Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A6 2,5 tdi 85 kw mootoririhma ja pumbarihma märgid
Pealkiri: A6 2,5 tdi 85 kw mootoririhma ja pumbarihma märgid (Vastuseid: 15 | Vaatamisi: 1999)
renet28
postitusõiguseta huviline
Registreerunud 15.08.12
postitati 16.08.12 17:09 Tsiteeri
Kas keegi oskab aidata A6 2,5 tdi 85 kw kust leiaksin mootoririhma ja pumbarihma märgid on äkki mingi leht selle jaoks olemas
sults
Registreerunud 17.02.05
Auto: audi a6 2.5TDI 103 kw AEL Quattro
postitati 16.08.12 17:17 Tsiteeri
Algselt postitas: renet28
Kasuta natuke otsingut,selle kohta infi palju.
renet28
postitati 16.08.12 17:19 Tsiteeri
Arvata on ,et olen otsinud netist aga seda vajalikku pole ju leidnud miks ma muidu küsin
ülks
Registreerunud 04.12.04
postitati 16.08.12 17:20 Tsiteeri
Vaata siia. :)
www.teemetünni.ee
renet28
postitati 23.08.12 16:30 Tsiteeri
mootori surnud seis
kas keegi seletab mulle kuidas on vända ja nukkvõlli surnud seis a6 2,5 tdi 85 kw
Kas keegi seletab mulle, kuidas on A6 2,5 tdi 85 kW vända ja nukkvõlli surnud seis?
andrec
Registreerunud 07.10.06
Auto: A4 B6 R30 VR6 turbo
postitati 23.08.12 17:03 Tsiteeri
Nukvõllile läheb tagant plaat peale, võtad pumba rihmaratta ära nuka küljest. Väntvõlli saad siis paika, kui 0 paistab hooratta pealt kasti august.
http://img52.imageshack.us/img52/8876/v230202.png
http://img843.imageshack.us/img843/3773/a130037.png
J.Aru
Registreerunud 28.07.12
postitati 06.06.14 19:56 Tsiteeri
Kas hoorattal võib ka 0 asemel sügav sälk olla või äkki saab seda ülemist surnud seisu ka kuidagi muud moodi kontrollida kui hoorattalt vaadates?
spool
Registreerunud 27.10.10
postitati 07.06.14 08:20 Tsiteeri
Jah võib ka sälk olla. Keera eelsüüteküünal maha ja katsu mingi pika kruvikeeraja või asjaga kusmaal kolb on ja paralleelselt vaata sidurikoja ovaalsest avast kas sälk/märk paistab.
J.Aru
postitati 07.06.14 10:55 Tsiteeri
Algselt postitas: spool
Kuidas kolb olema peab, päris üleval? Ja kas tuleb vaadata esimese silindri ehk siis auto ninapoolset kolbi?
spool
postitati 07.06.14 16:51 Tsiteeri
Algselt postitas: J.Aru
Jah, päris üleval. Jah, ninapoolne kolb.
J.Aru
postitati 09.06.14 08:26 Tsiteeri
Algselt postitas: spoolJah, päris üleval. Jah, ninapoolne kolb.
Suured tänud! Nüüd saan vaadata kas väntvõll ja nukkvõll omavahel paigas, peale seda keeran süüte paika ja vaatan kas hakkab auto lõpuks starteriga käivituma. :)
J.Aru
postitati 10.06.14 20:32 Tsiteeri
Vabandust, et kaks postitust järjest... Sain täna auto lõpuks võtmest käivituma, süüde oli rängalt varajane. Aga mingi kahtlane üsna valju klõbin on sees. Kuidas see sälk seal augus täpselt olema peaks, augu keskel? Mul hetkel rihitud augu ülemise servaga, kas see võib klõbinat põhjustada?
spool
postitati 10.06.14 21:46 Tsiteeri
Pildi peal on ju konkreetselt näidatud, et augu ülemine äär on ovaalne ning alumine sirge. Märk pannakse sirge ääre järgi. Teistpidi on seda ava võimatu vaadata minu arust.
J.Aru
postitati 11.06.14 11:30 Tsiteeri
Ma ei oska nendest joonistest ikka korralikult aru saada :(Panen parem pildi. Kas siis sellel autol peab olema ülemise servaga sälk (pildil vale sälk)? See on sirge serv ja alumine on ovaalne...[img=http://s28.postimg.org/zef08ekp5/2014_06_05_579.jpg]
spool
postitati 12.06.14 08:32 Tsiteeri
http://www.upload.ee/image/4101491/01Etrans.jpg
Õige ava on tähistatud sinisega, mul on selline tunne, et sinu poold pandud pildil on hoopis rohelisega tähistatud ava.
J.Aru
postitati 12.06.14 12:22 Tsiteeri
Normaalne... Mina vaatasingi koguaeg seda rohelisega märgitud auku ja ei osanud teist otsidagi kuna see oli ka ovaalne. Igastahes suured tänud veelkord ja autojuures katsun selle õige augu ka ülesse otsida ning sellejärgi märgid paika panna. :)
[PHP: 32.2% - SQL: 67.8%]
