 Lehekülgi:  1  2  3  4  5  6
Pealkiri: Pidurid (Vastuseid: 138 | Vaatamisi: 36284)
Teemo
Registreerunud 15.10.05
Auto: Audi Quattro
postitati 27.02.08 09:30 Tsiteeri
Algselt postitas: priidik
Kes teab mainida, kas sellised sobivad näiteks C4 S6-le ka?
Suht pisikesed on need kettad seal taga ikka, tahaks midagi vastavale massile sobivamat.. Samas, kas on võimalik pista suuremaid kettaid jättes suportid/sadulad originaalid?
Nagu ma aru saan, siis sealsed kettad on 245*10mm. S6-l on aga originaalis juba 269*20mm(ventileeritud). Seega kui tahta kasutada s6 sadulat oleks vaja juba ventileeritavat ketast.
priidik
Registreerunud 17.04.03
postitati 27.02.08 13:14 Tsiteeri
Sealne ketas oli lihtsalt näiteks. Pigem mind huvitaks kasutada suurema raadiusega kui originaalis. Teretulnud on head soovitused, et milliste ketaste poole võiks kiigata.
Maku
postitati 17.06.08 14:29 Tsiteeri
RS2 porshe brake options
Parts list for possible solutions RS2 brakes COMMENTS
PORSCHE part # AUDI part #
FRONT
928 GTS Big Black Calipers 928-351-423-03 Same size as the "big reds",black color
928-351-424-03 Ø 44m and Ø 36mm pistons
__________________________________________________________
993 TT Big Red Calipers 993-351-425-10 8A0 615 105K Some modifications needed, as to mounting the caliper the
993-351-426-10 8A0 615 106K Correct way(leading/trailing), ie the air valves mount upwards
1994-96 RS2 2-Piece 322mmx32mm Rotors ? 8A0 615 283 Rotor is 993TT but hat is different, 45mm
? 8A0 615 284 measured from outer hub to outer disc surface
1994-911 C2 3.6 Turbo 322mmx32mm Rotors 965-351-045-00 Casted went holes, direct bolt on to RS2
965-351-046-00 as a one-piece rotor-45/mm "hat"
928S4-M030 option 304mmx32mm 965-351-041-01 "Cross-drilled," will bolt directly onto RS,
965-351-042-01 To be used on the 304mm option if cross drilled is preferred
928 GTS Front Brake Rotors 322mmx32mm Rotors 928-351-045-01 Same offset as the C2 Turbo rotors and RS2
928-351-046-01 Compatibel, Plain rotors, no vent holes
REAR
Original RS2/968 rear rotors 299mmx24mm 951-352-041-02 8A0 615 601C Stock rotors without vent holes
928 M030 Rear Rotors, 299mmx24mm 951-352-041-91 8A0 615 601D "Cross-drilled", bolt on to RS2
Zimmermann cross drilled 299mmx24mm 460.1516.50 Aftermarket rotor from Zimmermann,cheapest
Parking brake shoes(set) Ø180mmx25mm 928-352-097-10R 8A0 609 525C
993TT Front Brake Pads 993-351-949-00 8A0 698 151G Non slotted, for use with "cross-drilled" rotors
928 M030 Rear Brake Pads 965-352-939-04 8A0 698 451B Non slotted, for use with "cross-drilled" rotors
Caliper bracket/adapter 8A0 615 125A Both 304 and 322 use the same bracket on the RS2
Brake Pad Vibration Dampers, 44mm, Each (4) 965-351-096-00 8A0 615 231D
Brake Pad Vibration Dampers, 36mm, Each (4) 964-351-096-01
Brake Pad Vibration Dampers, 30mm, Each (4) 964-352-096-00 8A0 615 231B
Brake Pad Vibration Dampers, 28mm, Each (4) 964-352-096-01 8A0 615 231C
GTS Caliper Bolts, Each (4) 900-067-268-02 N 100 650 02 Caliper-to-adapter M12x1,5x70mm
951S Caliper Bolts, Each (4) 900-067-154-02 N 100 880 03 Adapter-to-steering knuckle M12x1,5x25mm
Caliper Bolt Washers, Each (8) N-011-564-2
LINK
Maku
postitati 25.04.09 21:55 Tsiteeri
Minu RS2-le läksid ette Ferodo Premier klotsid, mille karbi peale on kirjutatud Porsche 928 (4957cc) 9/86-5/92 (esimesed), 944 Turbo (2479cc) 9/85-9/97 (esimesed), 959 (2829cc) 8/87-8/89 (esimesed), 944 (2681cc) 9/88-6/89 (esimesed). Ketta suurus on 304mm ja klotsi tootekood FDB560.
