Pealkiri: Audi A4 B5 2.8 V6 142kw - 1997 - copypaste (Vastuseid: 13 | Vaatamisi: 3392)
copypaste
Registreerunud 13.06.11
postitati 20.09.11 17:15 Tsiteeri
Tervist kõigile! teen ka oma autost teemat, n.ö. päeviku..
Auto ostetud juunis 2011 Viljandis, muidu toodud Šveitsist,
sõidsin ära juba umbes 4000km
reaalne kütusekulu linnas 11-12 liitrit sajale
auto andmed ja muu info:
Mark: Audi
Mudel: A4
Mootor: 2,8 142kw
Käigukast: Manuaal (5-käiku)
Keretüüp: Universaal
Värvus: Must met.
Vedavsild: Esivedu
Ls: 268000km
V.a: 10-1997
Engine: ACK № 039 365
Power = 142 kW (193 hp).
: = 2.80 l
Country Code: X4B
Date prepari.: 06/10/1997
Model Year: 1998
PRCode: 0G1 = gearshift lever
PRCode: 0JF = weight category front axle weight range 6
PRCode: 0YE = weight category rear axle weight range 5
PRCode: 1AJ = anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
PRCode: 1BE = sports suspension/shock absorption
PRCode: 1G3 = alloy spare wheel with original equipment tires
PRCode: 1LB = disc brakes, front
PRCode: 2PV = leather trimmed sports steering wheel
PRCode: 3FA = without roof insert (standard roof)
PRCode: 3S2 = black roof rails
PRCode: 4UE = airbag f. driver a. front seat passenger
PRCode: 5RG = right outside rear view mirror, convex on large brace, plus panorama mirror
PRCode: 5SL = outer left rear view mirror: non-spherical
PRCode: 8AV = without radio, with loudspeaker connections
PRCode: 8GL = alternator 120A
PRCode: 8RM = eight loudspeakers (passive)
PRCode: B0F = component parts set, complying with vehicle type for Switzerland, various parts
PRCode: C1L = cast alloy wheels 7J x 16 five-arm style, offset 45
PRCode: H6U = tires 205/55 R 16 91W
PRCode: J0L = battery 340 A (70 Ah)
PRCode: M7F = 6-cyl. gasoline eng. 2.8 L/142kW V6 5V catalytic converter, MVEG 2 base engine is T7F
PRCode: T7F = components for base engine, unit 078.2
PRCode: X4B = national sales program Switzerland
Veljed KOSEI SNIPER 17"x8" (olemas dokument hooldusraamatus, autole paigaldatud nad 1998 aastal)
Iluvõre ei mäleta mis firma oma, pärast lisan
Pilte:
http://img843.imageshack.us/img843/520/img7703p.jpg
http://img683.imageshack.us/img683/2114/img7702c.jpg
http://img33.imageshack.us/img33/1084/img7710z.jpg
http://img829.imageshack.us/img829/1756/img7714pz.jpg
http://img199.imageshack.us/img199/1075/img7719u.jpg
http://img849.imageshack.us/img849/7505/img7721n.jpg
http://img694.imageshack.us/img694/9978/img7729s.jpg
Lisan ka uusi pilte värvitud kapotiga lähimal ajal
Autol tehtud:
267000km
õli poolsünt Valvoline,
küünlad Bosch,
õlifilter Knecht
klapikambrikaane tihendite vahetus - Elring
http://img189.imageshack.us/img189/928/07082011048.jpg
rooliotsad TRW (ostetud, aga praegused ka veel enamvähem korras, varsti lähevad vahetusse)
19.09.2011 läks värvimisse kapott iluvõrega
Vaja teha:
Püsikiiruse juhtplokk jamab, vaja uut leida
Põhikaitse paigaldada (olemas)
Sooviks iluvõrele panna S-line silti, äkki on kellegil pakkuda?
Auto praegu müügis aga ilmselt jätan endale kui head pakkumist quattro vastu ei tule.
Olen ikka väga rahul, puudu jääb ainult nelivedu(
postitati 20.09.11 17:49 Tsiteeri
Ei kena liikur. Pidin lihtsalt nokkima. Kas kw jääb ikka väheks 2.8 puhul, peaks küll jaguma ju esivedulise jaoks, et S-line märki ette tahad?:D Suts üle aasta tagasi taheti esinduses eesti rahas 300eek kuskil ning sama palju klambri eest.;) PS! Avatar pole just reeglitega kooskõlas juhul kui see sinu liikur pole. :P
copypaste
postitati 20.09.11 17:53 Tsiteeri
Algselt postitas: Quattru
Tänud! S-line märk annab juurde 36kw :D ei lihtsalt iluvõre näeb kuidagi tühi, muud midagi, vb ka jääb nii nagu ta on või panen tagasi audi märki. :)
Avatari muudan ära!
