Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mootor jooksis õlist tühjaks!
Pealkiri: Mootor jooksis õlist tühjaks! (Vastuseid: 43 | Vaatamisi: 11155)
Hb4avant
Registreerunud 08.06.09
Auto: B4 avant 2.0
postitati 21.12.09 19:35 Tsiteeri
Lugu järgmine.....
Autoks on Audi B4 92a. 2.0 85kw. Sõitsin õismäelt kesklinna, kuskil poole tee peal, kuulsin, et mootor hakkas kahtlaselt tiksuma. Jõudes kesklinna, otsustasin igaks juhuks õlitaset kontrollida. Selgus kurb tõsiasi, et mootoris polnud enam õli. Käisin tanklas ja kallasin õlitaseme normi, käivitasin uuesti auto ja hakkasin viga otsima. Nimelt, kui auto käima panin, hakkas õlifiltri korpuse vahelt hoolega õli välja pressima.Ülemise õlirõhuanduri poolse korpuse ja filtri poolse korpuse vahelt nimelt. Millest võib selline asi tekkida? Väga suur surve või on lihtsalt korpus vigane?
Rain
Registreerunud 05.10.03
Auto: Allroad ja A6 Allroad
postitati 21.12.09 19:47 Tsiteeri
Kontrolli karterituulutus üle. Kui see umbes siis surve karteris ja otsib kõige lihtsama koha kus välja pressida.
madjs
Registreerunud 28.10.02
Auto: Audi 80 b4 1,9tdi, Suzuki VX 800, Golf 2 GTI, Megan Coupe 108kw
postitati 21.12.09 19:48 Tsiteeri
Algselt postitas: Hb4avant
Lugu järgmine.....
Sul peaks masinal olema õlijahuti filtri peal? Kui jah siis seal õlileke tüüp viga, filtri all peidus mutter mis jahutit kinni hoiab. See mutikas võib lahti olla või siis tihendid lihtsalt surnud, muidugi filter ise võib ka lahti olla. Külmade ilmadega kipub tihendi vahelt minema lööma kui külma mootoriga natuke rohkem paarutada.
postitati 21.12.09 20:11 Tsiteeri
Endal oli sama lugu eelmine aasta. Külmaga mootoriga on õli paks ja vana kalk tihend annab eriti kergelt otsad. Nimet õlijahuti tihend läks katki sul. Vahetada on kerge: Õlifilter küljest, all on 22 mutter vist, tolle keerad lahti ning tuleb õlifilter küljest. Seal pesitseb üks tihend mis arvatavasti sul läbi. Tihendit on erladi müüa poes. Kindlasti panna korralik poolsünt õli sisse ning ka uus filter.
http://www.upload.ee/image/310871/IMG_2584__Custom___Medium_.jpg
Hb4avant
Auto: B4 avant 2.0
postitati 21.12.09 20:32 Tsiteeri
Algselt postitas: KeveN
Täpselt selline pilt mulle kapoti alt avaneski.
Suured tänud teile ja Häid Pühi!
pampkuri
Registreerunud 08.03.04
postitati 21.12.09 22:42 Tsiteeri
Tihend maksab mingi 30 eek jahutusvedeliku kulub ca 2.5l fitri all peidus olevale mutrile 27 võti, pühapäeval tegelesin sama probleemiga
Hb4avant
Auto: B4 avant 2.0
postitati 22.12.09 06:32 Tsiteeri
Algselt postitas: pampkuri
Ühesõnaga, kui lahti tõmbad selle korpuse, jookseb ka jahutusvedelik välja?
pampkuri
postitati 22.12.09 08:03 Tsiteeri
See korpus on ühendatud kumivooliutega, minu autol ta ilma voolikuid lahti ühendamatta sealt välja ei tulnd.
Hb4avant
Auto: B4 avant 2.0
postitati 22.12.09 08:11 Tsiteeri
Tänud, jälle targem!
jaakk
Registreerunud 23.07.07
Auto: Bmw 525i -2007, sedaan
postitati 22.12.09 09:30 Tsiteeri
Mul lõi eelmine teisipäev samamoodi õli välja, vedas, et mootor kotti ei jooksnud.
Minul maksis 600 kr koos õlivahetuse ja tööga.
masinist
Registreerunud 15.09.07
Auto: C4 avant quattro 16v, VW rabbit
postitati 22.12.09 11:34 Tsiteeri
Tundub, et põhiviga mis külmadega kaasneb, 2 päeva tagasi sama juhus enda autoga, 15 min. kohapeal töötas, ning selle ajaga oli tubli loik alla tekkinud, selgus et pool tihendist oli teadmata suunas kadunud.
Uus tihend + vahetus 125.- ning jahutusvedeliku voolikuid ei pea lahti võtma.
Golf 1, Lada 1200, Riga 1, Riga 3, Riga 4, Riga 7, Riga 22, Riga Mini, Erkkola mopo
john
Registreerunud 07.01.03
postitati 22.12.09 11:48 Tsiteeri
Kusjuures see viga esineb ainult 2.0 mootoritel. Endalgi sama jama olnud.
