 Lehekülgi:  1  2  3
Pealkiri: Toitesüsteem (pihustid, regulaator, pump..) (Vastuseid: 66 | Vaatamisi: 33037)
forsin
Registreerunud 01.07.04
postitati 29.03.07 14:03 Tsiteeri
Algselt postitas: mulk
Ma olen vist ainuke eestis, kes seda ei näe? :P
mina teise arvuti taga ka ei näe, aga äkki keegi vajab.
http://www.turbobits.co.uk/acatalog/digital_fuel_pressure_gauge.html
http://www.turbobits.co.uk/acatalog/Innovate_LC-1_wideband_air_fuel_ratio_gauge.html
Maku
postitati 02.09.07 14:53 Tsiteeri
Selle TABELI järgi on Porsche ORANGE pihustite nominaalväärtus 396.8 cc/min. Seal on veel paljude pihustite andmeid.
Orange siis:
0-280-150-791 37.75 396.8 285.4 - - - - 83.9 99.6 79.5 94.4 71.9 85.4 64.3 76.3 58.1 69.0 53.0 62.9 High Porsche 6-3.6l
Edit:
0-280-150-791 37.75 396.8 285.4 - - - - 83.9 99.6 79.5 94.4 71.9 85.4 64.3 76.3 58.1 69 53 62.9 Top High Porsche 6-3.6l
0-280-156-012 29.5 310 223 43.5 3.0 29.5 310 65.6 77.8 62.1 73.8 56.2 66.7 50.2 59.6 45.4 53.9 41.4 49.2 Top High Porsche 6-3.4l, 6-3.6l
0-280-156-012 41.0 430.9 310 43.5 3.0 41 430.9 91.1 108 86.3 102 78.1 92.7 69.8 82.9 63.1 74.9 57.5 68.3 Top High Feedback - Ned Ritchie
Veel 1 tabel.
Bosch Number cc/min @3bar Resistance (ohm)
0280150791 414 12.0
0280156012 412 12.0
Boschi enda andmed:
Part Number g/min @ 3 Bar (Bar) Pressure Resistance (ohms) Design Type Connector Comments
0 280 150 791 311.0 3.8 12.0 EV 1 9 122 067 011 - PORSCHE 911 (993) TURBO GT2 ORANGE
0 280 156 012 310.0 3.8 12.0 EV 6 9 122 067 011 Standard Body - PORSCHE BITURBO
0 280 155 968 310.0 3.8 12.0 EV 6 9 122 067 011 Dual Spray/Long Body - FORDI ROHELISED
injectors ... Orange Porsche GT2 ?:
Nr.: 0280 150 791
PORSC - 911 (993) 3.6 Turbo 4 03.95-09.97 300kw 408HP 3600cc
but i have found also this info
Bosch injectors 0 280 150 791, 511 ccm 3,8 bar (Porsche), 750:- Skr
http://www.mrm-racing.a.se/English/start.asp
0 280 150 791 at 4 Bar is 529,3cc/min
porsche oragne is 511cc at 3.8 bar
forsin
postitati 30.12.07 19:12 Tsiteeri
Kuskil olen pildistanud õieti ja lihtsalt lisatud bensiini surve kella
http://www.album.ee/node/12030924/50026938
Inimene teadis ja ei vedanud bensiini voolikut salangi (et varsti ise maha põleda) kuid ainult selliseid valesid bens manomeetreid müüvad eesti poed. ???
http://www.album.ee/node/12030917/50026938
20VTQ
Registreerunud 01.05.07
postitati 31.12.07 13:07 Tsiteeri
Algselt postitas: Maku
Loodan, et postitaja ei pane pahaks, kui selle postituse siia teemasse tõstan, sest see on äärmiselt asjalik.
