tagasi kogu aeg ja käigukastil tuleb kogu aeg tagasi 18265 rohkem vigu pole. Natuke isegi toimis 30 m sai sõita ilma avariita...vana lüliti oli etem sai ikka pikemalt tiirutada. Ma saan aru, et põhiviga on siis selles 00550 mis põhjustab seda jama.
Autol on muidu kütusefilter vahelt ära võetud, ma ei tea miks seda tehtud on, äkki peaks tagasi panema? ..see võib ka ju probleemide põhjuseks olla?
txxxl
Auto: Audi
postitati 22.06.13 19:11 Tsiteeri
kerge vihje
http://wiki.ross-tech.com/wiki/index.php/00550
allan23
postitati 25.07.13 16:41 Tsiteeri
Kuna autol oli kütusefilter vahelt ära ühendatud siis sai uus pandud vahele tagasi...kõik veakoodid kadusid ära. teema lukku pmst. kõik toimib.
[PHP: 24.7% - SQL: 75.3%]
