 Lehekülgi:  1  2  3  4
Pealkiri: 3,0 tdi 176 kW soojenemine (Vastuseid: 87 | Vaatamisi: 27117)
sospert
Registreerunud 18.05.04
Auto: q7
postitati 20.09.12 13:10 Tsiteeri
Tervist.
Kas keegi oskaks mulle öelda kui ruttu võiks selline mootor oma töö temperatuuri saavutada? Endal nüüd selline mootor Q7-me peal ja kuidagi vääääga kaua võtab, ennem kui 90 kraadi kätte saab. Eks kütus maksab ka midagi ja oleks ju tore kui saaks kuskilt kokkuhoidu.
Tänud vastajatele.
postitati 20.09.12 13:56 Tsiteeri
Technical product information
Engine temperature display fluctuates between 50° and 90° C - all TDI
Customer statement / workshop findings
At outside temperatures under 5°C the engine temperature fluctuates according to the display in the dash insert between 50 and 70°C or till the coolant temperature reaches 90°C. The phenomenon occurs mainly when driving at low engine speed.
Technical background
Because of a very good effectiveness of the engine in low rev range, little engine heat is passed on to the coolant. At low outside temperatures the coolant temperature does not reach 90°C. If the heating is used, the coolant loses further heat depending on the blower level. As a result, the coolant temperature can fluctuate between 50° and 90° C.
Below an outside temperature of 5° C and a coolant temperature of 70° C the standard PTC auxiliary heater is activated, to heat the interior.
Measure
Please do not repair, this is normal.
Customer information
A low coolant temperature has no effect on the service life of the engine. An engine oil with suitable viscosity is used.
Sul peaks ka lisasoojendi olema autos...
sospert
Auto: q7
postitati 20.09.12 14:41 Tsiteeri
Nagu ma aru saan, siis on see normaalne, et mootori temp näidik ei jõua 90-ni ruttu? Täna hommikul kui lisasoojendi tööle hakkas, siis läks küll kiiremini. Või vahetan termostaadi ikka ära - nö igaksjuhuks?
audi121
Registreerunud 30.09.09
Auto: a6 2004 3.0 tdi
postitati 20.09.12 18:24 Tsiteeri
Endal 3.0 tdi a6-e peal ja varem läks kuidagi kiiremini soojaks. Kahtlustan kah ,et termostaat õhtal ja siis juba jahutusvedelik ka uus.Endal webasto puudub aga seda asendab elektriline radikas mis läheb automaatselt tööle koos mootoriga aga sul see vist puudub ,kuna sul webasto.
sospert
Auto: q7
postitati 20.09.12 19:16 Tsiteeri
Nii, termostaat vahetatud. Sai originaal pandud. Mitte midagi ei muutunud. Tähelepanekuid nii palju, et kui vahetama asusin, siis oli mootori temperatuuri näitaja armatuuris ca 70-ne peal. Samas jahutusvedelik, mis termostaadi korpuse vahelt välja pressis oli ikka väga kuum - kõik auras ja põletas näppe. Kas äkki selline variant, et näidik armatuuris näitab midagi muud kui mootori temperatuuri? Jahutusvedeliku tempi kuskil mujal kui plokis? Lihtsalt selline mõte tuli pähe. Ega ma ei kurda otseselt sooja puudumise üle, sest hommikuti hakkab sooja ikka väga ruttu tulema. Lihtsalt vana kooli inimesena ma arvasin, et mootor peab ikka ruttu 90-ne peale jooksma. Lugedes seda inglisekeelset juttu võib ju aru saada, et näidik võibki pendeldada 50 ja 90 vahel uuematel autodel. Äkki uuematel autodel on asjad teis moodi?
Targemad võivad täiendada.
postitati 20.09.12 19:19 Tsiteeri
Algselt postitas: sospert
Ja 70 kraadine jahutusvedelik ei peaks kuum olema inimnahale? Uuematel autodel ei või pendeldada ma arvaks, mul a4-l seisis punkti pealt õiges kohas sõltumata ilmast ja oludest, külmaga lihtsalt võttis selle punktini jõudmine sutike rohkem aega.
postitati 20.09.12 19:31 Tsiteeri
Temperatuuri seier ei näita seda mis mootor on see on juhile rohkem rahustuseks et kõik ok. Kui mootori reallne temp on umbes 70 võib kell juba 90 näidata samuti ka 100 klaadi juures. Need näidikud kõik nii tehtud, et juht ei närveeriks. Paljudel uutel autodel pole ültse enam temp näidikuid. 70 kraadine vesi ongi väga kuum ja põletab. Diisel lähebki pikemalt soojaks. Kui ta sul maantesõidul tempi hoiab siis on ok.