Võtan tsiteeritud jutu lühidalt kokku
Lahja segu = 1kg bensiini/üle 16,5kg õhku (võimsus langeb)
Lahjendatud segu = 1kg bensiini/kuni 16,5kg õhku (kütust kasutatakse säästlikult, mõnevõrra vähendatud mootori võimsus)
Rikastatud segu = 1kg bensiini/13kg õhku (suurim võimsus)
Rikas segu = 1kg bensiini/alla 13kg õhku (mootori võimsus ja säästlikkus langevad)
Kuidas seda mõista - 13 kg (kilogrammi?) õhku, kas mitte liitrites ei peaks olema kogused?
Maku
postitati 31.12.07 14:44 Tsiteeri
Algselt postitas: mkj
Jään vastuse võlgu aga kas sellel on vahet kumb ta on?
Teemo
Registreerunud 15.10.05
Auto: Audi Quattro
postitati 31.12.07 15:27 Tsiteeri
Vahe on üsna suur. Me ei saa tuua kahe muutuja suhet, kui me ei kasuta samu ühikuid. Mass jagatakse ikka massiga ja ruumala ruumalaga. Antud ja üldse kõigis kütusega seotud teemades on õhk ikka kilogrammides.:)
Oleme harjunud jah, et üks kg vett või bensiini on u. 1l, aga see tuleneb nende vedelike tihedusest, mis ongi u.1kg liitri kohta.
Teras on aga juba 8korda raskem, õhk on aga tohutult palju kergem. Õhu tihedus on u. 1.3 kg kuupmeetri kohta ehk 0,0013kg/l:)
Seega kui me võtame segu suhteks 14l õhku ühele kg-le kütusele, oleks see ainult 0.018 kg(18g) õhku ühele liitrile ehk ühele kilogrammile kütusele. Vaevalt, et sellise suhte juures 2%-legi kütusele põlemiseks õhku jätkuks.:D
forsin
postitati 31.12.07 16:36 Tsiteeri
kui õieti mäletan siis oli liiter bentsu seguga 14,7 õhku natuke üle 9000 liitri
Sorri teemo ka vastas
Maku
postitati 03.01.08 14:35 Tsiteeri
Küttesegule lisa
Kütuse täielikuks põlemiseks teoreetiliselt vajalik õhu ja bensiini masside suhe on 14,7 : 1, mida tähistatakse lambdaga (λ) järgmiselt:
λ = 1 vahekord 14,7 : 1
λ> 1 - õhu liiasus,
&#955;< 1 - õhu puudujääk.
Mootori väljundvõimsus ehk võimsus võllil väljendub avaldisega
P = 2&#960;n × M, kus n &#150; väntvõlli pöörete arv minutis, b &#150; kütuse kulu väljundvõimsuse ühiku kohta.
Mootori silindrites ei ole võimalik saavutada bensiini täielikku põlemist õhuga mittetäieliku segunemise ja põlemisprotsessi ajalise piiratuse tõttu. Selleks, et bensiin põleks täielikult ära, on nõutav teatud õhu liiasus (&#955; &#8776;1,1). Ja vastupidi, hapniku täielikuks äratarvitamiseks on vajalik bensiini liiasus (&#955; &#8776; 0,9).
Optimaalsete &#955; väärtuste piirkond on 0,9 &#150; 1,1 . Kasvamisel väärtustele &#955; = 1,1...1,3 väljundvõimsus langeb, aga kütuse erikulu kasvab ( ~ 35%), &#955;> 1,3 juures segu süttib halvasti, tekib süüte vahelejätmisi.
Suuremal osal juhtudest on töösegu vaesustumine tingitud peenfiltri mustumisest või bensiinipumba kulumisest. Ülemäärane kulumine ja töösegu vaesustumine kiirendavad kulumist ja praktiliselt ca 1 aasta jooksul jääb mootor täielikult seisma. See on ühtlasi kütusele suurenenud rahaliste kulutuste ja aktiivne keskkonna saastamise periood.
