Pealkiri: Поиск… Radio info and navi display on B5 Audi S4 (Vastuseid: 1 | Vaatamisi: 2121)
ClintBarton
Registreerunud 28.06.18
postitati 29.06.18 07:14 Tsiteeri
HI,
I have a 2001.5 Audi S4 (B5) retrofitted with a RNS-E radio/navi unit, with its CAN bus wired to the instrument cluster. I would like to install the ColorMFA. Currently with the original red FIS, it shows radio info, as well as navi directional arrow, bargraph, and other info (while guidance is active) on the FIS as a secondary display. Reading the previous messages posted in this forum, it appears that the ColorMFA will also fully support these functionalities. Am I correct?
Can someone post some photos or video of the navi stuff working on the ColorMFA? I have not seen any so far.
Please help.
I did not find the right solution from the internet.
References:
http://www.colormfa.ru/forum/viewtopic.php?t=822
Online Video Production Studio
Thanks!
postitati 29.06.18 07:33 Tsiteeri
This is actually a online gathering place for CAR enthusiasts and specifically for Audi brand :cool:
Hopefully someone could help You out!
Edit 02.07.2018
Algne postitus (OC from OP) nägi välja selline:
"Actually two issues. First when I tried to search the forum for this issue I tried "Audio issues" and got no results due to the terms being "too common." I tried many other variations and it always either returned no results or ignore the most relevant terms and returned useless threads. NOT VERY HELPFUL!My real problem is that when Dorico is running, no other program (youtube for example) will produce any sound. So if I wanted to watch the tutorial videos I have to exit Dorico and then restart it afterwards. I find that annoying and limiting. Any thoughts or suggestions?"
[PHP: 42.0% - SQL: 58.0%]
