Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - MMI lühises!?
Pealkiri: MMI lühises!? (Vastuseid: 14 | Vaatamisi: 1452)
timo6mblus
Registreerunud 08.08.12
postitati 04.12.12 16:56 Tsiteeri
MMI lühises!?
Tere,
Juhtus nüüd selline totter asi, et audi c6 2005a katuseluuk otsustas lampi ennast avada kui katusel oli kõvasti lund:mad: Seega oli terve salong keskelt lund täis ja MMI juhtpaneel oli lume all. Kiiresti sekundite jooksul pühkisime lume maha ja hakkasin kuivatama. Kõlab vb natuke hullult aga seda lund ei jäänud sinna palju ja silmaga vaadates kuskile pragudesse nagu lund sulama ei jäänud. Samas võin nüüd eksida, sest hommikul sõites tööle oli kõik okei aga peale tööd MMI tegi 20 sekundi pärast sellise triki, et viskas pildi kinni ja kõik juhtpaneeli tuled läksid korra põlema. Nii on iga kord nüüd kui üritan sisse lülitada.
Järelikult sai MMI aju alt niiskust ja on nüüd lühises. Kas mul on mõtet oodata ja autot kütta )nagu siiani teinud) ja vaadat ehk kaob viga ära? Samas mõtlesin ka asja lahti võtta ja ära kuivatada, kuigi pole ennem seda keskelt lahti katkunud ja läheb vist nats keeruliseks.
Flamenkos pakuti elektriku juurde aega alles järgmine neljapäev ja see on ilmselgelt liiga kaua.
Palun pakkuge oma varjante ja võib ka mõnda elektrikud soovitada.
KsenoonE
Postitusõiguseta huviline
Registreerunud 05.01.10
postitati 04.12.12 17:05 Tsiteeri
Alustuseks ehk kuskile sooja garaazi ajada ja vaadata kas aitab.
timo6mblus
postitati 04.12.12 17:06 Tsiteeri
Algselt postitas: KsenoonE
Mõtlesin ise sama
postitati 04.12.12 17:24 Tsiteeri
MMI aju ei ole nuppude all, seega on sellega kõik hästi vast. Nuppude all on indikatsiooni moodul vms. Võta kasvõi naise föön ja veeda tunnike autos puhudes sooja õhku nuppude vahele. Arvan, et hakkab tööle. Sinna on inimesed muudki valanud ja tavaliselt on kõige suurem mure kinnikleepunud nupud.
OOOO, VW, Seat, Skoda DIAGNOSTIKA, OSTUABI (võimalik üle Eesti), kodeerimine, (de)aktiveerimine, aut. kastide õli, seadistused, DPF-i, õhkvedrustuse mured, läbisõit jne. (Litsentsiga orig. Ross-Tech PRO V2 seade + alati uusim tarkvara ja 19a. kogemust). 2g, HN+, MHI2, MHI2Q uuendused, NAVI 2026-27, VIM, SpeedCam, Carplay, Android Auto aktiv. jne. Läbitud kilomeetreid ei muuda. U2U või 55547002.
timo6mblus
postitati 04.12.12 17:30 Tsiteeri
Siis on hästi :D Täna just mõtlesin, et võtaks fööni ja kuivataks sealt nuppude vahelt. Muideks flamekos öeldi jah, et see pidi nii tavaline olema kui sinna igast kohvisi ja limonaade kallatakse. Aga mehed ise väitsid, et seal all on aju mis maksab sirka 600 euri, samas kes seda väitsid on need mehed kes tööde vastuvõttudega tegelevad.
raemees
Registreerunud 18.09.09
Auto: BMW E90 320dA 2008a
postitati 04.12.12 18:16 Tsiteeri
Algselt postitas: timo6mblus
Kas tööde vastuvõtja kirjutab seal ka arve välja?
timo6mblus
postitati 04.12.12 18:29 Tsiteeri
Algselt postitas: raemees
Jah
postitati 05.12.12 05:07 Tsiteeri
Õige ka, 600 arve jätab vähemalt pikaks ajaks meelde, et auto pole kohvik.
timo6mblus
postitati 05.12.12 07:19 Tsiteeri
Eksole, aga mul hakkas nüüd mmi lambist tööle eile õhtul ja hommikul oli ka täiesti usin töötama, eks näis kas peab nüüd vastu ka, loodame parimat!!
postitati 05.12.12 07:27 Tsiteeri
Taevast sadanud lumi ja vihmavesi on üldiselt väga puhas.
Teine lugu oleks merevee või soolalumega, mis tekitaks kiiresti korrosiooni (eriti koos elektrivooluga).
postitati 05.12.12 07:32 Tsiteeri
Fööniga soovitan olla ettevaatlik. Tuttav hakkas läpaka klaviatuuri fööniga kuivatama nii 5-10cm kauguselt ja ohh üllatust... alguses vaatasime, et väga hea saab nii ja järgmisel hetkel otsustasid nupud sulama hakata ja läksid kõveraks ja seda vaid sekundiga.
juks11
postitati 05.12.12 07:36 Tsiteeri
90% vett saanud nupustikust koos elektroonikaga (ehk rahvakeeli ajuga (ja mitte MMI ajuga) - täpsustuseks Hr.Raemehele) saab korda. Väljavhetust on üliharva vaja. Kuigi iga niiskuskahjustusega elektroonika tuleks ikkagi lahti võtta ja spets ainetega ära puhastada, et vältida hilisemaid kahjustust.
A-kaheksa
Registreerunud 23.11.07
Auto: A6 C6 4,2Q, Mondeo 11
postitati 05.12.12 08:37 Tsiteeri
Igal juhul tuleb see nupustik lahti võtta. Nagu kirjutati, siis pole sa esimene mees, kellel nii juhtus. MMI nupustiku on pöördumatult kahjustanud ka paljud autopesulad. Salongi pesuainet ei pritsita lapile, vaid otse nuppudele. Nii mõnigi pesula on kliendile ostnud uue MMI nupustiku. Krooni ajal oli hind vist 25000 kandis Q7-le
Kui tahad, et asi ikka kestaks ka tulevikus, siis kindlasti lahti vaja võtta ja õieti pesta/kuivatada.
www.harteron.ee
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 05.12.12 12:54 Tsiteeri
Kas keegi ütleks ka kuidas seda lahti võtta? Endal ka ei tööta need kõik nupud sama kergelt, ilmselt kunagi midagi epale läinud...
andero
Registreerunud 03.09.03
Auto: audi a6 3.0 TDI Quattro
postitati 05.12.12 17:12 Tsiteeri
Siin näidatud vajalikud operatsioonid: http://forums.audiworld.com/showthread.php?t=2832795
[PHP: 25.3% - SQL: 74.7%]
