Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 100 Avant Quattro Diesel - 1988 - krss
 Lehekülgi:  1  2  3  4
Pealkiri: Audi 100 Avant Quattro Diesel - 1988 - krss (Vastuseid: 89 | Vaatamisi: 18989)
krss
Registreerunud 24.11.03
Auto: VAG
postitati 14.08.04 19:32 Tsiteeri
Sai soetatud lõpuks see pikaaegne unistus peres teise pisi-quattro kõrvale. Masin on suht ammu Shveitsist tulnud, vist käinud osaliselt ka vee all (elektrisüsteem täielikult vahetatud uute osadega). Muidu originaal, suuremate avariide ja roosteta, läbisõit 260tkm. Lisadest vaid tavalised el jubinad (4x el.aknad, kesklukk, istmete-peeglite soojendused jms) ja orig luugiga. Esimese kahe ööpäeva jooksul suutsin sõita läbi peaaegu 1000km (täislastis + 205 laiusega papudega) ja masin suutis teha ka üllatuse - maanteekuluks (100-110km/h) tuli vaid 7.5L/100km:).
EDIT: kogu projekti areng algusest lõpuni on koondatud kokku üheks VIDEOKS (kliki siia)
http://www.carrating.org/documents/cars/1/12v1e2a131i3c382m2q2.JPG
http://www.carrating.org/documents/cars/0/04t4t3w9U6j7C2h3q6u6.jpg
daqqer
Registreerunud 15.07.03
Auto: minu masinad
postitati 14.08.04 19:52 Tsiteeri
ette paneks kohe valged suunad :)
väga kena pill, edu sellega.
edit: pilde nimed pane Audi_Jaak_1 ja 2 ja 3 ja 4... 7.
edit: mis kuradi lukuauk sul taga vasakul tule all on ? :)
d | ehitustehnika, suruõhk
postitati 14.08.04 21:05 Tsiteeri
Asjalik. Lühike numbrimärk viitaks nagu lombitagusele päritolule? Või pärineb see tagapaneel kuskilt mujalt?
krss
Auto: VAG
postitati 14.08.04 21:16 Tsiteeri
Esialgne postitaja Black
Täiesti Euroopa masin. Tagapaneeli päritolu ei tea, kuid see rikkus ära mu plaani tuua täismõõdus varuratas kuudist välja, stange kohale, nagu päris jeepidel:D
postitati 14.08.04 21:20 Tsiteeri
Kavatsed oma diisliprojekti ka ellu viia või läks tuhin üle? :P Ma just kaevasin su vana teema siin mingisse teemase vastuseks üles.
krss
Auto: VAG
postitati 16.08.04 09:56 Tsiteeri
Diislituhin pole sugugi üle läinud, vastupidi. Uurinud vahepeal seadusi, ning põhimõtteliselt ei tohi paigaldada mootorit, mis saastab rohkem (ehk siis kat-iga autole ei tohi paigaldada kat-ita mootorit, antud juhul diislit). Altkäemaksud suht soolased, et selleks ikkagi luba saada. Teine variant on kasutada firmade abi, kes tegelevad autode diisliks ümberehitamisega, kuna neil on "ARKis sidemeid", kuid siis jääb ehitamise rõõm ära, tuleb lasta NEIL teha ja loomulikult ka maksta. Kolmas variant on teha ümberehitus, kuid jätta asi ümbervormistamata ja teha tulevikus ülevaatused raha eest ostes... Tehnilise poole küsimused on lahendatud ja kui leiaks soodsalt hea mootori, läheks asi sügisel käiku. Kuna aga auto nii ökonoomseks osutus, siis kipub see ümberehitus oma mõtet kaotama:). Diisli momendi vastu nullpööretel see 2.3 muidugi ei saa, samuti ka mitte ökonoomsuselt. Aga diislitega harjununa, on kummaline teha gaas põhjas möödasõite, ja pikemast rekkast möödudes avastada spido osuti 200 pealt:D
Esialgne postitaja daqqer
Selle saad ise välja nuputada;)
jan-kos
Registreerunud 23.04.03
postitati 16.08.04 10:04 Tsiteeri
See luku auk peaks olema signa oma.Minu omal oli ka kunagi ja peal oli bossu signa,mingi vana mudel nagu ma aru sain keerati võtmega signa peale.Aga ilus on ta küll ja jälle peab ohkama "quattro", talvel nalja kui palju :D
mulk
Registreerunud 11.11.03
postitati 16.08.04 10:06 Tsiteeri
Eino mis sa hing veel tahad ... uskumatult võimas ... lisaks õkonoomsusele :P
Või on tõesti pikk rekka :D
Ulvar
Registreerunud 31.03.03
Auto: Ioniq 5
postitati 16.08.04 10:13 Tsiteeri
Esialgne postitaja krss
Tahaks ka endale sellist mootorit, mis rekkast mööda sõidul märkamatult kiiruse 200-ni kruvib ja veel seejuures 7.5l/100km kütet võtab! Või on need tõsiselt pikad rekkad?
