Huviliste autod
Huviliste endised autod
Audi 100 2.8 A/T - 1994 - airbag
[quote][i]Algselt postitas: Ardo[/i] Täna sain siis autole diagnosti tehtud: Faults Found: Engine 00281 - Vehicle Speed Sensor (G68) 03-00 - No Signal 01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80) 31-00 - Open or Short to Ground 00577 - Knock Sensor Regulation Cylinder 1 08-10 - Control Limit Surpassed - Intermittent VAG-COM Version: Release 311.2-N Chassis Type: 4A - Audi 100/A6 C4 Scan: 01,02,03,08,15,17,25 Address 02 ------------------------------------------------------- Controller: 4A0 927 156 Q Component: AG4 GETRIEBE 01K D81 Coding: PMC 0 Shop #: 0260002286 No fault code found. Address 03 ------------------------------------------------------- Controller: 4A0 907 379 A Component: Bremsen-Elektronik Coding: 0265100056 Shop #: BB 33837 No fault code found. Address 08 ------------------------------------------------------- Controller: 4A0 820 043 F Component: Klima-Vollautomat D05 Coding: 00060 Shop #: WSC 02315 No fault code found. Address 15 ------------------------------------------------------- Controller: 4A0 959 655 Component: AIRBAG II AĻP«PŸ˙… 1 Fault Found: 00588 - Airbag Igniter: Driver Side (N95) 32-10 - Resistance too High - Intermittent End ------------------------------------------------------- Seega päris hea tulemus, airbagi probleemid lahenevad uue rooliga. Kiiruse sensori surm on nüüd kinnitatud ja bensuauruklapp tahab puhastust, aga ei saa aru mida see viga endast kujutab: 00577 - Knock Sensor Regulation Cylinder 1 08-10 - Control Limit Surpassed - Intermittent Oskab keegi aidata? [/quote]
Huviliste autod
22
47.7%
52.3%
