Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4/S4 B5 (Typ 8D, 1994-2001)
 Lehekülgi:  1  ..  20  21  22  23  24  ..  29
Pealkiri: A4/S4 B5 (Typ 8D, 1994-2001) (Vastuseid: 700 | Vaatamisi: 203843)
postitati 22.01.13 21:15 Tsiteeri
Algselt postitas: R-I-X
Algselt postitas: Rahvaauto
Tundub mulle õige valik, oskab keegi kommentaare jagada:
http://www.auto24.ee/used/1226545
Hind tundub pisut krõbe arvestades, et veab ainult üks sild, tegemist on sedaaniga, tavaline riide sisu ja veel pre facelift.
Kui tegu isendiga nagu pildil, mis sirab igast otsast, ei kolise ega lonka, vägaheas korras paistva salongiga, siis leian küll, et hind on suhtkoht öiglane, küll aga paljusid häirib, et aastalt vana ja pole FL ning quattro.
Mina isiklikult ei näeks selles meeletut probleemi, tähtis on see, et ei peaks kuu-kahe vöi poole aasta pärast hakkama sadasi € sisse loopima, et isend turvaliselt söidaks/töötaks.
Värvuselt on ka päikesepaistes ja puhtana ilus.
Kapotialune maaling on maitseasi, kui neid kujundeid seal poleks, kannataks kuidagi välja, sest paljukest seda ikka näed.
Kui meeldib ja huvi on, siis kindlasti vaata ja tee otsus.
Läbisöidus ära lase ennast eksitada, sest seda saab nagunii kaheti vötta. Saksa suur riik ja selline pisike läbisöit, kahtlus on enivei, kuid see selleks.
Kütusekulu on töesti veidi koomiline, millele ka Tönis tähelepanu juhtis, liiter vöi poolteist körgem on juba usutavam.
Isiklikult arvan, et üldine keskmine pigem 8-9.
Elxx
Registreerunud 11.04.12
postitati 23.01.13 05:22 Tsiteeri
Kütusekulu jah rohkem nagu 1.9TD oma seal kirjas:D
Enda esiveoline 1.8 92kw võtab 7/8.2/9-10L/100km,see siis nii suvel 17" laiematega kui ka talvel 15"-ga,erilist vahet pole märgata.Turbokas ei tohiks väga palju rohkem võtta,vb aind kui tallata rohkem:D
Töökaaslane lasi 1.8T avandiga tallinnas 12L/100km,aga ta vähe tallub ka rohkem:P
postitati 23.01.13 06:33 Tsiteeri
Algselt postitas: Elxx
Enda esiveoline 1.8 92kw võtab 7/8.2/9-10L/100km,see siis nii suvel 17" laiematega kui ka talvel 15"-ga,erilist vahet pole märgata.Turbokas ei tohiks väga palju rohkem võtta...
Tehaseandmete järgi on turbokas ökonoomsem ja kui kasutada natuke agressiivsemat sõidustiili, siis sama soorituse juures arvan, et vahe käriseb veelgi.
Tamar
Registreerunud 16.12.10
postitati 23.01.13 06:37 Tsiteeri
Minul keskmine 9.3l/100. Autoks 1.8T. Algul mõtlesin ka korraks (ma ei tea mis mul ajudega toimus) vabalthingava B5 ostu peale aga tänan õnne et nii debiilset otsust ei teinud. Muidugi maitse asi :) Ja muidugi vabalthingavate autodega minekut võrrelda ei saa, ja kui lahjaks jääb, siis saab vuntsu juurde anda.
postitati 23.01.13 06:50 Tsiteeri
Algselt postitas: Tamar
Vabalthingavaga ei teki vähemalt tuunimise mõtet, jääb rohkem raha rahakotti:) Aga alati jääb ju lahjaks?:cool:
xpr
Registreerunud 10.10.05
Auto: e46 330d
postitati 23.01.13 07:33 Tsiteeri
Mul A4 avant 1.8TQ keskmine 12.3/100 -le. 90% on linnasõit ja lühikesed otsad - ilmad ka külmad. Kui vähem vajutada, saaks 10 kindlasti hakkama.
postitati 23.01.13 08:09 Tsiteeri
Algselt postitas: xpr
Ma arvan, et siinkohal on mõistlikum võrrelda tehaseandmeid, selleks need enamasti sobivad, sest igasugu subjektiivsete faktorite arv on viidud miinimumini. Muidu tuleb siia ca 25 postitust, kus sama mootoriga masinal sadakse linnakuluks ühel äärmusel 8l ja teisel 25l ning ülejäänud seal vahel, mis me siis selle infoga peale hakkame:P
Erki_P
Registreerunud 21.01.13
postitati 23.01.13 21:04 Tsiteeri
http://auto.motors24.ee/vehicles/379399-Audi-A4-1996.aspx?pg=1&sort=paid
oskab keegi selle isendi kohta midagi kommenteerida?