Ricky
Registreerunud 10.06.09
postitati 20.09.11 18:23 Tsiteeri
Kas see Kamei võre ei ole? S-i märgi asemel siis "Kamei" märk
http://www.autostyle.co.za/data/products/65742aaee56d759dd8e2_large.jpg
Masin muidu ilus(Y)
postitati 20.09.11 18:29 Tsiteeri
Algselt postitas: Ricky
[img]http5742aaee56d759dd8e2_large.jpg[/img]
Masin muidu ilus(Y)
Esimesel pildil paistab võrel audi rõngaste kohad? Ise eemaldasid need rõngalt sellelt võrelt, et kuidas kinnitusel seljuhul olid?
Patrick
Registreerunud 31.03.07
postitati 20.09.11 19:13 Tsiteeri
Tundub päris sile liikur olevat;). Sellest on küll kahju,et nelik pole. Vaatan,et oled suunad parkidena põlema pannud või mis?!
Ja pole küll oluline aga pean mainima,et tere tulemast ´´xxx BDS´´ nr. kombinatsiooni:D.
Isiklikult soovitaks orig. võre ette panna!
Patrick.
AndresL
Registreerunud 30.07.10
Auto: Audi A6 C5 2.5TDI 132kw. Quattro 2003
postitati 20.09.11 19:26 Tsiteeri
Minu silmis need Audi rõngad teevad selle molu ikkagi kõige nägusamaks. Igasugused kameid ja s-line´d on veidi mööda. Alati kui linnas sõites kohta Audit millel märgita võre hakkab suu nurgast vett jooksma ning isu tekib Rakvere keefirimarinaadis šašlõki vastu.
copypaste
postitati 20.09.11 21:58 Tsiteeri
Masin muidu ilus(Y)
Tänud! Jah, on vist Kamei.. kust seda Kamei märki kätte saab? Peab ebays vaatama..
Esialgu oli audi märk jah, kinnitused siis nagu sisseehitatud poldid, ning käivad kummikesed peale kui poldid on iluvõrest läbi.. ei tea kas on arusaada)
Algselt postitas: Patrick
Patrick.
Thank you! Kahju jah, et pole nelivedu, ei kujuta ette kuidas nii madala autoga talvel sõita on :) aga eks vaatab)
Jah, suunad sõbraga tegime USA style (kaheniidiline lamp)
Sa pole esimine kes soovitab originaalvõre ette panna.. Homme-ülehomme saan auto kätte siis vaatan k uidas ta matt-mustana välja näeb ja siis otsustan.
BDS = Badass :D
Algselt postitas: AndresL
Ei oska öelda mis sellel võrel nii väga mööda on, eks see on maitse asi.
copypaste
postitati 25.09.11 16:17 Tsiteeri
kapott + iluvõre värvitud
iluvõre must matt
pildid:
http://img824.imageshack.us/img824/255/23092011068c.jpg
http://img26.imageshack.us/img26/5894/23092011067.jpg
Patrick
postitati 25.09.11 16:47 Tsiteeri
Algselt postitas: copypaste
iluvõre must matt
pildid:
Uus värv on uus värv-pole midagi halba öelda:cool:. Aga orig. võre võiks ikkagi olla:D
postitati 25.09.11 16:54 Tsiteeri
iluvõre must matt
pildid:
kinnita mingi valemiga sinna praegusele võrele ka audi rõngad oleks ikka maru hea:D
Tegelikult tahtsin küsida palju kapotti värvimine kokku maksma läks? (Võid privaatteadetesse saata ka.
copypaste
postitati 25.09.11 17:01 Tsiteeri
hehe :)
okei, eks ma panen see audi märk korra tagasi, teen pilte ja vaatan äkki jääbki sinna :)
läks maksma värv 29 eurot 0,5 liitrit, ja onu värvis
muidu selline töö maksab 80-100 eurot (kokku) kui tekib huvi annan kontaktid :)
copypaste
postitati 03.11.11 17:24 Tsiteeri
hiljuti vahetatud tagumine rattalaager ning auto sai toonitud!
http://img256.imageshack.us/img256/24/sam0667s.jpg
http://img507.imageshack.us/img507/534/sam0665.jpg
võib pakkuda vahetusvarjante quattro audi vastu (a4, a6, a8)
Hiljuti vahetatud tagumine rattalaager ning auto sai toonitud!
Võib pakkuda vahetusvarjante quattro Audi vastu (A4, A6, A8).
RTamm
Registreerunud 25.10.10
postitati 03.11.11 18:51 Tsiteeri
Jääme endiselt Audi rõngaid ootama võrele :D. Muidu masin ilus ja sile.
[PHP: 19.3% - SQL: 80.7%]
