Pealkiri: veakoodid (Vastuseid: 3 | Vaatamisi: 3052)
RKaudi
Registreerunud 05.05.16
postitati 05.05.16 18:33 Tsiteeri
veakoodid
Tervist sai siin audi a6 2.5tdi quattro 132kw pingeregulaatori ära vahetatud! lööb vead ikka sisse sai juhtme taha pandud! kustutasime ära ja asjad ikka tagasi! peale seda lööb espi ja absi tule põlema iga 10 minuti tagant!
Chassis Type: XX (4B - Audi A6 C5 (1998 > 2006))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: XXXXXXXXXXXXXXXXX Mileage: 361900km/224874miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 4B2 907 401 B
Component: 2.5l/4VTEDC G400AG D00
Coding: 01016
Shop #: WSC 02239
VCID: 1F4B95279D3F0EE6827-4A3A
Subsystem 1 - Part No: 00014059
Component: 13059 130 106EC150_1.R75242
00014059 13059 130 106EC150_1.R75242
1 Fault Found:
01117 - Generator Terminal DF Load Signal
27-10 - Implausible Signal - Intermittent
Readiness: N/A
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 BR
Component: AG5 01V 2.5lTDI RdW 3133
Coding: 00011
Shop #: WSC 00000
VCID: 78F99EBB585199DEA3D-5072
1 Fault Found:
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D36
Coding: 06257
Shop #: WSC 02325
VCID: 3567578F0FC3A4B678B-5000
1 Fault Found:
18265 - Load Signal
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 AH
Component: A6-Klimavollautomat D65
Coding: 00040
Shop #: WSC 02325
VCID: 60C9D6DBE0C1711EFBD-254E
1 Fault Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 G
Component: Airbag Front+Seite 1001
Coding: 00106
Shop #: WSC 02324
VCID: 34616A8B04B9BDBE4F5-5072
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance Too High - Intermittent
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 936 PX
Component: C5-KOMBIINSTR. VDO D17
Coding: 00160
Shop #: WSC 00006
VCID: 8B135177B9C702467EF-5000
XXXXXXXXXXXXXXXXX AUZ7Z0E2747323
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 E
Component: Zentralverrieg.,DWA D33
Coding: 04683
Shop #: WSC 00200
VCID: 2B5371F7D987E2461EF-4E42
9 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01560 - Passenger Door
58-10 - Can't Lock - Intermittent
01561 - Rear Left Door
59-00 - Can't Unlock
01559 - Drivers Door
60-00 - Won't Safe
61-00 - Won't De-Safe
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00002
Shop #: WSC 02325
VCID: E0C956DB60C1F11E7BD-4A9C
3 Faults Found:
01403 - Glass-Break Sensors; Rear
36-10 - Open Circuit - Intermittent
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
01384 - Alarm triggered by Glass Breakage Sensor
35-00 - -
yanekk
postitati 05.05.16 18:41 Tsiteeri
Ja mida sa teada siis kokkuvõttes tahad?
Teema vales kohas ja ka selle lugemine ei teeks paha, http://foorum.audiclub.ee/viewthread.php?tid=62785
Best ET 12.08 :)
RKaudi
postitati 05.05.16 18:43 Tsiteeri
kuida selle geneka asja korda saaks? ja mis need teised koodid tähendavad? Ettetänades!
RKaudi
postitati 05.05.16 18:47 Tsiteeri
Selge! Sain aru.
[PHP: 64.0% - SQL: 36.0%]