-vr6-
Registreerunud 06.12.12
Auto: Audi cabrio & A4 TQ
postitati 26.01.13 14:30 Tsiteeri
Mina leian kui on soov osta audi ,siis quattro milleks osta poolik audi?
Audi paranda ja naudi!
ragnara
Registreerunud 23.03.12
Auto: A4 b9 2.0TDI Quattro
postitati 26.01.13 16:11 Tsiteeri
Seljuhul peaks kõik maasturi mehed ostma Land Rover disco 3-4? Quattrol on üldjuhul , suurem kütusekulu, rohkem sillaosi mida vahetada jne. Suures laastus peaks ikka vastavalt rahakotile ostma auto, et suudaks hooldada jms.
postitati 26.01.13 16:19 Tsiteeri
Algselt postitas: ragnara
Õige jutt, kuigi quattro on hea, ei pea kõik seda omama ja ilma selleta on auto ka auto!
postitati 26.01.13 20:34 Tsiteeri
Algselt postitas: audi_a4_v6
Vajadus söltub ka sellest, mis oludes on peamine söit.
Maakohtades, kus peamagistraali ja kodukoha vahele jääb teelöik, mida ise ei hoolda ja korraldatud teehooldus käib , kuis jumal juhatab, siis nelikvedu on oluliselt efektiivsem, kui pooleveoline.
Minule on isiklikult möistmatu vaatepilt, kus isik omab maasturit (Hummer, Landcruiser jne jne ), kuid peamine trass jääb linnas tööle söitmiseks max 5-10 km raadiusesse (pealinna vördluses nt. mustamäelane söidab tööle Ülemiste keskusesse). Ma ei ole kade!
Nelikvedu ei ole töesti ka köikvöimas, kuid tunnistan, et järgmist autot tahan siiski omandada nelikveolisena.
ragnara
postitati 26.01.13 20:55 Tsiteeri
Võibolla nädalavahetusel kasutab oma maasturit metsas sõitmiseks. Näiteks on jahimees vms? Kuid ei vaidle vastu, nelikveol on eeliseid palju, ainus miinus ongi see, et rohkem hooldust nõudvaid detaile, kuid ma usun, et kõik see mida nelikvedu pakub, kaalub need kulud üle.
mtaudi
Registreerunud 26.02.07
postitati 26.01.13 21:02 Tsiteeri
Mida ta nii erilist siis pakub Sulle??? Igapäevaelus mööda tavalisi teid sõites ei anna see nelikvedu suurt midagi juurde ja ei ole ma ome monovedusega ühtegi hange veel kinni jäänud - ka maateedel, kus lund ei lükata eriti - ei ole vaja seda kõigile peale pressida - ma ei väidagi, et see hea ei ole, aga quattro ei ole mingi imepill, mis oleks kordades esiveolisest üle - pigem natuke parem. Olulisem on auto juures pigem see, kas see meeldib, mis mootor peal on jne jne. Tänapäeva autode ESP-d suudavad esiveolisega juba sama hästi teel püsida, kui rallisõitja nelikveoga, aga vaevalt siin kirjutanutest keegi rallisõitja on.
[edit] pealgi on quattro märgi all palju erinevaid nelikveoskeeme, kuid selle auto teema all ei räägi me just viimastest, mis arvestavad veojõu suunamise juures ka külgkiirendust ja rooli asendit, nagu seda näiteks A5 ja S5 Q puhul, mille tarbeks tegi quattro gmbh täiesti uue nelikveosüsteemi: http://www.youtube.com/watch?v=ETCJoIzn7eo
B5-el ei ole kaugelti sellist süsteemi - ehk siiski vaid kaks ratast veavad, kuna ka diffrilukku ei ole.
