Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.5TDI V6 käivitub raskelt
Pealkiri: 2.5TDI V6 käivitub raskelt (Vastuseid: 11 | Vaatamisi: 1647)
Martin136
Registreerunud 22.01.13
Auto: Audi A4 Avant 2.5TDI 110Kw 2001
postitati 28.01.13 08:52 Tsiteeri
Külmalt ei taha korralikult käivituda!!! võtab natuke aega, et käima saada!!! milles võiks probleem olla?? kas nukkides või akus??
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 28.01.13 09:06 Tsiteeri
Algselt postitas: Martin136
:D
Nii huupi praegu pakun, minu meelest võib probleem olla selles, et midagi on viga. Samas ilmtingimata ei tarvitse olla ka, väga külmaga ongi käivitus natuke raskem.
Martin136
postitati 28.01.13 09:26 Tsiteeri
-6 ei ole eriti külm ju!!!
tl470487
aeg maha
Registreerunud 06.07.11
postitati 28.01.13 09:48 Tsiteeri
Näiteks olematu eelsüüde.
Martin136
postitati 28.01.13 10:23 Tsiteeri
eelsüüde on!!! täna näiteks läks paremini käima kui eile!!!
postitati 28.01.13 10:42 Tsiteeri
No vot, järelikult oli Hitleril täna parem tuju. Tegelikult võiks kaabli taha lükata ja auto üle vaadata. Kuna oled uus kasutaja, siis soovitaks otsida siit "otsingu" kaudu infot selle mootori vimkade kohta ja võta kohe paar viina ka ligi.;)
Et väga ei kurvastaks, või nii..
Martin136
postitati 28.01.13 12:14 Tsiteeri
Teadlik sellest mis mootor see 2.5TDI on ja olen sellega ka arvestanud!!! :D
ash
Registreerunud 28.10.02
Auto: typ85 CQ '87
postitati 28.01.13 13:07 Tsiteeri
Esiteks kas Sa võiksid palun lühendada oma hüüumärkide kasutamissagedust, teiseks see et autol eelsüüde armatuuris põleb ei tähenda, et nad ka tegelikult nii töökorras oleks.
Kolmandaks kui Sa kuuled et mootorit ikkagi raskelt ringi veab siis mina laeks esimese hooga vana aku täiesti täis ja prooviks uuesti, ehk on ikkagi asi akus. Diisel tahabki tugevamat ja korralikumat käivitusvoolu.
Mul omal oli kord ühe diiselautoga selline probleem, kus aku jäi lahjaks aga aru ei saanud et nii lahja, mootorit jõudis käiata aga tegelikukt kõrgsurvepumpa ei suutnud niipalju piitsutadada et kohe käima lööks. Pikad käiamised enne kui käima läks. Peale uue aku peale panekut oli see teema unustatud. Võibolla mõtlemisainet..
terv,
ash
Martin136
postitati 28.01.13 13:30 Tsiteeri
vabandan hüüumärkide pikka kasutamise pärast!
Vabandan hüüumärkide pika kasutamise pärast!
kosmoseklutt
Registreerunud 29.09.06
Auto: A4
postitati 30.01.13 19:46 Tsiteeri
Pooled eelsüüte küünlad on läbi põlenud.
rako
Registreerunud 29.01.13
postitati 30.01.13 20:41 Tsiteeri
Algselt postitas: kosmoseklutt
Äkki 1/3 :)
Küsikus üldiselt, millal viimane rihma vahetus oli? Kuidas oled kindel, et küünlad korras? Küünlaid käisid maas ja kontrolliti üle?
Kaabel sappa saad aimu kas kõik andurid on ikka omas õiges konditsioonis kui midagi ei leia mis takistaks otseselt käivitumist siis tuleks hakata asjaga loogiliselt tegelema. Kui see puudub siis mine spetsialisti juurte.
E: u2u võin abistada kaabliga.
Fugitive
Registreerunud 12.02.06
postitati 30.01.13 21:38 Tsiteeri
Küünalde kohta ütleks nii, et just sai enda autol otsitud põhjust miks külmema ilmaga käivitades korraks lonkas ja viskas suitsu tagant välja, sai küünlad algul testriga kontrollitud - korras, siis mahavõetud ja vool akult antud - tulemus oli see, et 2a vanad swag'i küünlad läksid punaseks 5-7sekundiga, kuid uued beru küünlad olid tulipunased juba 3 sek'iga. Uued küünlad sisse ja probleem lahendatud.
[PHP: 25.2% - SQL: 74.8%]