Maku
postitati 01.05.09 21:19 Tsiteeri
Algselt postitas: Maku
Ja tagumiste tootekood on FDB451. Karbil kirjas Porsche 911 Carrera 4 (3600cc) 6/89-3/99 (esimesed ja tagumised), 944 (2990cc) 1/89-3/99 (esimesed ja tagumised), Ferrari 348 1/90-3/99 (esimesed ja tagumised).
Geo
Registreerunud 20.09.05
Auto: 4xQ
postitati 25.05.09 20:58 Tsiteeri
Edit 18.08.2010
Tere klubikaaslased!
Selles postituses on juttu sellest kuidas modifitseerida UFO pidureid.
Mida oleks siis tarvis et saada lahti UFO piduritest?
1. A8/urS4/urS6 piduri suppordid, turu hind 1000-3000.- /2tk
2. Treida UFO püstaku RUMMU uuele kettale sobivamaks, kusjuures rummu ei pea välja võtma. Treimisel kohe saan aru kas laagrid on korras...
3. Kolmas ylemine UFO sadula kõrv tuleb eemaldada.
4. Kuna uuematel supporditel on kinnitusavad 14mm, läheb tarvis teha suurem keere (M14 M12 asemele) või valmistada vahepuksid. Kindlasti poes on M14x1,5 polte, aga mina sobitasin rattapolte. Siiski lihtsam on teha puksid, aga M12 ei ole nii tugevad kui M14.
5. Rummu ja piduriketaste vahele tuleb teha tsentreerimisrõngad.
6. Suppordi sadulal tuleb freesida maha umbes 3,5mm et saada pidurisupport ketta keskele.
7. Vajaduse või soovi korral sadulad lahti võtta=> liivaprits=>värv=>remkomplekt sadulatele (Laki Autos u 350eek/1 kmpl).
NB! Võite alati pöörduda minu poole, aitan ka rattalaagrite vahetamisega pressi abil.
Graal
Registreerunud 25.02.09
postitati 26.05.09 09:57 Tsiteeri
On veel lihtsam variant. Osta heas korras kogu S6 (1995-1997) (sobivad vist S4 omad ka) püstak, sh. vedru-amort. Ufo krempel maha, S6 krempel külge (läks mul 1,5h). Vajadusel klotsi/ketta vahetus ja tuld :-) Milleks mingite treimiste ja puurimistega möllata?
Geo
Auto: 4xQ
postitati 26.05.09 20:18 Tsiteeri
Algselt postitas: Graal
Milleks puurida ja möllata? Selleks et MINGIL treialil ja puurijal oleks tööd, loomulikult :D
888
Registreerunud 24.01.06
Auto: Audi A6 Quattro
postitati 16.03.10 15:47 Tsiteeri
UFO pidurite ( 200 20v, V8 ja urS4 ) vahetus HP2 pidurite vastu
Tekkis siis selline küsimus, et kas saab ufo ketsate asemele mingid muud kettad panna ilma, et peaks vahetama kogu püstaku?
Olen kuulnud ja ka netist väheke uurinud, et peaks saama alla panna audi A8 pidurikettad;) (Muidugi koos suporditega) On selline asi võimalik?
Sõitsid saanid-Sõitsid reed A Quattro sõidab ikka veel;)
jõuvanker
Registreerunud 21.03.03
postitati 16.03.10 21:30 Tsiteeri
Algselt postitas: 888
Jah, on võimalik, kuid UFO püstakut tuleb natukene "kohendada", et sinna uuematüübi suportid külge sobiksid. Sama tuleb teha ka ketastega või rummudega.
Vihane-Tihane
Registreerunud 02.05.06
Auto: Audi 200 TQ 20v avant ja 120 Prado
postitati 16.03.10 21:53 Tsiteeri
Rummud tuleb püstaku küljest eemaldada (mis tähendab ühtlasi juba rattalaagri vahetust) ning ca 2mm välimist äärt maha treida, et siis A8/S8 ketas otsa istuks. Suportite ning püstakute vahele tuleb üleminekuflants meisterdada.
Ega selline tegeminegi kõikse odavam ole.