-vr6-
postitati 27.01.13 07:08 Tsiteeri
B5el on tagumine diffrilukk täitsa olemas seda EDL-i vms näol. Läheb elektrooniliselt lukku.
postitati 27.01.13 07:56 Tsiteeri
Algselt postitas: -vr6-
No päris diffrilukust ma olen aru saanud, et sel juhul ikkagi ei räägita, aga võimalik, et ma eksin.
postitati 27.01.13 09:51 Tsiteeri
Algselt postitas: mtaudi
Räägime uuesti, kui oled ühe talve quattroga sõitnud. ;) Kasvõi sellesama B5-ga täiesti sileda lumise tee peal..
Ma sõidan hetkel ESP ja torsendifferiga volksiga ja pärast igat käivitust käib sõrm kiirelt ESP-nupu kallal. Vahel ununeb ja siis tekib hiljem tavaliselt liiklusohtlik olukord. Kaks juhti jäägu õppesõiduautosse.
xpr
Auto: e46 330d
postitati 28.01.13 08:54 Tsiteeri
(vaidlused veoskeemide üle kustutatakse hoiatamata!) - Siin võiks samamoodi teha.
Igaüks kiidab oma vedu. Selge on see, et 4 vedu on parem aga kulukam.
Ennem olnud kõik esiveolised autod ja see talv sõitnud Q ja asi palju parem. Viljandi inimesed teavad linnas kõrgemäge, mis otseteed suht tihti kasutan. Esiveolisega sealt talvel ülesse ei lähe nii lihtsalt. Q võin seal poole mäe peal isegi seisma jääda ja ülesse sõita - proovitud.
EDIT: google.ee, et milline on kõrgemägi. 18%
http://www.youtube.com/watch?v=wUFBMSzNPrI
Ma ei saa aru, miks on vaja igas teemas selle üle arutleda :)
SilverLine
Auto: Audi A4 Facelift, Volvo S60 D5
postitati 22.02.13 10:49 Tsiteeri
Sain siin 2 nädalat tagasi nuhtlusest nimega BMW lahti ja hetkel käib uue auto jaht. Mõtlesin küll, et seekord loobun sakslastest ja võtan rootsi toodangu ligi, nagu Volvo S60! Paari auto pihta olen huvi ilmutanud ka aga kuidagi ei ole õnnestunud neid kontrolli viia. Siis hakkasin oma vana lemmikut silmitsema ehk B5 FL. Ega sealgi erilist valikut ei ole aga üks hakkas silma siiski:
A4 2,4
Jutt on juures täitsa hea. Omadest kogemustest tean, et kalleim töö peres oleva B5 on siiani olnud hammasrihma värk. Kui kellegil mingit infot tolle auto kohta peaks olema kuulaks huviga. Mulle õudsalt meeldib see 2,4 V6 mootor. Just madalatel pööretel on ülimalt nauditav vääne ja see quattro teeks ka talvise liiklemise oluliselt meeldivamaks!
Ma ei ole nende autode turul ammu silma peal hoidnud ja optimaalsest turuhinnast kahjuks ülevaade puudub. Kas on selline hinnaklass tollel masinal, et võiks eeldada, et selle raha eest saab ikka töötava masina?
postitati 22.02.13 11:56 Tsiteeri
2.4 - kütusekulu ja hooldekulu nagu 2.8, aga vähem jõudu.
Ei ole mingit mõtet seda ihaldada, vaata kohe 2.8-t.
Kui tahad ökomat, siis 1.8T. Kui tahad madalalt väänet, siis 2.8. Need 2.6 ja 2.4 mootorid on ühed parajad õnnetused.
AronL
Registreerunud 07.09.08
Auto: M140i xDrive
postitati 22.02.13 13:09 Tsiteeri
Soovitaks ka pigem siis juba 2.8 vaadata, hoolduskulud samad.
Müügis ka pea 1000€ odavamalt üks üpris viisakas isend, pole küll päris nii hea varustusega kuid hiljem nahksisu leida ei ole eriti raske B5'le
Audi A4 2.8Q
rass
Registreerunud 25.09.02
postitati 22.02.13 13:23 Tsiteeri
Algselt postitas: Black
Mida ta nii erilist siis pakub Sulle??? Igapäevaelus mööda tavalisi teid sõites ei anna see nelikvedu suurt midagi juurde ja ei ole ma ome monovedusega ühtegi hange veel kinni jäänud ......
Räägime uuesti, kui oled ühe talve quattroga sõitnud. ;) ....