Huvitavat lugemist
mulk
Registreerunud 11.11.03
postitati 19.04.08 19:58 Tsiteeri
Tore oleks teada saada pildil oleva anduri ühendamiseks kasutatud T- ühenduse keermed
Ehk siis, kellel vedeleb antud osa(d), sooviks keerme mõõte sealt, või on keegi juba oma anduri paigaldamisel kõnealused keermed tuvastanud?
Teemo
Auto: Audi Quattro
postitati 19.04.08 20:31 Tsiteeri
Eile just tegelesin sarnase asjaga ning vastus on AAN moto korral M14X1,5, vastavalt sise- ja väliskeere.
Maku
postitati 20.04.08 08:51 Tsiteeri
Kütuse täielikuks põlemiseks teoreetiliselt vajalik õhu ja bensiini masside suhe on 14,7 : 1, mida tähistatakse lambdaga (&#955;) järgmiselt:
&#955; = 1 vahekord 14,7 : 1
&#955;> 1 - õhu liiasus,
EFI lehelt:
Chip Tuning Package, GT3071R Stage I
Air/Fuel ratio 11.5-11.8 under boost, 14.7 under light load and idle conditions. Recommended for 91-93 octane fuel.
S2 foorumist:
12.5 is the afr for best power but it's also on the limit where egt usually starts to climb. 12 is good. 11.8 on the safe side. below that IMO it's rich.
Try to make it leaner but also use an EGT gauge.
12.3-12.5 is the ideal target, then you make it richer if need be to combat EGT temps.
I wouldn't want my car lower than 11 AFR to be honest, below that and it's 50 cent "get rich or die boosting" territory
Like porkkis and jamo said, i will try on leaner, around 12-12.5.
I have egt gauge to check the temp.
thanks guys, i will try it anyway. maybe i get more hp-s.
100% surely you can push more out of it when you dont flood it like that
Needless to say that listen for pingning while you make it leaner.
Teemo
Auto: Audi Quattro
postitati 20.04.08 10:12 Tsiteeri
Paar rida TTÜ-s omandatud tarkusest.
Seda rida ei maksaks Eesti pinnal võibolla päris tõepähe võtta.
Kuigi tundub, et lõik on pärit S2 forumist ehk Inglismaa omast, siis sarnaste numbrite korral Motorgeek'is tuleb arvestada järgmist. Ja võibolla on ka seegi lõik kuskilt USA kirjandusest pärit.
Kui Euroopas näitab 91, 95, 98 oktaaniarvu, siis USA-s mitte.
USA-s on selle näitaja nimetus AKI ehk Anti-knock index. See aga saadakse järgmiselt: (oktaaniarv uurimismeetodil+oktaaniarv mootorimeetodil)/2 =AKI
Pannes valemisse konkreetsed arvud, seda meie 98 korral saame: (98+88,5)/2 =93. Seega meie 98 on USA bensujaamas 93.
Maku
postitati 20.04.08 10:21 Tsiteeri
Algselt postitas: Teemo
Seega meie 98 on USA bensujaamas 91.
Jeppadi, see lõik on pärit EFI lehelt. Nimelt nende GT3071R stage 1 tarkvara. Tänud kommentaari eest!
Teemo
Auto: Audi Quattro
postitati 25.04.08 12:58 Tsiteeri
Ehk siis...
Pilt1
Pilt2
Pilt3
mulk
postitati 01.05.08 20:18 Tsiteeri
Tänud Teemo´le asjalikest piltidest.
Sellist paigaldust aga pole võimalik profesionaalselt teha, kuna lihtsalt õigete tihenduspindadega liitmike hüdraulikapoest ei leidu, v.a. juhul, kui ise teha sobiv T-liitmik.
Ise lahendasin asja nõnda
tegu 8mm terastoru jaoks mõeldud T-liitmikuga
lukas
Registreerunud 29.07.04
Auto: paar käru
postitati 04.06.08 11:46 Tsiteeri
Küsiks "034" reguleeritava regulaatori kohta
Selline siis!
