S - Audid
20vT - tuuning
Sisselase (cooler, kollektor..)
[quote][i]Algselt postitas: Maku[/i] [quote][i]Algselt postitas: Maku[/i] The reversion pulse that comes when the intake valve opens, runs backward up the runner and bounces off the plenum. At the right RPMs, it will start to resonate. This pulse then goes back down the runner pushing up to 130% more air in front of it! The air speed gets up to about .8 Mach. This is why if everything is equal, fuel injection will make more horsepower than carbs. The higher air speed in the runners gives you better cylinder filling at the lower speeds which gives you better bottom end. [b]Arrange the runners in the plenum so that the reversion pulse bounces off a hard surface. You don't want the pulse to blow down the opposite hole.[/b] LINK: http://www.dune-buggy.com/turbo/intake.htm [/quote] Kas ainult minule tundub aga näiteks [url=http://84.50.81.66/albums/album03/mtmvssmsvsaan.sized.jpg]SMS ja AAN kollektorid[/url] ei ole selles mõttes just eesrinnas? [/quote]
S - Audid
20vT - tuuning
22
35.8%
64.2%
