 Lehekülgi:  1  2  3  ..  9
Pealkiri: Sisselase (cooler, kollektor..) (Vastuseid: 202 | Vaatamisi: 71105)
Maku
postitati 17.05.06 12:33 Tsiteeri
C4-le uuema kliimaradikaga mõeldud cooler
http://84.50.81.66/albums/album03/fmic_parts_sized.jpg
http://84.50.81.66/albums/album03/fmic_no_bumper.jpg
By prr: http://www.s2forum.com/forum/showthread.php?t=13286
Maku
postitati 17.05.06 13:57 Tsiteeri
Sisselaske kolled
http://www.wagner.mediatel-pr.de/upload/newsticker/020805123304.jpg
http://84.50.81.66/albums/album03/popupp2.jpg
http://www.dahlbackracing.se/images/Parts/insug/s4_2.jpg
http://www.dahlbackracing.se/images/Parts/insug/s4_3.jpg
http://www.mtm-online.de/imgneu/performanceteile2/17_1_s.jpg
MTM-i poolne kommentaar oma kolle kohta:
The mtm 5-cylinder inlet manifold is developed for big power steps (more than 380 hp), to get a short way for the inlet air. Instead of getting air from the back of the engine, the air comes from the front.
HINNAD
WAGNER TUNING - 990 EUR
MTM - 1160 EUR
DAHLBÄCK - 1301 EUR (up to 450hp), 1769 EUR (hand built)
HACKE RACING - 6000 SEK (rebuild your intake manifold for Audi S2, with polished plenum)
034 MOTORSPORT - 1300 $ / dollarit
POGEA RACING - 979 EUR
Maku
postitati 17.05.06 14:37 Tsiteeri
Natukene lugemist (motorgeek foorumi link!) sisselaske kollektoritest. EFI härrased ise väitsid mulle, et "3b vs EFI" sisselaske kolle, on 10-15% võimsuse vahe.
Näitlikustamiseks panen kaks pilti siiagi, mis tulemused EFI mehed said, kui mõõtsid 3B ja nende enda sisselaske kolle voolavust.
Kõige pealt siis nende enda sisselaske kollektor!
http://84.50.81.66/albums/album03/034HO_IM_FLOW.jpg
Seejärel 3B sisselaske kollektori voolavus!
http://84.50.81.66/albums/album03/3B_IM_FLOW.jpg
EDIT: ADU KOLLE! JShadzi: I'll preface by saying I didn't believe it myself either, but the #'s don't lie. Same flowbench, same procedure as the previous 2. We even went back and ran it again to verify, same exact results...
About 5% less flow across the board than the 3B we tested, make your own conclusions
http://84.50.81.66/albums/album03/ADU_kolle.jpg
EDIT2: AAN sisselaske kolle mõõtmistulemused!
http://84.50.81.66/albums/album03/aan_kolle_numbrid.jpg
forsin
Registreerunud 01.07.04
postitati 26.05.06 19:48 Tsiteeri
Algselt postitas: Maku
Natukene lugemist mehed mõõtsid 3B ja nende enda sisselaske kolle voolavust.
B3 Orig. sisse kolde keskmisel pildil on 228,5 kanali ees risti post (poldi auk) jalus, mis segab õhu otse voolamist.
Mina olen need vaheseinad kolde seest eemaldanud.
Eriti hästi saab aru segavatest vahe postidest porshe koldel , mida rohkematest vahe postidest õhk mööda voolab , seda vähem kohale jõuab ja viimases ainult 220.
Maku
postitati 01.06.06 20:57 Tsiteeri
RS2 tuning by POGEA - http://www.audi-tt-forum.de/SHOP/
http://84.50.81.66/albums/album03/1_G.jpg
http://84.50.81.66/albums/album03/2_G_001.jpg
Maku
postitati 01.06.06 21:35 Tsiteeri
AAN kolle S2 peal
http://84.50.81.66/albums/album03/062_G_001.jpg
http://84.50.81.66/albums/album03/KOLLE2.jpg
mulk
Registreerunud 11.11.03
postitati 05.06.06 19:19 Tsiteeri
Kahjuks ei mõõtnud oma kollektorit modifitseerides voolavust võrreldes originaaliga, kes aga plaanib omalegi teha, mõõtku kindlasti.
http://static.flickr.com/56/106410058_a441cb5033_o.jpg
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 08.06.06 09:52 Tsiteeri
Eks see on ka visuaalselt suht aimatav, kui 3B või ABY sisselaset ADU omaga võrrelda...
epic
Registreerunud 26.05.05
postitati 21.06.06 20:11 Tsiteeri
küsimus
Ok siis küsin ühe pika keerulise küsimuse:
On 93a suure kliimaradikaga S4.
Kuhu paigutada cooler ja milline ? Ainus variant teha stangele sisselõige numbri alla ? Forge typ06 500 x 175 x 60mm ja 63,5mm torudega ? Nii saaks paigaldada suurema turbo, mille jahutisse minev ava on 57mm (Garrett GT3071 see vist nii on). Kas cooleri torud võiksid olla rv-terasest (muhvid vahele et liikuma annaks) või silikoonist ?
Filtri poolel tuleks vist kasutada mõnda silikoonlõdvikut, mis on mõeldud VAG 1,8T-mootoritele, sest AANile neid saada pole. Neil peaks olema sama bypass ja tundub, et väljavõtted istuksid.
