 Lehekülgi:  1  2  3  4  5  ..  14
Pealkiri: ECU, chipindus ja wastegate (Vastuseid: 334 | Vaatamisi: 61837)
Maku
postitati 05.02.06 13:29 Tsiteeri
Chipindus ja wastegate
Lisan paar sõna WASTEGATE vedrust. Copy/paste S2 centralist:
To my knowledge, the 3B engines were equipped with a spring that allows the wastegate to open at 1.6bar of absolute manifold pressure (~0.6bar boost) whereas the ABY & ADU engines were fitted with a 1.8bar WG spring. This means that without the electrical control of the wastegate (via the wastegate frequency valve) the 3B would be capped at 0.6bar boost and the ABY at 0.8bar. This is good for engine preservation, in the event of electrical gremlins, and it allows the ECU to be the major factor in dynamically determining how much extra boost is permitted. In factory configuration, the ECU of the 3B engine permits approx 0.8bar boost and the ABY allows for controlled overboosting spurts of up to approx 1.1bar.
Lets say we have a ECU that runs the 3B or ABY engine at 1.2bar of boost (~2.2bar absolute). A good rule of thumb seems to be that the wastegate spring should be about 0.2bar below total system pressure and so a 2.0bar wastegate spring would be an ideal candidate for this configuration. By using the stiffer spring, there is also a fractional improvement in the time required to close the wastegate such that turbo spinup is marginally improved. The toughest wastegate spring available to my knowledge provides for a mechanical pressure limit of 2.2bar - so this would work well with an ECU designed to run at a lairy 1.4bar of boost.
The tension in the wastegate spring can also be fine tuned by adjusting the upper perch in the top of the wastegate chamber. In doing so, this can increase the amount of pressure required to crack open the wastegate and so provide a cheap and easy way of increasing boost. However - the practise is NOT recommended as the ECU may detect an excessive boost condition and go into 'limp-home' mode. Don't forget that the MAP sensor within the 3B ECU is only rated to 2.0bar of absolute pressure, so it would be pointless trying to get 1bar of mechanical boost on a standard 3B ECU as the MAP sensor would simply flatline and cause the overboost protection routine to cut in. An equally valid concern is that the ECU may not provide adequate fuelling and ignition settings for the now manually increased boost in the system. This applies to any setting with more than 0.8bar of boost - but there might be some tolerance in the ECU that allows for a little excessive boost. I suspect that is more true for the factory ECU of the ABY engine but I have no evidence and don't wish to use my own car as a guinea-pig.
Adjustment of the wastegate spring is best left to serious tuning professionals, and maybe only in conjunction with a revised ECU to make everything run sweetly.
Lühike kokkuvõte on see, et kes soovib sõita 1,4 barise ülerõhuga (K24 tavakasutuseks ja efektiivsuse piiripeale ülerõhk), see peaks kasutama 2,2 barist WG vedru. Ehk siis: ülerõhk + 0,8bar = WG vedru.
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 05.02.06 23:54 Tsiteeri
Siit saabki selgeks see, et ainult vedru näppides on oht väga lihtsalt sattuda olukorda, kus lisandunud boosti puhul jääb segu lahjaks koos kaasnevate probleemidega.
quattromees
Registreerunud 07.01.03
postitati 06.02.06 06:38 Tsiteeri
Algselt postitas: generaator M
ABY, AAN kohta ei oska öelda, 3B mootoril kuni 1.5bar ülerõhuni segu lahjaks ei jää (kui soft õige), üle selle ei tea.
Kokku rohkem, kui 1100 hobust
Maku
postitati 25.02.06 11:58 Tsiteeri
Andrus, seal jutus oligi mõeldud stock 3B mootori ECUt.