Kas see regulaator töötab kõigil ikka normaalselt? Minu oma käitub selliselt, et miski peale 5,5 bari küttesurvet (koosneb 4 bari kütterõhk + 1,5 ülerõhku) tundub nagu enam edasi ei töötaks. Lubatud 3-5 bari peaks nagu tähendama 3-5 bari pluss veel ülerõhk või on minu oma lihtsalt praak.
Olgu öeldud, et benapump on boschi 044 niiet selle taha ei tohiks asi jääda.
Äkki kellelgi on samamoodi jebinud või olen ise millegagi jälle võssa pannud :)
Maku
postitati 04.06.08 11:58 Tsiteeri
Täpse surve kohta ma öelda ei oska aga minul töötab see regulaator ilusti. Nagu lynx ütles: "milleks seda bensusurvet vaja teada on, kui oluline on küttesegu"? Aga jah, jään täpse vastuse võlgu.
Maku
postitati 07.10.08 07:34 Tsiteeri
RS2 pihustitega dyno
PekkaS:
It gave only 435hp, should go near 500hp with bigger injectors. We´ll see.... Oh, and that 435hp was gained at 1,4bar boost.
What injectors are you running? RS2?
Yes, RS2.
LINK
Maku
postitati 12.10.08 09:21 Tsiteeri
Orange siis:
Ei, kuramus, lugesin seda tabelit valesti. Tulbas "Flow @ 43.5 PSI / 3 Bars" ei ole midagi kirjas. Siiski on vist nende pihustite nominaalväärtus midagi muud - 3 bar: 440 ml/min - ca. 73 PS/Düse. Lisaks on kirja pandud selline asi - max : 630 ml/min - ca. 105 PS/Düse.
Link ühele tjuuning lehele.
Marko
http://84.50.81.66/albums/album03/pihustite_tabrl.thumb.jpg
Maku
postitati 10.05.09 21:20 Tsiteeri
Tuli üks päev sinise paagist pump välja tirida. Kapis vedeles vanast ajast üks AAN-i pump (oli vist:)) ning panin need ühe pildi peale. Ehk siis AAN-i pump on ca 11cm pikk, ADU pump ca 14cm.
hunt-lambanahas
Registreerunud 07.02.09
Auto: Bmw e61, bmw e46
postitati 01.07.09 17:43 Tsiteeri
Kust leida sellist andurit et ehitada kutuse rohuku naitav susteem nagu eelpool oli naidatud!Voi manomeeter kapoti alla panna peale voolu torule vahele?Kas sobiks ka ohu manomeeter voi on bensu jaoks mingi spets manomeeter?
andrec
Registreerunud 07.10.06
Auto: A4 B6 R30 VR6 turbo
postitati 01.07.09 17:59 Tsiteeri
Algselt postitas: hunt-lambanahas
Mina ostsin mingiaeg tavalise õlirõhu kella ja anduri selle jaoks, aga pole aega leidnud veel installida.
hunt-lambanahas
postitati 01.07.09 20:24 Tsiteeri
Aa mul kah vedeleb uks uus komplekt selline aga jah motlesin just et kas selline sobib bensu susteemi jaoks?Pean aind spets kolmiku tegema!
andrec
postitati 01.07.09 20:58 Tsiteeri
Hydroscand abiks selleks.
Maku
postitati 16.07.09 22:36 Tsiteeri
Bosch state that most spark ignition engines develop their maximum power at air/fuel ratios of 12.5:1 - 14:1, maximum fuel economy at 16.2:1 - 17.6:1, and good load transitions from about 11:1 - 12.5:1. However, in practical applications, engine air/fuel ratios at maximum power are often richer than the quoted 12.5:1, especially in forced induction engines where the excess fuel is used to cool combustion and so prevent detonation.
Autospeed - Tuning Air/Fuel Ratios
 Lehekülgi:  1  2  3
[PHP: 68.7% - SQL: 31.3%]