BLOW-JOB is better then NO JOB
mulk
Registreerunud 11.11.03
postitati 17.03.10 04:50 Tsiteeri
S4 Biturbo pidurid sobivad 1:1le, suporti kinnitamis avad tuleb vaid suuremaks puurida.
lehys
Registreerunud 31.05.08
Auto: Cupra Leon Sportstourer
postitati 17.03.10 06:24 Tsiteeri
Algselt postitas: mulk
Samad siis lähevad ka urs4-le alla,millel ufo pidurid?
mulk
postitati 17.03.10 07:36 Tsiteeri
Algselt postitas: lehys
Ohvkoors.
lauri
Registreerunud 09.09.08
postitati 17.03.10 09:00 Tsiteeri
Algselt postitas: Vihane-Tihane
Suporti ja püstaku vahele üleminekuflantsi pole vaja. Üks UFO kinnituskõrv (ufo püstakul on neid 3) maha lõigata ja kahele suurem keere sisse lõigata. Kuna endale panin kasutatud kettad, siis piisas mul rummu diameetri vähendamisest ja pisut suporti modifitseerimisest (lisaks kinnituskõrvade ümber tegemisele). Kui kunagi hakkan pidurikettaid vahetama, pean rummu või ketast treima hakkama.
Minul läks kogu jama maksma u 1000 eek.
Vihane-Tihane
postitati 17.03.10 10:58 Tsiteeri
Algselt postitas: lauri
Jah...ei pannud tähele, et juttu oli A8 supportitest lisaks mainitud A8 ketastele. Enda 200-l sai installitud siis S8 kettad ning tavalised kahesilindrilised suportid. Nende suportitega tuli teha mul ülemineku vaheflants, kuna kinnituskõrvad sellise kompoti puhul täiesti nihkes igatpidi. A8 suportite kinnitused on erinevad jah võrreldes tavaliste B4, 100-de, jne. suportitega.
http://static3.nagi.ee/i/p/577/89/1444743503188a_m.jpg
888
postitati 17.03.10 17:19 Tsiteeri
Thanks!
Peab siis kevadepoole meisterdama hakkama, et A8 kettad alla saada või siis tõesti S4 biturbo omad sebima;)
rix30
Registreerunud 19.04.09
Auto: Audi S3 1,8T 8L
postitati 17.03.10 19:53 Tsiteeri
Kas siis originaalid nii lõpuni sõidetud!:)
888
postitati 19.03.10 15:26 Tsiteeri
Ega nad nii väga kiita ole jah, aga asi rohkem selles, et lähevad alla teised veljed ja see ufokas on ikka jube jura seal all:P nagu mingi plekk-velg:D
end3l
Registreerunud 27.06.07
postitati 19.03.10 16:41 Tsiteeri
Ja ega UFOde hind ka väga kiita pole. Revalist ~6k/tk ning kuskilt autopoest B-osana vist ~3600 eek / paar.
mulk
postitati 20.03.10 05:00 Tsiteeri
Algselt postitas: end3l
Kus kohas ja mis ajast UFO kettaid B-osadena saada on?
888
postitati 20.03.10 11:04 Tsiteeri
Ma vaatasin, et ladu24.ee-s olid müüa V8 esimesed pidurikettad ja hind oli mingi 1300.-:o See on vist jamps või mida te arvate?;)
arsi
Registreerunud 09.02.06
postitati 20.03.10 12:16 Tsiteeri
See on jama :)
Tegemist siiski tavalise kettaga mitte UFOga
end3l
postitati 20.03.10 17:38 Tsiteeri
Siinkohal jään vastuse võlgu, aga 2009 suvi helistasin kas automaailma või taolisse poodi ning huvi pärast küsisin ufo kettaid. Vastatigi, et tellimise peale saab ~3600 eek paar ( võis vabalt ka 3400 või 3800 olla aga midagi 3600 kanti ta oli). Ei välista ka varianti, et müügimees oli ohmu ning ajas pada - kuigi küsisin üle kas tegu ikka ufo ketastega.
edit: ebayst leidsin 122 naelaga (korda 17 = eek) sellised.
http://cgi.ebay.co.uk/FRONT-BRAKE-DISCS-PAIR-AUDI-V8-3-6-88-94_W0QQitemZ120533710037QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarPart s_SM?hash=item1c105e74d5
Geo
Auto: 4xQ
postitati 20.03.10 18:50 Tsiteeri
Millised kogemused on BREMBO piduritega s4/s6? On mingi vahe? Olen kuulnud et 50% inimesi ütlevad et pole mõtet toppida 4 kolviga suppordit ja suuremat 323mm ketast, samas 50% ütlevad et tulemus on hea.
[PHP: 68.7% - SQL: 31.3%]