Hb4avant
Auto: B4 avant 2.0
postitati 22.12.09 12:01 Tsiteeri
Algselt postitas: masinist
Käisin hommikul Forsist läbi, et tihend osta. Müüa rääkis sama juttu, et see aasta pidi neid tihendeid ikka väga hoolega minema:)Nüüd lähen vahetama, ehk õnnestub ikkagi jõuludeks maale enda autoga saada.
ulith
Registreerunud 19.03.06
Auto: 80 b4 1.9tdi 94a/ VW G4
postitati 22.12.09 12:16 Tsiteeri
Algselt postitas: john
LOL
Mul on 1.9 TDI sellel ka juhtus :D
Kuidas sa väidad,et ainult 2.0 mootoritel? VAG insener oled w :D?
Tihendi vahetusel pole jahutusvedelikuga tegemist üldse vaja teha!
jaakk
postitati 22.12.09 12:27 Tsiteeri
Minu autol ka päris kahte liitrit kubatuuri välja ei anna.
Algselt postitas: ulith
LOL
Kiil
Registreerunud 03.02.03
Auto: Allroad C5
postitati 22.12.09 14:58 Tsiteeri
Seda 27 mutrit tasub õlivahetusel pingutada, enamustel on see lõdvalt kinni kui pole ammu seda tihendit vahetatud.
joe80
Registreerunud 03.09.06
Auto: Audi A4 Avant 1,8Tq, Volkswagen Passat 2,0 B3 Syncro
postitati 22.12.09 15:31 Tsiteeri
Kui seda tihendit pole kaua vahetatud, siis see kummitihend seal kuumaga muutub rabedaks, nagu oleks ta mingist plastikust ja siis on ta kerge purunema. Seega, kui seda pingutada, võidki ta lihtsalt puruks keerata ja kui ikka on väga isu pingutada, siis pane juba uus tihend.
q
Hb4avant
Auto: B4 avant 2.0
postitati 22.12.09 15:56 Tsiteeri
Algselt postitas: Kiil
Kusjuures see mutikas oli suht lahti jah seal. Tihend oli muutunud väga kõvaks nagu plastikust oleks tehtud.
Eemaldasin vana ja asendasin uuega, mille sain Revalist ja maksis üllatavalt 37 .-
Ning jahutusvedeliku lõdvikuid pole vaja lahti krudida, sain ilma ilusti hakkama.
ermik
Registreerunud 12.11.09
postitati 22.12.09 16:03 Tsiteeri
Enda autol ka õliloik all juba pikemat aega, tundus, et vändaotsa tihend läbi ja sealt tuleb. Sai siis see suur töö ära tehtud ja tihend vahetatud. Aga paganama loik ei ole ikka kuhugi kadund. Kas tuleb ka hakata selle tihendi vahetusele mõtlema ja kui raske seda 1.9TDil teha on?
ermik
postitati 29.12.09 15:03 Tsiteeri
Sai ka õlijahuti tihend vahetatud ja hea meel, et nüüd mootor puhas. Aga eile sai ülavaatusel käidud ja mootor ikka tilgub käigukasti juurest. Nüüd mõistus otsas, äkki tilgub karteripõhja käigukasti poolne ots läbi? Kas võib olla et vahetatud otsasimmer oli defektiga?
paukpadrun
Registreerunud 20.04.07
Auto: A4 b6, Cabrio
postitati 29.12.09 21:06 Tsiteeri
Täpselt sama jama juhtus ka mul peres kasutusel oleval 1.9tdi-l.
Tundub, et paljudel juhtub seda:D
pampkuri
postitati 29.12.09 21:52 Tsiteeri
Nu jah ju ma siis ei julgend piisavalt sikkutada ja lasin voolikud lahti. Aga asi lõppes sellega et tilga mille ma pudlisse kinni püüdsin jõi isa mahla pähe ära oi plaa seda kisa. :o
real1
Registreerunud 09.06.06
Auto: B3, B4, B5; B7, C4, C6
postitati 29.12.09 22:01 Tsiteeri
Minul vedas, külmaga hakkas lihtsalt õlifiltri tihendi vahelt läbi andma, aga seda päris hoolega. Filtri kinnikeeramine aitas:)
Hb4avant
Auto: B4 avant 2.0
postitati 30.12.09 07:54 Tsiteeri
Külmumisoht peaks siis välistatud olema:D
Hb4avant
Auto: B4 avant 2.0
postitati 30.12.09 07:57 Tsiteeri
Algselt postitas: real1
Kusjuures ma vaatasin, et see sama tihend, mis on õlifiltri küljes, sobib isegi õlijahuti vahele. Ise küll panin uue, kuid võib-olla oleks saanud selle ju vanalt õlifiltrilt ka :)
[PHP: 19.3% - SQL: 80.7%]