Tahtsin just sama öelda. Tüüpiline jutt neile, kes ei ole nelivedust varem omanud. Enne oma esimest quattrot arvasin suht samamoodi. Nüüd ma ei kujutaks ette enam esiveolisele tagasi minemist. Aegajalt sõidan ka ühe esiveolisega (sealjuures suht võimsa bensiinimootoriga) ja kuigi see auto on palju parem auto kui B5 Audi, siis lõpuks jääb B5 peale mul just neliveo tõttu.
Tõesti, kinni enamasti ei jää esiveolisega kah, ning kohalt minema (lõpuks) saab ka esiveolisega aga nelivedu on lisavarustus nagu kliimaseade - saab ilma hakkama kah, aga ometi ju ei tahaks?
Ja päris ausalt, ma ilmselt ei sõidaks Audi A4'ga, vähemalt mitte tootmisaasta vahemikus '95-'02, kui sellel poleks nelivedu. Kui ma oleks valmis sõitma esiveolisega siis sama raha eest leidub turul palju paremaid autosid, kui Audi B5. Ei ütle seda niisama vaid puhtalt kogemustest.
Teine asi, mille oma kogemustest siia juurde lisan on see, et diislit on siiski mõtekas vaid siis osta, kui tõesti on sõita pikki otsi ja tihedamalt. Näiteks linnast väljast tööl käia vms. Mina elan kesklinnas ja peamiselt on mu sõidud max 10km pikad, enamasti lühemad. Vahest harva (1-2x kuus teen mõne 300-500km maanete otsa). Tõesti kütte kulu on mõnusalt madal linnas ka lühikestel otsadel. Aga kuna kulu summa-summarum on liitrites ikkagi väike, siis kokku ka 20% suurem kütusekulu ei rööviks sellises olukorras taskust summaliselt palju rohkem raha - nii nagu pole mõtet 10 senti odavamaks tankimiseks teise linna otsa sõita. Tagantjärele tarkusena oleksin pidanud 1.9TDIQ asemel ostma 1.8TQ või 2.8TQ/3.0Q ja oleksin vist täna rohkem rahul ostuga - soojema ja vaiksema auto näol :)
Ja kui kulutustest rääkida, siis ainus asi, mis Quattrol on tähelepanu nõudnud tagasillas võrreldes varasemate esiveoliste Audidega on tagadifferi simmerid ja rattalaagrid. Muus osas pole seal tagasillas midagi väga lagunevat B5 masinal.
rass
postitati 22.02.13 13:36 Tsiteeri
Algselt postitas: SilverLine
Kui sa ei plaani osta nelikveolist, siis S60/S80 või Saab 9-3/5 on iga kell parem auto, kui Audi B5.
Olen ise omanud 3 aastat Volvo S60 2.5T '05, mis oli parim auto, mis mul üldse olnud kunagi on (sh saadaval ka nelikveolisena) ja juba 6,5 aastat on peres Saab 9-5 2.3T '98, millega ma aegajalt sõidan tänaseni ning peale mida on Audisse istudes tunne nagu istuks Moskvitsi.
B5 on lihtsalt nende kahe autoga võrreldes põlvkonna võrra maha jäänud ja moraalselt vananenud auto. B6 on aga eelnimetatud autodega juba täitsa võrreldav ja tunduvalt parem valik minu arvates. Esiveolisi leiab juba täitsa hea hinnaga kah.
siimuu
Registreerunud 19.08.11
postitati 22.02.13 15:01 Tsiteeri
Siiski S60/S80 Volvot võrrelda Audi A4 B5'ga on tiba imelik - S80 kannatab võrdlust pigem A8'ga ning S60/9-5 A6'ga. B5'te võid Sa 1-1'le võrrelda Volvo V/S 40'ga või sama ajastu Saab 9-3'ga. Arvan, et siga & kägu omavahel võrrelda pole päris mõtet.
Puhtalt omadele kogemustele toetudes ütlen, et enne sõidan B5'ga, kui sama aastakäigu 9-3 või S/V40'ga. :):o
SilverLine
postitati 22.02.13 17:51 Tsiteeri
Ei võrdlegi neid kaht omavahel, lihtsalt kaks autot mille vahel ma kaalun hetkel. Selle esiveduse 2,4 mis juba majas on sellega olen 3 aasta jooksul väga rahul olnud (okei, seda tõesti ei tea kui hästi ta end quattro peal õigustab). Kui B5 peaks valima siis kindlasti quattro.
[PHP: 6.6% - SQL: 93.4%]