Väiksem map sensor iseenesest "fuel cut-i" ei põhjusta. Pigem teevad seda muud tegurid. Olen proovinud erinevaid softe ja erinevaid seadistusi. Minu kogemused näitavad seda, et kui ka rõhk üle lubatud map sensori piiri läheb, siis õige softiga segu lahjaks ei jää. Teooriat netist lugedes on nii, et kui rõhk läheb üle map sensoril lubatava, siis ECU ei saa enam lihtsalt infot, mis kapoti all toimub ja ei oska enam protsessi õigesti juhtida (ehk siis, et võivad tekkida anomaaliad).
genekas
postitati 05.03.06 01:28 Tsiteeri
Ega MAP pole ainus asi, mille järgi võib aju aru saada, et on aeg bensu pealeanne ära lõigata - kui näiteks MAP ei anna suurema rõhu signaali välja, aga MAF järgi õhuhulk kasvab üle maksimaalse lubatud laaderõhule antud pöörete ja gaasiklapi asendi puhul vastava õhuhulga väärtuse, siis saab aju ikkagi aru, et tegu on liiga kõrge rõhuga.
forsin
Registreerunud 01.07.04
postitati 05.03.06 20:28 Tsiteeri
Järelikult minul suurte nukkidega ja soft ainult (195kw) peaks kogu aeg bentsu kinni keerama kuna õhu kogus on väga suur ??? Aga ei esine sellist jama, miks ??? kuigi lamda kell on ammu üle lahjade tulede ja kustunud= ülilahja (tervik segu), rikaks jäi ainult süttimis segu (mis hoiab kolbe ära sulamast).
Lisan selgituseks, et bensu pump karanteerib surve ja 250 map kinni ei jookse ülesurve klapp lõikab 2,2 bar ga liigse ära.
epic
Registreerunud 26.05.05
postitati 15.10.06 11:46 Tsiteeri
Aga
Kui asendada urS4 orig. aju progetavaga, siis mis asjad armatuurist ära kaovad ? St kütusekulu ja muud näidud on otseselt ajuga seotud ja progetavaga neid enam pärast ei näe ?
Silwer
Registreerunud 11.12.02
postitati 15.10.06 16:04 Tsiteeri
Kompuutri näidud kaovad ära - rõhk, kütusekulu, jne.
BMW 325i E30 2,8 stroker & BMW 328iT E36 & Seat Altea XL 2,0 TDI+DSG
epic
postitati 18.10.06 17:24 Tsiteeri
Aga mida oleks vaja, et ise chippi kirjutada ? Ütleme kui tahaks kopeerida teise samasuguse chipi. Peaks ju saama mingi eepromi kirjutajaga seda teha ?
quattromees
postitati 19.10.06 11:36 Tsiteeri
Algselt postitas: epic_metal
Kopeerimine saab, aga muuta ei mõista, kuna pole infot, mille abil hex koodist aru saada...
Taavi
Registreerunud 21.11.04
Auto: UrS4
postitati 19.10.06 13:20 Tsiteeri
Minul on küll hex nö lahti kodeeritd kujul. Aga muuta ei mõista ikka mitte midagi.
quattromees
postitati 19.10.06 21:17 Tsiteeri
Algselt postitas: Offroader
Tahad Sa sellest pikemalt rääkida???;)
Taavi
Auto: UrS4
postitati 19.10.06 21:23 Tsiteeri
Hetkel veel mitte. Pean enne korra aju veel lahti võtma paari asja täpsustamiseks. Aga tekst on loetav igatahes.
forsin
postitati 20.10.06 13:27 Tsiteeri
kui me eestis sellega hakkama saame (4 x mapi muutmisega ) mina tahaks muuta ainult ühte map-i.
siis poleks progetavaid ajusid vaja = ~ ABT !!!
orig. aju kombib süüdet kuni kindla läheduseni detonatsioonile (progetaval paned ainult jäigalt paika ja kõik)
ei ta õpi midagi etr kõige valusamat süüdet saada (kaitsevad mõlemad).
sammuti orig. aju kombib pidevalt lamdat rikkama poole kuni 1,0 -ni
kuid enamus progetavatel ajudel puudub ise õppiv lamda süsteem.
kellel soovi arutame.
sest enda arvates tean mida ja kuhu muuta (mootori poolseid vajadusi silmas pidades) kuidas on arvuti poolne osa ??? aga kellegagi kahekesi võibolla tekkib tulemus.
samas nõus oma S6 peal katsetama sest on lisatud mootorle kaitseks mitte elektroonilised lisad.
epic
postitati 21.10.06 13:05 Tsiteeri
Milline EPROM-i kirjutaja on kõige parem ?