Difrilukk. ;)
Ulvar
krss
Auto: VAG
postitati 16.08.04 10:16 Tsiteeri
Esialgne postitaja mulk
Eino mis sa hing veel tahad ... uskumatult võimas ... lisaks õkonoomsusele :P Või on tõesti pikk rekka :D
See "diislitega harjunud" tähendab seda, et võtad enne möödasõitu 100m kiirenduseks hoogu ja siis pedaal põrandasse ning hoiad hinge kinni, et enne üleüleülejärgmist kurvi mööda ikka pääsed:D. Ning gaasi enne maha ei võta kui tagasireastunud. See oli lihtsalt esimene (ja seniks viimane) selline "kiire" möödasõit siin Soomes, ja loomulikult mitte ülesmäge:) Auto igal juhul üllatas kiirendusega. Muidu harjunud MB 200D kiirendusega ja selle bensukaga, mis siin avataril. Tegelikult olen äärmiselt kerge jalaga ning närvid lubavad ohtlike möödasõitude asemel loksuda ka lubatust paarkümmend km/h aeglasemalt sadu kilomeetreid veoka taga, eeldusel et sealt kastist midagi kraesse ei pudene. Seda enam, kui auto võimaldab sõitmist nautida (respect suurtele audidele:))
krss
Auto: VAG
postitati 31.08.04 12:00 Tsiteeri
Sai möödunud nädalavahetuse masinat veidi lammutatud, ja tõdetud, et Eestis oldud 4 aasta jooksul pole see masin küll kordagi ametlikult ülevaatusel käinud. Pole hullud vead, aga eelmise omaniku vildakas suhtumine sõiduriista küll südant ei soojenda:(
Aga ümberehitusluba on nüüd käes:cool:. Ainus, mida ei ole, on aga korralik diiselmootor, sest kõik, mida seni pakutud, on juba poolel teel kapremondile või siis korralik mootor, mida on hakatud osadena maha müüma (puuduvad kütusetorud või pump jne)...
krss
Auto: VAG
postitati 22.09.04 01:19 Tsiteeri
Natuke oma möödunud nädala seiklustest:
Neljapäeval läksin ostma siis seda kauaotsitud diiselmootorit, mis pidi olema ideaalses korras ja äsja kapremonditud. Oli aga üsna letargilises seisundis: tossav (nii seest kui tagant), köhiv (keskmistel pööretel) ja leemendav (iga nurga alt). Siis sai poolel teel kammitud läbi kõik muud pakkumised ning lapatsit antud, kuna teiseks parim pakkumine oli ootamatult kaugel. Kuna mootori pealetõstjat polnud, sai see venitatud ühe traktori kopa sisse, kes siis selle mu Avandile tagant luugist sisse "kallas":). Mootor käes, oli ees ootamas 320km ja kaks-pool tundi laeva väljumiseni. Õnneks oli suurem osa maanteest kiirteed, ning veerand tundi linna ummikutes ning veerand tundi enne väljumist olin igal juhul sadamas:D (häbi!). Koos seiklustega piiril jäeti mind siiski laevast maha ning veetsin öö sadama ees, autos magades. Esimese Autoekspressiga siis Tallinnasse, ning sealt ühe jutiga Tartusse, oma masinat lammutama. Õhtuks oli mootor maas, kuid oh üllatust, väljaotsitud andmed diiselmootori sobitamiseks quattro käigukasti otsa osutusid totaalselt valedeks, ning siis algas jube sebimine ja juppide sobitamine, mis kestis kokku peaaegu 4 päeva. Igal juhul täna lõuna ajal sõitsin omal jõul garaazhist välja, loopisin tuled-stanged ette, ning kiiruga Tallinna poole, et jõuda taaskord viimasele laevale. Seekord jõudsin:) Kogu asi on praegu veel nii poolik, et käivitan autot kapoti alt juhtmetega, kuna elektriga polnud üldse aega tegeleda. Tänase päeva kilometraazh tuli ligi 1000km ning ise ülirahul oma diisel-quattroga:D. Lähipäevil tuleb siia ka detailsem jutt ümberehitusest, koos piltide ja võibolla ka mõne videolõiguga
jan-kos
postitati 22.09.04 06:06 Tsiteeri
Vägev :cool:
krss
Auto: VAG
postitati 22.09.04 19:12 Tsiteeri
Kogu tehniline info sellest ümberehitusest asub siin:
http://foorum.audiclub.ee/viewthread.php?tid=3744
Edasi siis väike pildialbum mu viimase 5 päeva tegevusest.
