S - Audid
20vT - tuuning
Sisselase (cooler, kollektor..)
[quote][i]Algselt postitas: Maku[/i] [quote][i]Algselt postitas: epic_metal[/i] Marko, kas pööratud Wagneril on ta siis täpselt sama suur ? [/quote]Nu siiber on kollektori küljes ja keerasin selle avatuks ning vaatasin sisse ja seinad olid samal joonel. Katsusin ka sõrmega üle ja mingit üleminekut ei täheldanud. [url=http://www.034motorsport.com/engine-components-audi-i5-20vt-3baan-throttlebody-boring-service-70mm-p-460.html]3B/AAN Throttlebody Boring Service, 70mm[/url] [i]Big bore throttle body service for 3B or AAN throttle bodies, we disassemble the stock throttle body, clean it, remove the stock throttle blade and shaft, and bore the throttle body to 70mm (up from 65mm), also removes the throttle wedge. Over a 15% increase in flow with faster throttle response, not recomended for cars where VERY smooth throttle tip in is desired. Core throttle body required, we have modified throttle bodies in stock, just send in your unit and we will return a modified unit. Also, we ask that you remove your TPS from the throttle body before shipment as its not requried for the modification on our end. With a $250 core charge, we can ship modified throttle body to you, core charge will be refunded upon return of good, usable unit.[/i] Ehk siis nad võtavad siibri koos võlliga välja ja puurivad seest 65mm pealt 70mm peale. [/quote]
S - Audid
20vT - tuuning
22
42.5%
57.5%