Fugitive
Registreerunud 12.02.06
postitati 20.09.12 20:31 Tsiteeri
Algselt postitas: audi_a4_v6
Uuematel autodel ei või pendeldada ma arvaks......
No krt, kui keelt ei mõista siis kasutagu või google-translate'i... On ju selgelt kirjas:
"Because of a very good effectiveness of the engine in low rev range, little engine heat is passed on to the coolant. At low outside temperatures the coolant temperature does not reach 90°C. If the heating is used, the coolant loses further heat depending on the blower level. As a result, the coolant temperature can fluctuate between 50° and 90° C."
Tõlge:
"Tänu suurele mootori efektiivsusele madalatel pööretel, väga väike osa mootori soojusest on jahutusvedelikule edasi antud. Madala välisõhu temperatuuri puhul jahutusvedelik ei soojene 90 kraadini. Kui kasutatakse salongisoojendust siis võib jahutusvedelik veelgi rohkem jahtuda, oleneb salongiventika kiirusest. Tulemuseks on see, et jahutusvedeliku temperatuur VÕIB VARIEERUDA 50 ja 90 kraadi vahel".
end3l
Registreerunud 27.06.07
postitati 20.09.12 20:44 Tsiteeri
10, +-5 min olenevalt õhutemperatuurist ja ilmast. Mida kuid edasi praegu, seda aeglasemalt läheb:D Õnneks Webasto pult aitab ning auto on alati sisse istudes soe, olgu väljas palju tahes. Istmesoendustest puudust ei tunne.
vedru
Registreerunud 07.01.07
Auto: Auditu
postitati 21.09.12 05:05 Tsiteeri
Just vaatasin, sooja hakkas tulema mõne minuti möödudes, seier ronis 90 kraadi peale umbes 10 minutit ja 8 km. Linnasõit siis.
postitati 21.09.12 05:18 Tsiteeri
Algselt postitas: Fugitive
No krt, kui keelt ei mõista siis kasutagu või google-translate'i... On ju selgelt...
Äkki võtaks vähem emotsioonikalt, ta rääkis üldiselt "uuematest autodest", kas kõigil nii? Vähemalt bensukatel pole mina tähele pannud sellist käitumist, diislitel on seega tavaline nähtus?
Fugitive
postitati 21.09.12 05:52 Tsiteeri
Enamusel uuematest traktoritest on elektriline salongiradikas, seepärast hakkab sooja puhuma üsna ruttu.
Algselt postitas: vedru
Bensukas eraldab soojust ikka kordades rohkem kui diisel, seepärast polegi bensukatel sellist probleemi :)
A-kaheksa
Registreerunud 23.11.07
Auto: A6 C6 4,2Q, Mondeo 11
postitati 21.09.12 07:36 Tsiteeri
Jah, see on uuemate diislite probleem. Võimsad ja samas ökod mootorid. Mersul alates 2000 algusest, kui tulid CDI mootorid, ei lähe maanteel talvel seier üle 70c ja sooja isegi tuleb salongi kesiselt.
Sospert, ma loodan, et sa ikka sõites ootad soojenemist. Külmalt käivitades ja kohapeal tiksudes ei soojene mootor kunagi piisavalt. Väga külmaga oleks mõistlik kohapeal mootorit soojendada ca 1 minut. Sõites soojeneb mootor kiirema aja jooksul, õlitus muutub paremaks ja mootori kulumine väiksemaks jne.
www.harteron.ee
postitati 21.09.12 07:51 Tsiteeri
Mitte midagi ei ole katki, nagu ka Audi TSB-s kirjas.
postitati 21.09.12 09:36 Tsiteeri
Eks need, kes suvel traktoristideks hakanud, püstitavad veel nii mõnegi sellise teema. Uute ökodiislite mure see ongi, et salongi sooja saada, kuna energia kulutatakse edasiliikumiseks, mitte vee keetmiseks.