EDIT: PILDID KUSTUNUD JA KOONDATUD KOKKU VIDEOKS (kliki siia)
Järgmiseks lappasin masina kokku ning tegin ligi 1000km pikkuse "proovisõidu"
Siinkohal tahaksin väga tänada ühte Eesti parimat diislispetsi, sõber Aivarit, kelle entusiasmi, kogemuse, lugemuse ning näpuosavuseta poleks tänaseni võimalik tankida oma autot koos traktorite ning rekkadega samas järjekorras:D. Samuti tahaks väga tänada ka Tartu lammutuskoja "Süüde" töömehi, kes aitasid nii jõu kui ka nõuga!
tarmo
Registreerunud 05.01.03
postitati 22.09.04 19:25 Tsiteeri
kas ainult mina ei näe pilte ?
edit: nüüd näen....põnev :D
tõsist vaeva nähtud ikka :D
margus
Registreerunud 15.12.02
postitati 22.09.04 19:32 Tsiteeri
Mina näen :)
Aga tõepoolest huvitava tööga oled hakkama saanud!!! Tore kui selliseid hakkajaid ikka on!
resnick
Registreerunud 14.03.04
Auto: B4 '93
postitati 22.09.04 20:06 Tsiteeri
respect :cool:
Joel
Registreerunud 01.10.02
postitati 23.09.04 05:35 Tsiteeri
Sponsored by Upcider või panid niisama vodkaturisti? :) Auto kohta ei oska ma midagi öelda - tore, et selline huvitav masin nüüd ringi liigub, aga minu jaoks on sel asjal väike rüvetamise hõng juures...
Absolut
Auto: Corvette C5 `01
postitati 23.09.04 05:54 Tsiteeri
minugi arust tegu ka natuke rõvetamisega...et teha "ladast sapikas"
jan-kos
postitati 23.09.04 06:24 Tsiteeri
Minuarust täitsa norm., süda vahetati ära ja see põletab nüüd muud mahla,muu jäi ju samaks või vahetas ka auto marki? :o
Reix
Registreerunud 19.07.03
Auto: riisikas ja hamburger
postitati 23.09.04 06:30 Tsiteeri
iseenesest täitsa mõnusalt alternatiivne ettevõtmine, mulle igatahes asi meeldib:). aga tekkis selline küsimus - kas see 51 kW diisel sigaravantquattrole natuke lahjax ei jää, eriti, kui mingi kandam peal, käru sabas?
kes audis naerab, naerab paremini - http://foorum.audiclub.ee/viewthread.php?tid=2342
postitati 23.09.04 06:47 Tsiteeri
Esialgne postitaja Reix
Kandamit veab üldjuhul pöördemoment, mitte kilovatt ja kuna olen omal ajal ka ise mõnda aega 51 kW diiselsigariga sõitnud, siis väidan, et lisaks tema enda raskusele polnud ka teist pooleteisttonnist autot järel vedada mingi probleem. Keskmise 2.0 bensukaga oleks ilmselt raskemgi olnud. Ilmselt ei plaani krss sellega 402m võitma minna. Raskel maastikul on madalalt vedav diisel vägagi omal kohal. Rüvetamisest on asi kaugel. Minu arvates on diisel seal sihipärase kasutamise korral täiesti omas elemendis. Tubli, krss! :)
PS. krss, kirjeldusse "Audi 100 Avant Quattro Diesel" järele võid nüüd ausalt väljateenitult ka "Allroad" lisada. :P
krss
Auto: VAG
postitati 23.09.04 07:03 Tsiteeri
Ega nii lahjade vedelike abil ikka mootorit vahetatud ei saa:D. Ju siis ikka rohkem vodkaturist...
Aga mida tähendab "lahja"? Kui Sa pead silmas 100kW mootori tömmet gaas pöhjas, siis diisel kiirendab loomulikult aeglasemalt. Samas on see bensumootor päris lahja nullpööretel, kus diislil on jöudu enam kui piisavalt. Enamus söidust on (vähemalt minu puhul) lähemal nullpööretele kui "gaas pöhjas" olukorrale, ja just nendel pööretel pole minek kuidagi kehvem - sama käib ka koormaga söidu kohta, sest diisel jääb bensukast oluliselt maha oma löppvöimsuselt (st maanteel möödasöite peab planeerima), kuid madalate pöörete momendiga suudavad vöistelda vähesed bensukad (nt manuaalkastiga V8-t, see töenäoliselt suudaks ja vbl isegi yletaks veidi). See oli ka kogu ymberehituse pöhjuseks, et saada momenti juurde, kuna "sportauto" on mul pyhapäevasöitudeks juba olemas:D
Reix
postitati 23.09.04 07:13 Tsiteeri
okei, okei, mul lihtsalt diislitega kogemus peaaegu ümmargune null, ju see moment on siis nii madalal kui räägitaxe. peaasi, et auto vastaks omaniku ootustele:)
krss
Auto: VAG
postitati 28.09.04 22:31 Tsiteeri
Heh, see tagaluugi serv kipub nagunii neile siltidele kitsaks jääma:D. No millises järjekorras peaks panema? Audi 100 Allroad, siis keskel 4 rõngast ja paremal Diesel Quattro? Mul veel pooled elektri ja elektroonika asjad (sh vead) lõpuni ehitamata, ei ole tahtnud sildimajandusega oma pead vaevata. Tegelikult teades olukorda Tallinnas, oleks vist nende siltide külgepanemine umbes sama, nagu narkoärikate aktsiate ostmine :mad:. Igal juhul põnev oleks mõne Allroadiga kõrvuti sattuda, ja võrrelda, KUMMAL ON SUUREM kliirens:D
 Lehekülgi:  1  2  3  4
[PHP: 28.4% - SQL: 71.6%]