Ootaks nüüd ettepanekuid, sest asi vaja lähiajal ära teha.
jõuvanker
Registreerunud 21.03.03
postitati 22.06.06 05:32 Tsiteeri
Algselt postitas: epic_metal
Ise küsid ja vastad. Mida rohkem suuda metalltorusid survepoolel kasutada, seda parem, tee võimalikult ühetses tasapinnas liitekohad ( metall+metall ja peale silikoon paikamismuhv ) Üldiselt soovitaks metalltoru võimalikult palju painutada, kasutada põlvesid ning head keevisõmblust :)
epic
postitati 22.06.06 08:11 Tsiteeri
Aga kuidas paigaldada ikkagi ? Kas kõik, kellel on suurem jahuti on kliimaradika ära võtnud siis ? Sellest küll ei taha loobuda...
Millist lõdvikut sisselaskes kasutada ?
See äkki: http://www.forgemotorsport.com/content.asp?inc=product&cat=0017&product=FMA4B5IND
Tegu AEB, ATW, AWM, AVJ lõdvikuga. Mis turbo neil mootoritel küljes on ? Kui suure läbimõõduga õhulugeja ? 80mm ?
PS Kas on sellist head linki, kust saaks erinevate turbode kompressoripoole avade mõõdud teada ?
jõuvanker
postitati 22.06.06 09:10 Tsiteeri
Kui Sul on piisavalt vabaraha, too minu kätte masin, teen ära:D
epic
postitati 22.06.06 10:00 Tsiteeri
Algselt postitas: jõuvanker
Aitäh, aga enda autot teen ma ikka ise. Pole kunagi kusagil midagi "teha lasknud".
Mõtlesin asukohta. Kuhu on C4 kerel kõige mõistlikum paigutada see cooler ?
Maku
postitati 23.06.06 20:48 Tsiteeri
KLIKKA PILTI
http://84.50.81.66/albums/album03/v2iksemCooler.jpg
http://84.50.81.66/albums/album03/suuremcooler.jpg
epic
postitati 27.06.06 18:57 Tsiteeri
034Motorsport pakub 20vt gaasisiibrile vaheflantsi:
http://www.034motorsport.com/product_info.php?cPath=28_63_73&products_id=479
sellega saab paigaldada VR6 gaasisiibri.
Ja see annab juurde mida ? Kas siis tõesti läheb õhuga kitsaks seal ?
oleeev
Registreerunud 23.05.03
Auto: 2x audi S4tq,VW passat2,8 syncro
postitati 27.06.06 19:32 Tsiteeri
Kust ma saaks sellise komplekti ja mis hinnaga?
prr
Registreerunud 20.10.02
Auto: A3 & A4 Cabrio
postitati 27.06.06 22:11 Tsiteeri
Olev, vaata seda pilti :
http://trdsupra.com/images/media/32_Picture_6700.JPG
Tehke või tina, aga tegu on USA variandiga millel hoopis teistsugune stange ( stange liist on pildil oleval autol küljes, mida euro masinatel pole). Ehk siis kes on näinud - USA variantidel on stanged kogukamad ja seal all on rohkem ruumi.
lapsest peale on hobused meeldinud
Maku
postitati 28.06.06 05:39 Tsiteeri
Algselt postitas: oleeev
VASTUS KÜSIMUSELE!
Rst
Registreerunud 06.10.04
Auto: hall metallik diisel Q
postitati 02.07.06 05:21 Tsiteeri
http://bufkinengineering.com/intake%20manifolds.htm
Sealse jutu järgi parimad sisselaske kollektorid.
epic
postitati 04.07.06 10:22 Tsiteeri
http://mailis.apaatne.org/album73/aai
Millega tegu ? Kes toodab ? Kes müüb ? Mis hinnaga ? Kust maalt on vajalik ?
Aitäh
epic
postitati 08.07.06 07:52 Tsiteeri
http://www.kirjastusmuusika.ee/images/audi/dbilas_DKT.jpg
Niisiis Audi mootorile on vaja kahte kahelõõrilist ja ühte ühelõõrilist. Tuleb teha õhukollektor. Siibrikoda siis otse kaane külge ?
mulk
postitati 08.07.06 08:25 Tsiteeri
Turbomootori puhul ei ole ITB vajalik.
TT
Registreerunud 08.06.04
postitati 23.08.06 12:16 Tsiteeri
Soovitage kohta, kus 3B sisselaskekoldelt "seinad" välja puurida ja kinni tekkinud augud keevitada.
Ivo
Registreerunud 08.01.05
Auto: audi 200
postitati 23.08.06 12:42 Tsiteeri
ise lasin teha pärnus ehimetis
Taavi
Registreerunud 21.11.04
Auto: UrS4
postitati 04.09.06 09:24 Tsiteeri
Lihtsalt üks pisike tähelepanek, mille peale võibolla kõik ei tule. Nimelt C4 kerega S4/S6 pole intercoolerist eriti suurt kasu, kui puudub põhjakate. Õhk jookseb mõõda lihtsalt. Seega kui põhjakatet osta ei taha/ei leia, siis tuleks sinna alla mingi plaat meisterdada. Enda omale täna aretasin midagi:P
[PHP: 15.1% - SQL: 84.9%]
