S - Audid
S - Audid - üldine
S3 Quattro
[quote][i]Algselt postitas: Samzik[/i] Aga on keegi kuulnud midagi mootori poole pealt, mis motod s3 quattro peal on ? 1.8t aga mis täpsemalt. Leidisn midagi sellist. "What Are The Differences Between The 150, 180, 210 And 225 Bhp Vag 1.8 Turbo Engines?" All the engines are basically the same but there are some important differences to account for their varying outputs. For the Octavia alone, there actually seem to be three types of the 150 bhp engine. The AGU engine is the 1.8T engine in the pre-facelift Octavia Elegance/L&K FWD. This engine utilises Borg-Warner's K03 turbo, has smaller injectors to that in the facelifted cars and does not feature variable valve timing and drive-by-wire (it has an old-fashioned throttle cable instead). When tuned, this engine will not produce as much power as the later engines. 193 bhp seems to be the maximum. The 150 bhp engines in the 4x4 (code ARX) and the post-facelift FWD Elegance/L&K (code AUM) seem to have basically the same inner workings as the 180 bhp engine in the RS (code AUQ). They all have bigger-sized injectors and feature the K03sport turbo. This is a hybrid turbo, using the K04 turbine in a K03 casing. The differences in power between all three engines seem to be merely ECU mapping related. Hence, these engines will produce similar gains when tuned. This is in the region of 205-225bhp. The 210 and 225 bhp engines as found in the Seat Leon Cupra R, Audi S3 and Audi TT have different internals and a bigger k04 series turbo, all which allow it to produce more power. A chipped version of these engines can reach 260-270 bhp. Below is a brief overview of various 1.8T engines. This is not a comprehensive overview, but it will show the differences between the main engines used by Skoda and the other VAG brands. AGU Skoda Octavia 1.8T FWD (Elegance, L&K), 10/96-8/00 Also found in: Audi A3 1.8T and Volkswagen Golf GTI (earlier models) Output: 150 hp Drive: FWD Emission: Non-VVT, EU3 Throttle: cable Injectors: small Turbo: K03 Gearbox: EVS, EGY AUM Skoda Octavia 1.8T FWD (Elegance, L&K), 8/00-now Also found in: Volkswagen Bora 1.8T and Volkswagen Golf GTI (updated models) Output: 150 hp Drive: FWD Emission: VVT, EU4 Throttle: drive-by-wire Injectors: big Turbo: K03sport (k03/04) Gearbox: EBN, ENJ, ESV, FDC AUQ Skoda Octavia RS, 8/00-now Also found in: Seat Leon 20VT Topsport Output: 180 hp Drive: FWD Emission: VVT, EU4 Throttle: drive-by-wire Injectors: big Turbo: K03sport Gearbox: EHA (Octavia RS, 5-speed, long gearing - Leon has 6-speed 'box!) ARX Skoda Octavia 1.8T 4x4 Elegance, 8/00-now Output: 150 hp Drive: Haldex 4WD Emission: VVT, EU3 Throttle: drive-by-wire Injectors: big Turbo: K03sport Gearbox: FEX (5-speed, short gearing) Other 1.8Ts APX: Audi TT, 225 hp, Haldex 4WD, K04, 6-speed APY: Audi S3 (earlier model), Seat Leon Cupra R (earlier model), 210 hp, Haldex 4WD, K04, 6-speed ARY: Seat Leon 20VT Cupra 4, 180 hp, Haldex 4WD, K03sport, 6-speed ARZ: Volkswagen Golf GTI, 150 hp, FWD, K03sport, 5-speed AWT: Audi A4 1.8T/1.8T quattro and Volkswagen Passat 1.8T, 150 hp, FWD or Torsen 4WD, K03, 5-speed AWU: Volkswagen New Beetle 1.8T, 150 hp, FWD, K03, 5-speed BAM: Audi S3/TT (updated models), Seat Leon Cupra R (updated model), 225 hp, Haldex 4WD (S3/TT) or FWD (Cupra R), K04, 6-speed BFB: Audi A4 1.8T/1.8T quattro (updated model), 163 hp, FWD or Torsen 4WD, K03sport, 5-speed [url=http://www.daniil.dds.nl/skoda/vag-1.8t-engines.html]link (allikale)[/url] [/quote]
S - Audid
S - Audid - üldine
S3 Quattro
22
47.3%
52.7%