erki.t
Registreerunud 06.07.06
Auto: Got burger? (Jeep)
postitati 21.09.12 12:20 Tsiteeri
See 6 - 12 EUR mis kulub bentsukal tartusse sõites rohkem, tagab lõppkokkuvõttes rahulikuma hingamise ja mugavama elu? ;)
postitati 21.09.12 16:26 Tsiteeri
Algselt postitas: erki.t
TFSI mootoritel on juba sama probleem. Bensiinimootor hakkab lihtsalt diislile järgi jõudma ona ökonoomsuselt.
veekaheksa
Registreerunud 07.09.03
Auto: A4 TDI quattro, S8 40V
postitati 21.09.12 16:51 Tsiteeri
Sooja saad sa just täpselt niipalju, kui sa kütet põletad. Kui kütet ei põleta, siis ei saa sooja ikka kah. Loomulikult peab olema termokas korralik ja suurema külmaga(alla -10C) soovitan soojalt ikka mingi katte radikale ette süstematiseerida. Esiteks seisab kauem soe, teiseks soojeneb kiiremini.
soojade soovidega,
veekaheksa
erki.t
postitati 21.09.12 17:01 Tsiteeri
Ajalugu kordub ?
Mäletan veel papitükkidega nõuka rauda ringi vuramas... mõnel volgamehel oli suisa termantiinist kate õmmeldud.
Mõnus ju... ostad omale 40 000EUR eest auto ja siis lähed nillid Euronicsi prügikastist omale papityki radika ette :D
Wolf123
Registreerunud 27.04.11
Auto: B4 Coupe
postitati 21.09.12 17:09 Tsiteeri
Oman 2.5td 103kw a6 c4. Kui väljas 10 kraadi, siis linnas ca 4-5km sõitu ja 90 kraadi ilutseb kellal ning salongi puhub kuuma. Kõik andurid vahetatud, uus termoastaat, jahutusvedelik ning ka kliima kinnitab seda 90 kraadi ( kelladeplokile ja kliimale erinevad andurid )
Mina võin rahulikult öelda, et konkreetselt minu 2.5td läheb kiiremini soojaks, kui endine 2.0 bensiin 85kw b4.
Võimalik, et asi selles, et dislakal automaat kast ning linnas pidevalt pöörded 1500-3000 vahel.
Samas kohapeal tuksudes võingi seda 90 kraadi ootama jääda. Olemas elektriline soojendusradiaator ning ei kurda. Täna hommikul oli 5.5 kraadi, autole 2x eelsüüdet ning käis nagu kell. Natuke maad sõita ja õrnalt puhus juba leiget.
postitati 21.09.12 17:11 Tsiteeri
2x eelsüüdet ei ole küll nüüd vajalik selle ilmaga.
Seda võib ehk -20ga ja alla proovida ;)
Wolf123
Auto: B4 Coupe
postitati 21.09.12 17:15 Tsiteeri
Kuna mul autol aku kehvake, siis igaks juhuks andsin, et ikke tööle jõuda.
77aH ning väsinud aku on ikka sellele mootorile liiga lahja.
90+ah on normaalne.
erki.t
postitati 21.09.12 17:23 Tsiteeri
Vabandust aga teema on siiski üsna kaasaegse diiselmootori iseloomu lahkamiseks, mitte mõne histoorikuomaniku egotripiks mõeldud.
Wolf123
Auto: B4 Coupe
postitati 21.09.12 17:36 Tsiteeri
Kas mitte kaasaege disla ei peaks kiiremini soojenema?
Vaevalt nüüd Audi taandarengut tegi ( va. 2.5td v6, mis ongi ebaõnnestunud oma kuulsate nukkade poolest )
Kuid jah, eks Eestlase kadedus ole piiritu.
Minu isend põletab maanteel alla 6l ning linnas lühikesed ( 1-2km sõitu ) 10-11 liitrit.
Minu postituse mõte oli selles, et kirjeldada, kui kiirelt võiks auto 90 kraadi kätte saada.. Räägin oma kogemustest.
Soyer
Registreerunud 14.06.05
postitati 21.09.12 18:43 Tsiteeri
Algselt postitas: Wolf123
Teema point ongi see, et kaasaegsed diiselmootorid on nii ökonoomseks tehtud ja sellega kaasneb ka paratamatult soojusenergia puudumine. Seoses oma tööga olen pidanud talvel omajagu kontrollima klientide kaebust et masin ei lähe hästi soojaks ja tühikäigul seistes võib salongi päris ära külmuda ja seda ka väikestel bensukatel.
 Lehekülgi:  1  2  3  4
[PHP: 8.6% - SQL: 91.4%]