Keegi võiks sellest rääkida. Hinnad on erinevad. Näiteks byteshooter master maksab üle 4000 euro, mis pole normaalne ju :) Samas saab mõne programmaatori ka 50 euroga. Mis on nende vahe ? Ja mis softi kasutada kopeerimiseks ?
PS Tevalos maksab 27C256 tühi eprom-chip 80 krooni. Mis hinnaga meil chippe ostetakse ? 2k ? Ja "personaalne" chip maksab miski ~10k ? :P Äkki teeks lõpu sellele :)
Milline neist sobib 20vt aju progemiseks kõige paremini:
http://www.tevalo.ee/cgi-bin/web_store.cgi?ec=5a24b1c
Maku
postitati 21.10.06 16:29 Tsiteeri
Milleks sulle on vaja eprommi programmaatorit?
Silwer
postitati 21.10.06 16:52 Tsiteeri
Huvitav kuhu sa kavatsed seda kivi toppida? Kui mõtled et see sobib 20v 2,2t ajusse siis sa küll rängalt eksid. Sa võid sinna peale isegi mingi proge kopeerida aga tööle see auto selle kiviga lihtsalt ei lähe... :)
Aga soovin sulle edu chippide kopeerimisel. Seal on mõned nõksud (just aju enda poole pealt) mida kindlasti peab teadma - ja kui ei tea siis saad ruttu aru miks see 2000-3000 eek chipi eest on tegelikult odav.
quattromees
postitati 21.10.06 18:32 Tsiteeri
Külasepad kasutavad DIY programmaatorit, sobivaid kive leiab vanadest arvutikomponentidest...:P
Silwer
postitati 21.10.06 19:32 Tsiteeri
27C256 (millega pole midagi teha) ja 27C512 (mis on alles poolik lahendus ehk siis ei lahenda veel midagi) kive võib leida küll igasugustest vanadest aparaatidest aga seda "ühte" kivi mis ka aju tööle paneks te kindlasti kohe mingi vana "arvuti" seest või Tevalost ei leia... :)
quattromees
postitati 21.10.06 19:47 Tsiteeri
Algselt postitas: Silwer
Ei oska kommenteerida, sest senini pole "külasepal" midagi tegemata jäänud...
TT
Registreerunud 08.06.04
postitati 21.10.06 21:16 Tsiteeri
Katsuge aru saada, et inimuba (human been) on selline olevus, kellele ei piisa vastusest " ei saa";)
prr
Registreerunud 20.10.02
Auto: A3 & A4 Cabrio
postitati 21.10.06 23:54 Tsiteeri
87C257 on meil see "probleemne" kivi. Odavamad programmaatorid seda kivi ei tunne.
lapsest peale on hobused meeldinud
prr
postitati 21.10.06 23:55 Tsiteeri
Algselt postitas: Maku
Äkki tahab inimene ise kive kirjutada/katsetada. See oleks nagu reaalne seletus asjale.
epic
postitati 22.10.06 00:21 Tsiteeri
Selline plaan oleks jah.
Jah, loomulikult 20vt ajusse, nagu sa isegi aru said. Räägi siis nõksudest, mida teadma peab. Ja sellest, miks tööle ei lähe.
Millist ühte kivi ?
Või ei taheta "ärisaladust" välja rääkida ?
quattromees
postitati 22.10.06 01:28 Tsiteeri
Sportlikust huvist arendaks seda teemat edasi.
Keegi on leidnud kuskilt Audi Motronic M2.3 ja M2.3.2 bin defination`i???
Mingil salatsemisel pole mõtet, sest praktikas vaevalt mingeid arvestatavaid (positiivseid:P) muudatusi keegi ka infot omades võimeline tegema on.
Motronicu kohta kiirelt leitud näide, porge kohta:
siin
TunerPro´ga auto softi avades saab sellest ilusaid 2d ja 3d graafikuid, samas näeb konkreetset aadressi. Hex`i saab seada decimal´iks, et oleks lihtsab asja pe*sse keerata...;)
Arvan, et katsetan huvi pärast ära, kuidas aju reageerib suvalisele muutusele, näiteks softi tootja asemele kirjutaks midagi muud ning katsetaks, kas käima läheb või annab mingi checksum errori...
[PHP: 72.5% - SQL: 27.5%]
